Page 1 of 6 1 2 3 4 5 6
footstraps can hurt! #271912
04/28/14 06:29 PM
04/28/14 06:29 PM
Hobart, Tasmania, Oz.
Dazz Offline OP
Dazz  Offline OP
this is from the Asia pacific champs in new zeasland, a very painful experience I'm sure!
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: footstraps can hurt! [Re: Dazz] #271919
04/29/14 04:49 AM
04/29/14 04:49 AM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
Je.., That is really a horrorscenario came true.
But do you have onely one footstrap or two (per hull)??
For that reason I decided to implement on my cat only 1 footstrap for the back-foot. Which also has a spacious fit; as for helping a possible emergency exit.
I picked a footstrap from a windsurfboard for that.
Anyway lots of success with your broken foot. I hope you will be sailing again in half a year.
P.S. Do you consider to use a higher trapezehook position in future?
ronald
RAIDER-15 (homebuilt)
Re: footstraps can hurt! [Re: Dazz] #271923
04/29/14 07:48 AM
04/29/14 07:48 AM
M
MN3
MN3
M
ouch!
Re: footstraps can hurt! [Re: Dazz] #271924
04/29/14 07:59 AM
04/29/14 07:59 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
My foot straps already scare me, that doesn't help.
Re: footstraps can hurt! [Re: bacho] #271927
04/29/14 09:03 AM
04/29/14 09:03 AM
make sure they're loose enough that you can get your foot out of sideways but tight enough that you can't get your upper ankle shoved into it. You shouldn't look at a footstrap as a way to make your foot captive (easy to keep your foot in but hard to get it out)...look at it as something that you still have to use your foot muscles to hang into. If you ever feel the need to either reach down to open it up for your foot or if you have to wiggle your foot into it, you're doing it wrong.
One of our I20s had two footstraps on the rear of the boat - I've never felt so vulnerable than the 15 seconds I tried to sail with both feet in those straps...that was a train wreck in wait.
Also of note, the Magic Marine "light" footstraps are good in that they are more rigid than some of the others and can be set with a very large opening. We replaced the ones on our Infusion for this reason as they were an older style that wouldn't open up and stay open. I used to just barely put the ball of my toes into the old ones for safety because they wouldn't open up enough to allow escape at extreme angles. The "light" Magic Marine versions are very similar (same with different graphics I believe) that are coming on the newer Infusions/Nacras.
Re: footstraps can hurt! [Re: Jake] #271928
04/29/14 10:05 AM
04/29/14 10:05 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Anyone have a link for a US provider for the Magic Marine footstraps I can only find sites in AU and Europe.
F18 USA 242
http://www.solarwind.solar
Re: footstraps can hurt! [Re: David Ingram] #271929
04/29/14 10:08 AM
04/29/14 10:08 AM
When I tried to get mine, I called Jack Young looking for the new Nacra foot straps. He sent me to the Cat House (Fair Warning: specify "sailing and catamaran" keywords when doing a Google search for The Cat House) and they filled my order. What I received had Magic Marine logos on it but was the same thing. You also might want to check with Brett Moss - he's involved with Magic Marine US now.
LandFall Navigation has them as well HERE
Re: footstraps can hurt! [Re: Dazz] #271931
04/29/14 10:18 AM
04/29/14 10:18 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
The new ahpc boats seem to have them now so Jill could probably sell you some.
Re: footstraps can hurt! [Re: bacho] #271932
04/29/14 10:22 AM
04/29/14 10:22 AM
Clermont, FL, USA
Clermont, FL, USA
She has Dakine.
F18 USA 242
Re: footstraps can hurt! [Re: David Ingram] #271933
04/29/14 10:26 AM
04/29/14 10:26 AM
She has Dakine.
I spent a lot of time trying to source those and looked at the Dakine extensively. They're really tailored to things like a windsurfing board where the board weighs significantly less than you do and they fit tighter. They also are padded more and I would assume that's for barefooted use (which also makes them a tighter fit with shoes on). I'm really happy with the light Magic Marine versions (they fit the existing Dakine bolt holes too).
Note, on those Magic Marine ones - I installed mine so the logos would face the "right/same" direction on both hulls (yeah, I know...but it's just how I am). This put one of the top velcro straps facing back and the other facing forward. The forward facing one will get blasted open by water flowing down the leeward side of the boat. You can wrap a little electrical tape around it to keep it from unvelcroing (is that a word?) but if you install them with the upper strap opening from stern to bow (and one logo upside down), you won't have that problem.
Re: footstraps can hurt! [Re: David Ingram] #271934
04/29/14 10:33 AM
04/29/14 10:33 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Riccardi had a few awhile back, so I would assume Jill WAS getting them. If you find a source let me know ,I need a pair or two also.
Isak Dinesen
E. B. White
Re: footstraps can hurt! [Re: Jake] #271935
04/29/14 10:35 AM
04/29/14 10:35 AM
Clermont, FL, USA
Clermont, FL, USA
Very nice tip! Thank you.
F18 USA 242
Re: footstraps can hurt! [Re: Jake] #271936
04/29/14 10:36 AM
04/29/14 10:36 AM
Most of the I/N 20 guys I knew ,including me , used 2 footstraps behind the beam for weight adjustment,i.e. your back foot was in one or the other depending on how bow down you were, not for both feet. I would expect that felt pretty off balance.
Isak Dinesen
E. B. White
Re: footstraps can hurt! [Re: Team_Cat_Fever] #271937
04/29/14 10:37 AM
04/29/14 10:37 AM
Clermont, FL, USA
Clermont, FL, USA
I sent Bret an email asking if he had any if he doesn't I'll see what CatHouse has.
F18 USA 242
Re: footstraps can hurt! [Re: David Ingram] #271938
04/29/14 10:42 AM
04/29/14 10:42 AM
Petten Netherlands
N
N
Petten Netherlands
Why Magic Marine?
I've since many years Da Kine straps on my windsurfboards and since three years on my cat.
They are perfect. Be sure to buy the adjustable ones.
In Holland they are the best sold trademark for footstraps.
ronald
Re: footstraps can hurt! [Re: northsea junkie] #271941
04/29/14 12:12 PM
04/29/14 12:12 PM
Why Magic Marine?
Simply put, they're too tight even with the adjustment. I can adjust them to fit but I still have to wiggle my shoe in. They are certainly comfortable and work great but I don't feel confident that I can get my foot out if something were to go horribly wrong (like what happened in the video). I'll post a picture of the ones I have now on my F18 tonight.
Re: footstraps can hurt! [Re: Jake] #271942
04/29/14 12:18 PM
04/29/14 12:18 PM
Why Magic Marine?
Flipped the 20 years ago training for a Worrell and if my foot hadn't come out of my shoe it woulda been ugly. Righted the boat and the shoe was still in the footstrap. The kind of shoes or boots plays a role in this also, but I agree with Jake the DaKines are made for bare feet and are pretty snug. Although it's what I've always used out of availability.
Isak Dinesen
E. B. White
Re: footstraps can hurt! [Re: Dazz] #271944
04/29/14 12:29 PM
04/29/14 12:29 PM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
I have the Magic Marines, got them from Todd. They work nice, but can be a bit harsh on the foot, even with a boot. I guess it's a tradeoff between ease of getting the foot in, and padding on the strap. I also like having less padding to rip/degrade etc.
USF18 Eastern Area Rep
Nacra Infusion USA 753
Re: footstraps can hurt! [Re: Dazz] #271949
04/29/14 01:40 PM
04/29/14 01:40 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I just ordered a pair from sturgis boat works. $31.xx shipped.
Bri@sturgisboatworks.com
Re: footstraps can hurt! [Re: bacho] #271950
04/29/14 01:49 PM
04/29/14 01:49 PM
That might explain it, Ricky Riccardi used to work for them.
Isak Dinesen
E. B. White
1 registered members (Seanziepop), 581 guests, and 110 spiders.
Posts267,056
