| Re: Does Jay really have a boat?
[Re: ]
#269538 02/19/14 01:32 PM 02/19/14 01:32 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | Galvanized Trailer w/Lunchbox ?? come with a sandwich press too? If a sale is contingent on a sandwich press, I'll have it installed. | | | Re: Does Jay really have a boat?
#269540 02/19/14 02:22 PM 02/19/14 02:22 PM |
Posts: 5,590 Naples, FL | You'll have to come out and see us on March 1st. We should (hopefully) be cruising past Marco island in the afternoon. Note; we might duck behind Ten Thousand Island and cut the corner if the wind is right. if your boat draws less than 3 feet, you should be fine almost everywhere. You can see the bottom = time to turn  if you cut in at Big Marco pass, there are two fixed bridges (I think 40+ feet clearance). with that speed demon, I think the straight shot on the outside route might work best. Cut a left at Romano between the sand bars, keep Gullivan bay marker on your left, and it's a straight shot to Cape Sable. I guess the strategy call would be to continue directly to Duck Key and run north (ala Steeplechase) or hang a left at Cape Sable and run that route ...? You going to have a spot transponder or anything I can keep an eye on your progress? It would be nice to watch that thing fly by... while I work on my tan and drinking muscles
[Re: ThunderMuffin]
#269544 02/19/14 03:31 PM 02/19/14 03:31 PM |
Posts: 4,119 Northfield Mn | Galvanized Trailer w/Lunchbox ?? come with a sandwich press too? If a sale is contingent on a sandwich press, I'll have it installed. I can just picture a Foreman grill screwed down somewhere bouncing open/closed as it goes down the road.  Good conversation piece at the very least.
[Re: waterbug_wpb]
#269546 02/19/14 03:59 PM 02/19/14 03:59 PM |
Posts: 12,310 South Carolina | There will be a spot tracker page but Alan has all of that info. I'll have to get him to give me links to share. Florida bay is an option but it's risky...apparently the water can drain away for miles should the wind switch and blow out of the north. Two dudes were stranded on a 12 foot boat for three days trying to cut through Florida bay in one of the recent events. if your boat draws less than 3 feet, you should be fine almost everywhere. You can see the bottom = time to turn  That method works only works when the sun is up ;-)
Jake Kohl | | | Re: Does Jay really have a boat?
[Re: jkkartz1]
#269719 02/26/14 10:50 AM 02/26/14 10:50 AM |
Posts: 5,590 Naples, FL | Well, Jake, if you believe the NOAA forecast I don't think you're in for a record-breaking year, but it could be a very nice sail in your light air rocket.
Weak front appears to move through Thursday night with Atlantic High dominating the rest of the weekend. Easterly direction (ENE / ESE) and light (5-10 kts) which should keep the water pretty flat near shore.
A bit more breeze as you near Cape Sable, mainly out of ENE which might make your Steeplechase routing a bit more feasible?
Sunny and warm, too.
[Re: pgp]
#269721 02/26/14 12:48 PM 02/26/14 12:48 PM | MN3
| MN3
Unregistered | With water in the gulf in the low 60's and air temps in the upper 70's ... I am expecting a nice sea breeze all weekend long in my neck of the woods, don't know why it would be any different south of here. | | | Re: Does Jay really have a boat?
[Re: ]
#269722 02/26/14 01:16 PM 02/26/14 01:16 PM |
Posts: 5,590 Naples, FL | water temperature at "the turn" (Naples/Marco) is closer to 73 F, which isn't that much cooler than the air temperature.
Current temp near Cape Sable is 77
[Re: pgp]
#269723 02/26/14 03:42 PM 02/26/14 03:42 PM | MN3
| MN3
Unregistered | wow, I had no idea it was that much warmer there. | | | Re: Does Jay really have a boat?
[Re: waterbug_wpb]
#269728 02/26/14 07:14 PM 02/26/14 07:14 PM |
Posts: 4,119 Northfield Mn | yes, I walked south until no one I spoke to knew what "frost" meant. The frost is seven feet thick in exposed areas around here. I've never heard of it going that deep. The septic lines at the shop have had to been blasted three times this winter to clear ice and keep the drains working. Only two more months left!!!
[Re: brucat]
#269740 02/27/14 09:23 AM 02/27/14 09:23 AM |
Posts: 5,590 Naples, FL | You're blasting your septic lines? I don't even want to know what that could possibly mean. Just means lunch at Taquito #3 here...
[Re: waterbug_wpb]
#271056 04/02/14 04:03 PM 04/02/14 04:03 PM |
Posts: 5,590 Naples, FL | ![[Linked Image]](http://i90.photobucket.com/albums/k245/jronline13/IMG_20140331_143855_290_zpsc68ea25e.jpg) Finally figured out how to rig the screecher. Touched 8 knots in what looked like 5 TWS (barely ripples on the water). Too bad the pole's too short to leave the jib up.
[Re: pgp]
#271178 04/05/14 12:09 PM 04/05/14 12:09 PM |
Posts: 5,590 Naples, FL | I saved a track on google earth. how do I post a snapshot of it here?
22,008
guests, and 747
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,915 1 hour ago | | |
