| Center Sheeting #261998 08/03/13 07:02 AM 08/03/13 07:02 AM |
Posts: 382 SE MI / NE IN | I acquired a C2 late last year with center sheeting. Looks like the same setup as in this pic: ![[Linked Image]](http://c4regatta.org/assets/banner2.jpg) (is that you John?) I'm still not sure if I like it or not. Pluses: - Sheeting angle for the crew is nice. - 8:1 purchase is responsive in light and medium air - Line management during tacks seems a bit easier. Negatives: - Difficult to uncleat in certain conditions - especially lighter air. I can probably blame several blown tacks on this. - Seems like a lot of force on the center of the tramp - is this going to cause premature failure? - Sheeting load in heavy air is pretty high. My 17yr old son who's in decent shape was dead after two races. Noticed that this has not caught on - only the A-Cats seem to do center sheeting these days. Replacing it with a more standard setup is going to kill my beer budget. Let me know what you think. | | | Re: Center Sheeting
[Re: rehmbo]
#262003 08/03/13 11:11 AM 08/03/13 11:11 AM |
Posts: 3,293 Long Beach, California | Hey Jeff - Yes, that's me and Dennis Key on a C2. I had the center sheeting on all three of my F18s. I loved it. Mine was a 9:1 and I never used a cleat - just a Ronstan ratchet block. The first time I used it, I couldn't take my eyes off the tramp. But in practice, I never had any pucker, stretch, wear or damage there, so I just quit worrying. The tramp for center sheeting should be reinforced at the point where the block attaches. AHPC uses fabric straps, but I've seen a Nacra with an eye-strap on a backing plate sewn in, too. I had my first tramp worked on to add the reinforcement, and ordered the next two boats with the option. I think it is fast. Without a cleat, I worked harder, but it made us faster as a result. It was still a lighter load than the kite - as you can see in that pic, we're double trapped and I could easily hold the sheet with one hand. Dennis never had to worry about the sheet in the tacks, and I was surprised that the block in the center of the tramp never really felt like the obstacle I thought it would be. You need consistent crew if you're going to use this setup, I think. Managing the main in a tack is a new skill for some crews, and teams will need a couple of tacks to sort out the timing. If I were buying another boat as crew, I wouldn't hesitate to add the option again. If I were a skipper and knew I didn't have steady crew, I'd probably not. It was great to break the tension on the boat after a bad race - I could look at Dennis and say, "You had ONE job." Here's the same setup on a Cap.
| | | Re: Center Sheeting
[Re: rehmbo]
#262043 08/04/13 10:06 PM 08/04/13 10:06 PM |
Posts: 3,293 Long Beach, California | Goodall taught me a great main trim mantra: half as much, twice as often.
Good luck, and stick with it if you can. Once it is working, it is like beer flavored boobies.
| | | Re: Center Sheeting
[Re: rehmbo]
#262063 08/05/13 09:06 AM 08/05/13 09:06 AM |
Posts: 932 Solomon's Island, MD | We have the stock 10:1 system on the Infusion. Unlikely to change it ($$), though I like 9:1 myself as it's less line than 10:1. For what it's worth we don't use the cleat either. Couldn't find a spot where it was easy to re-cleat and uncleat, so now it's in a spot where it's impossible to cleat going upwind but can be cleated coming in off the wire during a tack. That is how the pros do it anyway (we are NOT pros but we can try).
My question on the center sheet without a cleat:
1) How does the skipper cleat the main going downwind? 2) Is the traveler still tied/spliced to the end of the main sheet? It hard to tell in the photos. 3) Does the center block interfere with the spin sheets/crew in a wire-wire gybe?
Scorpion F18
| | | Re: Center Sheeting
[Re: rehmbo]
#262084 08/05/13 12:12 PM 08/05/13 12:12 PM |
Posts: 382 SE MI / NE IN | I can answer #2 - yes, at least in my setup, its still tied to the traveler line. For #1, I have a cleat, so obviously I use it. Good question if there's no cleat. I prefer to use the traveler downwind (especially when I'm overstood  ), so trying to manage the main sheet, traveler, and tiller ain't going to work too well. I have a hard enough time with just one of the three. As for #3, we really haven't had conditions this year for wire-wire gybing. I'm a little-bit embarrassed to admit I hadn't really thought that one through yet. Not sure there'd be enough room behind the center block for both guys to cross at the same time. I assume crew would go first and there would have to be hand pass of the spin sheet around the front of the main sheet. Let's see what JW says. | | | Re: Center Sheeting
[Re: rehmbo]
#262093 08/05/13 01:20 PM 08/05/13 01:20 PM |
Posts: 932 Solomon's Island, MD | Thanks Jeff. I assume your cleat is on the block in the middle of the boat?
I already crown my 125 lb, 5' 4" helm in the gybes, but part of the issue is the board location is pretty far aft. Maybe it isn't an issue. I like the idea of getting the mainsheet of the helms hands in the tack. That would make her job easier.
Scorpion F18
| | | Re: Center Sheeting
[Re: rehmbo]
#262098 08/05/13 02:08 PM 08/05/13 02:08 PM |
Posts: 382 SE MI / NE IN | Yes. The cleat is attached to the block. Don't have the boat with me, but I'm pretty sure its a Ronstan RF56121. Its installed loop end to the tramp. Cleat angle is fairly high so you don't accidentally engage while your out on the wire. | | | Re: Center Sheeting
[Re: rehmbo]
#262118 08/05/13 06:55 PM 08/05/13 06:55 PM |
Posts: 3,293 Long Beach, California | Hi Guys - Jeff, do you have the Adventure Wines boat? That's the only one I know of that was ordered with center sheeting and a cleat. Hell of a coincidence if it isn't Ian and Paulo's old boat (USA 222). That thing is fast. Right-click and open in a new tab or window for more detail. HERE is the link to the first event that boat was raced. Ian raced with Bobby Kleinschmit, who has been working on ETNZ for the last couple of years. There are multiple high-res shots in that album that show the center sheeting clearly. ![[Linked Image]](http://www.abyc.org/photos/abycmultihulls10-13.jpg) Obviously, because the standard center sheeting system has no cleat, the skipper hand-holds it on the run. As with the beat, not cleating forces the team to work the main much more often, which is faster. Squeezing the main in the puffs when you have the kite up is very effective. The main traveller is a gross adjustment and less effective in trimming. When we overstood the gate, Dennis would put the mainsheet in his tiller hand to keep our backstay, and drop the traveller with the other hand. It never looked like much of a headache from my perspective. I drove for a couple of years (2006-2008), and only infrequently since, and I don't recall ever having a problem dropping the traveller when needed. AFA the traveller line, I have sometimes used a separate line (tied to the mainsheet), and Trey once made me a gorgeous, tapered mainsheet that was a split-tail on the end for the traveller. We liked that line best and used it up. We just had a figure-8 knot on the traveller side to keep the car from hitting the stops. Finally, gybing: there's several different ways to run the spin sheets these days, most of which will not be a problem with the center sheeting Jeff pictured above. One of the recent (last two years?) setups that I tried and liked was the one where the spin sheet isn't spliced or tied together, but instead the ends are taken up on bungees run through the tramp. That method of rigging certainly wouldn't be in the way for the skipper or crew.
| | | Re: Center Sheeting
[Re: John Williams]
#262145 08/06/13 10:37 AM 08/06/13 10:37 AM |
Posts: 382 SE MI / NE IN | Interesting - all 3 C2s in the pic are using center sheeting. I appear to have the same stack as USA 70 - 4 on top, 4 on bottom, with a tie-off through the center of the bottom. BTW - I can see the downwind sheet management a bit as you described in your pic here As for the boat, you're close - mine is hull #224. Purchased from Dan K out of Omaha, NE. He did a nice job getting it dialed in for me  it has proven to be really quick upwind. Still working to get my downwind technique perfected though. You guys are obviously at a different level than I. I'm still well on the learning curve regarding the finer aspects of getting the best VMG out of the downwind run (but that's a whole 'nother thread). Curious about the spin sheet takeup method you mentioned. Do they cross the tramp at a diagonal, diving under the aft part of the tramp? Which grommets do you use?
| | | Re: Center Sheeting
[Re: rehmbo]
#262158 08/06/13 01:00 PM 08/06/13 01:00 PM |
Posts: 932 Solomon's Island, MD | Jeff,
I'll start another thread on the downwind VMG. We have work to do upwind in over 13kts of breeze and downwind in big waves.
Relevant to this thread, the cross the tramp spin sheet method I've seen on the Falcon and tried on the Infusion crosses the sheets on the tramp, in your case right in front of the center sheeting block. One corner goes to a grommet that is on the aft starboard side of the tramp and the other to a grommet on the aft port side of the tramp. I think on the Infusion these may be used to tie off the tramp to the boat, but I'm not using it for that purpose. From left to right, the shockchord gets tied to the starboard spin sheet on the port side of the boat, goes through the port side grommet, forward to a ring under the mast, then back aft to the starboard side grommet and then tied to the port spin sheet that is sitting on the starboard side of the boat.
I have since dumped this setup and gone back to tying the tails on my spin sheet together on the tramp with a single shock chord holding them. With the crossed setup above life was great while sailing upwind. It was not happy when we gybed, my feet ended up tangles in the spin sheet mess.
Scorpion F18
| | | Re: Center Sheeting
[Re: rehmbo]
#272184 05/05/14 07:16 AM 05/05/14 07:16 AM |
Posts: 932 Solomon's Island, MD | Hey Jeff,
Would love some detailed measurements, location is critical IMO. Yours was in a good spot, easy to access for both helm and crew.
Likely to modify our next boat for center sheeting, though I have one question left. In bigger breeze when tacking, the helm takes the main and has complete control of the boat through the tack. This frees up the crew to quickly cross the boat, and most importantly ease the jib a little to prevent getting stuck in irons. As crew, I'm a little concerned I'll have too many lines in my hands with both main and jib to make a smooth crossing??
Scorpion F18
| | | Re: Center Sheeting
[Re: rehmbo]
#272195 05/05/14 04:25 PM 05/05/14 04:25 PM |
Posts: 4,119 Northfield Mn | I always thought the crew taking the sheet made the most sense. Allows the skipper to maintain good control of the rudders and not have to worry about passing a sheet behind yourself. Especially one that doesn't have a cleat on it.
| | | Re: Center Sheeting
[Re: rehmbo]
#272246 05/08/14 08:10 AM 05/08/14 08:10 AM |
Seem to recall your boat being OK in super light air but a little spring up would help for easing the sheet.
In the tacks, it is critical to ease the jib sheet about 2" in big air w/ waves, just about the same time you pop the main sheet. This relives the pressure the jib puts on the bows and lets you drive through the tack more easily. If you don't do this, it is easy to screw a tack. Part of the reason it's more important in breeze than any other time is the amount of sheet tension on the jib is ridiculously high to trim for proper upwind sailing.
In these conditions, I suspect it would be fastest for the helm to grab the main through the tack, still very possible with center sheeting. The traveler part was annoying if I recall correctly, forcing the main to still be passed around aft of the block. Maybe running the traveler to the helms trap wire would work, or a few other creative solutions.
Scorpion F18
1,303
guests, and 36
