| Re: masts
[Re: swatter]
#272560 05/20/14 08:00 PM 05/20/14 08:00 PM |
Posts: 12,310 South Carolina | I don't think there are many people here familiar with that particular boat / mast setup. Bach had a good suggestion and there are other possibilities too. You could try to step the mast from the front of the boat (boat on the ground), step it with the mast rotated 180 degrees (possible, but you have to pay close attention to the rigging to get it rigged properly), etc. Some masts have to be stepped rotated at 90 degrees (most Nacras)....there are all sorts of possibilities.
Jake Kohl | | | Re: masts
[Re: swatter]
#272561 05/20/14 10:11 PM 05/20/14 10:11 PM |
Posts: 1,203 uk | Put the road trailer behind the boat so that the mast support is by the center of the back beam. Prop the mast up on this
| | | Re: masts
[Re: davefarmer]
#272616 05/21/14 03:35 PM 05/21/14 03:35 PM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | Look at the vid below between 2.39 and 3.00 minutes: vid with camara on the rearbeam Mast feet just rests freely against the ball on the frontbeam in the direction of the hulls and is limited sideways by the trapeze-wires fixed temporary to both sides of the frontbeam. I use no step-hinges or things like that for anti-rotating the mast! Mast is fixed by the pole. Only thing is you have to support the masttop a foot or so above the tramp. I use a simple tripod for that: the boom and two wooden side-legs.
ronald RAIDER-15 (homebuilt)
2,548
guests, and 457
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
