Best back support trapeze #273839
07/11/14 01:50 AM
07/11/14 01:50 AM
Brisbane Queensland- Australia
Q
Qb2 Offline OP
Qb2  Offline OP
Q
I have given up sailing until I can wear a trapeze harness which doesn't cause lower back pain by compressing my spine and hips. All current harness seem to use flexible materials which put compression forces on the trunk and abdomen even with spreader bars. Are there any harnesses with wide rigid back plates to spread the weight and ease pressure points? Or should I get a sailmaker to do a custom job to try to sort out my problems? There are rigid formed bosuns seats online. Has anyone used them for comfortable trapping? I don't want to reinvent the wheel if there is a real back supporting harness already out there. Suggestions?
Re: Best back support trapeze [Re: Qb2] #273845
07/11/14 06:21 AM
07/11/14 06:21 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I've found my Magic Marine to be perfect for me, I've been comfortable even doing 3hours on the one tack, yoke over head adjustable leg supports, big back plate. Took a while to get it set right but after that it's just step in
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Best back support trapeze [Re: Qb2] #273865
07/11/14 07:40 PM
07/11/14 07:40 PM
Q
Qb2 Offline OP
Qb2  Offline OP
Q
My newest harness is the Magic Marine MX2 and I lasted 2 minutes before the pain hit right on the L4,5/S1 joints. After online reading into sailing injuries etc I am looking at info on the Worrell XT, Ronstan PRO with a firm back support, Aquata Equipe XT and a UK harness from Forward Sail with its own integrated lumbar support. So there appear to be options there. Getting to trial those apart from the Ronstan here in Oz may be a bit hard but investigating further. First off am getting a weightlifters back brace to see if that helps.
Re: Best back support trapeze [Re: Qb2] #273866
07/11/14 10:06 PM
07/11/14 10:06 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
I have an Aquata Worrell and love it.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Best back support trapeze [Re: Qb2] #273872
07/12/14 10:00 AM
07/12/14 10:00 AM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
A shorter trapeze wire also can help.
On the wire, the measure of "sitting" in your harness versus hanging straight out can be a very critical point for the load on your spinal joints.
ronald
RAIDER-15 (homebuilt)
Re: Best back support trapeze [Re: Qb2] #273880
07/13/14 06:52 PM
07/13/14 06:52 PM
Q
Qb2 Offline OP
Qb2  Offline OP
Q
Sitting in the harness was just painfull made worse when i leant back to take the pressure on my upper back. That really shifted the pain centre to the hips through compression. Sitting behind a desk for 30 years hasn't helped so core strength exercises are the go and i have my work cut out for me.
Re: Best back support trapeze [Re: Qb2] #273889
07/14/14 05:19 AM
07/14/14 05:19 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
I suffered a work-place accident a couple of years ago (catching a couple of G sized oxy cylinders has that effect) it resulted in a stuffed back and as a result my car racing had to cease, which was a good thing as it turned out because it brought me back to sailing wink
Luckily I have a great Dr. (a very cute SHE Dr. too grin ) who insisted on me walking & swimming every day... slow 4x4 off-road driving also helped in many suprising ways as I improved....
Walking from one side of the room to the other was initally a huge challenge eek
It took me 3 weeks of short walks to be able to get to the letter box and back in one shot
At week 8 after the accident I did my first full 1 kilometer walk ( then called for a taxi to get home sick )
I now walk ~5k's a day
Swimming was much easier on the body, it was more a case of just time in the pool than doing laps that helped
grin
My back is now in the best "expected" condition it can be and I dont suffer much from the injury nowdays at all, mind you, I take every step possible NOT to repeat the experiance
smile
Kingy
& now Mosquitos #1182 & #1740
Re: Best back support trapeze [Re: Qb2] #273892
07/14/14 07:45 AM
07/14/14 07:45 AM
Q
Qb2 Offline OP
Qb2  Offline OP
Q
Pirate can you get out on trapeze or is that pushing your back too far?
Surgeons told me in 09 I had arthritic bone spurs causing debilitating back pain. Recently I opted for spinal fusion to reduce the pain, Luckily while dragging my cat up the beach I met a sailor who was a pain management specialist. He diagnosed I have one leg 9mm shorter than the other. Who Knew? Now physio exercises, swimming, walking mean I rarely hit the pills. I thought I was in vastly improved until the harness hit back. Seems I have a lot of work to do.
Re: Best back support trapeze [Re: Qb2] #273895
07/14/14 11:35 AM
07/14/14 11:35 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
I've been extremely pleased with the back support and wide spreader in my Neil Pryde harness (I have a slightly older version). Full disclosure - never done any distance racing with it (yet).
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Best back support trapeze [Re: Qb2] #273927
07/15/14 06:36 PM
07/15/14 06:36 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Originally Posted by Qb2
Pirate can you get out on trapeze or is that pushing your back too far? ......
I certainly don't get on the trap anywhere near as fast as most others do...... takes me a bit longer blush
My injury was lower back so I altered a few things to make my life easier to get hooked on as well as getting out on the trap and back in...
1/
added thigh straps to the harness, this took away the 'crutch load' which was placing direct pressure on my spine, the leg straps take away the load off my spine and put it more into my hips.
2/
the harness hook was moved up to sit just above my belly-button, this took the lateral loading of the harness up higher on my back so the pressure of the harness is now above the damaged part of my spine.... the pressure is now on my rib cage whereas it was far lower prior to the harness mods.
3/
the dog-bone ring was moved higher up the trap wire. I actually have to do a little body 'hop' in order to hook on, once hooked on the ring stays on the hook as I move out over the side, once out on the trap I can then lower myself down via the trap's pulley system..... out on the trap I have 'weight' mainly on my thigh/hip area and mid rib area, there's hardly any load on my lower back
smile
Like everything it was a bit of trial & error with my current setup, its not perfect by any means but its far more friendly than it was to start with, I've also spent time doing dry runs or 'land practice' to sort out when and where I get into trouble pain wise.... and subsquently the learning curve on how to avoid that pain
wink
practice makes perfect
smile
Kingy
Re: Best back support trapeze [Re: Pirate] #273939
07/16/14 01:07 AM
07/16/14 01:07 AM
Q
Qb2 Offline OP
Qb2  Offline OP
Q
Excellent. Great options to trial. thanks.
0 registered members (), 448 guests, and 31 spiders.
