| Slow in light wind #273896 07/14/14 11:49 AM 07/14/14 11:49 AM |
Posts: 57 Minneapolis | Hello, all I am relatively new to racing. I just got my Nacra F16. I find that when racing in light wind I am extremely slow. I keep thinking I am over sheeting and over pointing, but I am not so sure of that any more. I'd really appreciate some tips on how to improve boat speed. (I am sitting far forward, I allow the mast to rotate most of the way out) I am sure there is more I can do.
thanks for the advice.
Dave Foster Minneapolis Nacra F16
| | | Re: Slow in light wind
[Re: Mpls_Nacra]
#273909 07/14/14 10:15 PM 07/14/14 10:15 PM | Scarecrow
| Scarecrow
Unregistered | Don't let your rotation out upwind. Going upwind in light wind is all about efficiency. Read the first part of this this and set your mast so that it is working properly. Letting out the rotation is just adding drag. With a modern wing mast, rotation is the last place you should look (after cunningham and traveller etc) to changing power it should always be set so the luff tell tails are working. Once moving in really light wind your apparent wind will be a long way forward so if anything you need less rotation not more. Also don't be afraid to actively adjust this setting in the light. When you come out of a tack and have all but stopped the apparent wind will be at or above 45 degrees, as the boat accelerates it will swing forward to around 20-25 degrees so your mast setting will need to be changed to suit. | | | Re: Slow in light wind
[Re: Mpls_Nacra]
#273917 07/15/14 10:18 AM 07/15/14 10:18 AM |
Posts: 57 Minneapolis | Thanks for the info, I cant wait to try it out. I'll let you know.
[Re: Mpls_Nacra]
#273952 07/16/14 10:31 AM 07/16/14 10:31 AM |
Posts: 57 Minneapolis | Karl, I am planning on going to broken rudder. possibly one other event.
are you coming out to MYC again any time soon?
[Re: Mpls_Nacra]
#273953 07/16/14 10:31 AM 07/16/14 10:31 AM |
[Re: Mpls_Nacra]
#273970 07/16/14 10:22 PM 07/16/14 10:22 PM |
Posts: 4,119 Northfield Mn | It's usually so it opens the leech. Otherwise it's hooking severely at the top. You really aren't flattening it much because mast rotation will remain the same, and you aren't sheeting very hard.
I'll probably be up there at some point, no plans to store my boat up there this summer though
[Re: Mpls_Nacra]
#274014 07/18/14 11:33 AM 07/18/14 11:33 AM |
Posts: 57 Minneapolis | Thanks again everyone, What about diamond wires. where should the tension be light, medium and heavy wind. ( I am on the heaver side of the scale)
thx DF
[Re: Mpls_Nacra]
#274016 07/18/14 03:47 PM 07/18/14 03:47 PM |
Posts: 4,119 Northfield Mn | I adjust the diamonds a lot of times between races. If I feel under powered I loosen them, if I was maxing out the downhaul a lot I'll add tension.
[Re: Mpls_Nacra]
#274054 07/21/14 09:02 AM 07/21/14 09:02 AM |
Posts: 5,590 Naples, FL | I find that when racing in light wind I am extremely slow. When you say "Light Wind", can you give a range (windspeed or Beaufort)? If memory serves, there was some discussion about laminar vs. turbulent flow breaking at about 8mph and the difference in AWA between surface and top of mast. Sail settings and efficiency changed based on those parameters
[Re: Mpls_Nacra]
#274100 07/23/14 01:05 PM 07/23/14 01:05 PM |
Posts: 57 Minneapolis | Jay, I would say 7 mph and under.
thx DF
1,007
guests, and 40
