Double stack designs #269398
02/15/14 09:33 AM
02/15/14 09:33 AM
Memphis, TN
Andy Humphries Offline OP
Memphis, TN
I'm redesigning my double stack trailer for F18s and F16s. Search feature stinks. Can someone direct me or provide pics, etc. Thanks!
Re: Double stack designs [Re: Andy Humphries] #269407
02/15/14 07:01 PM
02/15/14 07:01 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
this one is probably a year old now and is still working a treat with it on the road most w/ends.
Trailer can be used for one or two boats as the 2nd boat carrying setup is all slip in.
Basicly the 2nd setup is a duplicate of the lower setup.
Kingy
& now Mosquitos #1182 & #1740
Re: Double stack designs [Re: Pirate] #269408
02/15/14 07:27 PM
02/15/14 07:27 PM
srm Offline
srm  Offline
I don't see any for/aft or side-to-side angle bracing. You're not concerned about the frame racking?
sm
Re: Double stack designs [Re: Andy Humphries] #269409
02/15/14 08:17 PM
02/15/14 08:17 PM
Andy, I'm extremely pleased with how well my setup has worked.
Re: Double stack designs [Re: Andy Humphries] #269410
02/15/14 08:34 PM
02/15/14 08:34 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
I like mine. similar to the ones Fun in the sun sell.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Double stack designs [Re: Andy Humphries] #269417
02/15/14 10:29 PM
02/15/14 10:29 PM
I've got a second iteration of my first one in my head...but regretfully, no sketches. It consists of a flip down rear rack and mast support that hinges on the rear cross bar and might even include a locking system on the hinge (locking vertical). Two members attach to the trailer forward of the rear and hinge up to be bolted in place with some speed knobs.
The front rack would be completely welded (as was my last one) and rest on the cross member just in front of the beam of the lower boat. It too would have a brace that goes rearward to bolt to the trailer to give it some fore/aft stability but that brace would be welded to the doublestack rack and be bolted semi-permanently in place.
I've seen some designs that have a box built around the lower boat with a diagonal cross member between the top and the bottom. I like that solution because it gives you complete access to the lower boat...but, the tradeoff is that it makes it forever difficult to get to the trailer boxes.
Re: Double stack designs [Re: Andy Humphries] #269423
02/16/14 10:46 AM
02/16/14 10:46 AM
Memphis, TN
Memphis, TN
Thanks for the input. Please keep the suggestions coming. I have a Mac Daddy box from Trey that changed things because of the height.
Re: Double stack designs [Re: Andy Humphries] #269427
02/16/14 02:44 PM
02/16/14 02:44 PM
brucat Offline
brucat  Offline
If you use strong enough material, you shouldn't need diagonal bracing. You may want to use gussets, but I've seen some strong trailers without that as well. The tradeoff is weight, of course.
The outside box idea is great if you want to sail the bottom boat more often, especially if you routinely store two boats on the trailer.
Can't wait until my kids are old enough to need a doublestack!!!
Re: Double stack designs [Re: Andy Humphries] #269429
02/16/14 03:39 PM
02/16/14 03:39 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
My trailer set up you can remove the bottom boat without removing the top boat. You do however need to take the masts off as the rear support blocks the boat in.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Double stack designs [Re: Andy Humphries] #269441
02/17/14 06:53 AM
02/17/14 06:53 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
This is the poor mans triple stack trailer, highly not recommended, extremely slow to pack and reassemble. but that is what happens when you buy two boats at a national titles. It got us home but really didn't like it!
tripple 1.jpg (60 downloads)
tripple 2.jpg (38 downloads)
tripple 4.jpg (29 downloads)
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Double stack designs [Re: Andy Humphries] #269446
02/17/14 09:30 AM
02/17/14 09:30 AM
What about a hexa stack trailer? With an ATV?
This is one of Fun in the Sun's trailers coming back from ABYC in Long Beach for the Alter Cup a few years ago.
Re: Double stack designs [Re: Dazz] #269449
02/17/14 10:42 AM
02/17/14 10:42 AM
Used motorcycle tires work as good between-boat pads in a pinch. I've seen some a-caters do that before.
Re: Double stack designs [Re: Andy Humphries] #269478
02/18/14 09:42 AM
02/18/14 09:42 AM
brucat Offline
brucat  Offline
I've done the 2x4 wrapped in beach towels trick before, and it works well. But, the OP is talking about designing (or redesigning) a real double stack trailer.
One other thing to consider is flexibility in the design to accommodate a third boat. Not something that's done every day, but gives you the option to buy a new boat, help with a sale delivery, get another boat to a big regatta, etc. Sort of like us with the single trailers jury rigging up a double stack, you could plan ahead to turn your double into a triple on demand.
Re: Double stack designs [Re: Andy Humphries] #269480
02/18/14 10:02 AM
02/18/14 10:02 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Building a rack on the front that could carry a set of cat-trax to use as cross bars has been on my list for a while now. I think that 2 separate stands in the back could support another set of trax for the 2nd boat. I think that it would work well enough, if you were dedicated double stacking most of your trips, then you would probably want an option that didn't lock in the lower boat.
Re: Double stack designs [Re: bacho] #269484
02/18/14 10:30 AM
02/18/14 10:30 AM
I would be worried about the strength of the catrax for the front part since the 80% of the boat weight is carried there and it sees considerably higher cycle loading while on the trailer. But, that is a really interesting idea for the rear cradle and one I might steal. My trailer is already configured with uprights to store my cat-trax so if I'm double stacking, I only need to transport one extra set. Interesting thought. It might lead to needing extra height to clear the wheels...or maybe not.
Re: Double stack designs [Re: Jake] #269487
02/18/14 10:49 AM
02/18/14 10:49 AM
Can you make the centerline sailbox slide (on rollers like a drawer) out behind the trailer? Maybe a swing-down wheel to support the aft end while it's extended?
Then you might get to the sailbox without moving any boats (not sure if you'd ever need to do that but since we're brainstorming....)
Re: Double stack designs [Re: Andy Humphries] #269488
02/18/14 10:52 AM
02/18/14 10:52 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
My theory was that with 2 boats you will want 2 sets, and they do take considerable room on a trailer, might as well make use of it.
A removable external upright would solve any issues with the tracks not handling the load, but that sounds like a bandaid to me.
If you could sneak the upright of the front stand between the hull of the lower boat and to the outside of the trax tire, I bet it would survive.
Re: Double stack designs [Re: Andy Humphries] #269516
02/19/14 06:02 AM
02/19/14 06:02 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Here is my other elegant solution.
Re: Double stack designs [Re: Andy Humphries] #269519
02/19/14 08:02 AM
02/19/14 08:02 AM
This is a popular double stack trailer we use over here.
The top hull supports are removable when you are just using one boat, and the box is big enough to fit a complete set of gear for two boats.
Re: Double stack designs [Re: Andy Humphries] #269530
02/19/14 12:27 PM
02/19/14 12:27 PM
brucat Offline
brucat  Offline
So you have zero access to the box if there are boats on the rack?
I guess you'd get used to that, but something is almost inevitably forgotten at least once in a while.
1 registered members (Damon Linkous), 4,145 guests, and 742 spiders.
