| Re: [Prindle 19] Holes in mast
[Re: Ameland]
#269442 02/17/14 07:09 AM 02/17/14 07:09 AM |
Posts: 586 Hobart, Tasmania, Oz. | Those holes sound like your mast rotation spanner, is it missing by any chance?
[Re: Ameland]
#269450 02/17/14 10:45 AM 02/17/14 10:45 AM |
Posts: 12,310 South Carolina | some photos will really help us help.
Jake Kohl | | | Re: [Prindle 19] Holes in mast
#269458 02/17/14 03:25 PM 02/17/14 03:25 PM |
Posts: 6 | some photos will really help us help. I Will make some photos this weekend. | | | Re: [Prindle 19] Holes in mast
[Re: Ameland]
#269775 03/02/14 10:00 AM 03/02/14 10:00 AM |
Posts: 6 | | | | Re: [Prindle 19] Holes in mast
[Re: Ameland]
#269776 03/02/14 10:00 AM 03/02/14 10:00 AM |
[Re: Ameland]
#269777 03/02/14 10:37 AM 03/02/14 10:37 AM |
Posts: 3,224 Roanoke Island ,N.C. | Aluminum rivet with 3m 5200 or sikaflex around it and over the hole in the center of the rivet should do fine.
[Re: Ameland]
#269862 03/05/14 09:54 AM 03/05/14 09:54 AM |
Posts: 2,844 42.904444 N; 88.008586 W | It looks like a block, maybe a jib downhaul went there?
YOu could also just silicone a large threaded screw into the holes. Doesn't look to be a structural issue, from those pics anyways.
The P19 is a nice boat.
F-18 Infusion #626- SOLD it!
[Re: Ameland]
#269895 03/05/14 09:13 PM 03/05/14 09:13 PM |
Posts: 3,224 Roanoke Island ,N.C. | I can ' t fint rivet in That size the hoes arena to big for 6 mm rivets .. Forego the rivet and just use 5200. All you really need to do is seal the mast.DO NOT put a stainless steel bolt or rivet in the hole just to fill it. Stainless will cause galvanic reaction and you don't need the strength of stainless for anything in that repair.
3,236
guests, and 277
