what is a good 1st beachcat to buy for the beginning racer? #273976
07/17/14 07:21 AM
07/17/14 07:21 AM
C
Chris Ross Offline OP
C
I would like to buy a beachcat for the purpose of racing it in CRAW (Catamaran racing association of Wisconsin) events. They run a handicap system so basically any beachcat would work. I have been racing sailboats all of my life - I started with optis, moved on to scows, and keelboats. Then I bought a Gougeon 32 catamaran 3 years ago. I have been racing the cat against monohulls in mixed fleet racing, and I realized that I haven't improved much in the last couple of years. I still have a long long way to go to be competitive with the G32 in a multihull fleet. So, my plan is to buy a beachcat and race other beachcats with the hope I would improve more quickly as a multihull racer. I weigh about 170lbs, and would like a cat that I could race solo, but could also race with a crew if I could find someone interested. What type of cat should I look for?
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273977
07/17/14 07:30 AM
07/17/14 07:30 AM
Madison WI
ewindsail Offline
ewindsail  Offline
Madison WI
CRAW has a regatta August 2-3 in Green Bay. Check out the various types of boats being sailed. I sail a F16 and at 175 like the ability to single hand as well as have crew if I want.
Capt. Chaos
CRAW member
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273978
07/17/14 07:32 AM
07/17/14 07:32 AM
The best piece of advice that I have to offer is to get a boat that is actively being raced in your area in a sizable fleet. I raced as an x-boat (the odd boat) for several years and it wasn't until I bought a boat and assimilated with one of the more active fleets in our area that I really started to learn and improve at a rapid rate.
You have a lot of options at 170lbs.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Jake] #273980
07/17/14 08:50 AM
07/17/14 08:50 AM
If you own a boat that has a nice fleet nearby it improves your skills faster and a lot cheaper than having to travel extensively to find regattas with boats of your type.
Buying a boat you can "grow into" is another good idea. Of course, almost any boat fits this category since they are all easy to learn but difficult to master.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273983
07/17/14 09:42 AM
07/17/14 09:42 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
X2 on Jake
I did the handicap thing on an i20 for a couple years, it's not so great after a while IMO. Our race results suffered some after moving to an F18, but we have certainly become better sailors from it.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273988
07/17/14 12:44 PM
07/17/14 12:44 PM
What kind of experience do you have? That's the biggest question I think. If you are really green and just getting into sailing, the more complicated the boat the more likely you are to be turned off by the sport. Not to scare you off, but the modern boats power quickly too, and if you don't know how to manage that power they are a handful at best. Most everyone on here started with a H16, they're durable, cheap used, and easy to unload if you want to move onto something different. BUT, if you're coming from another spinnaker boat, then the transition wouldn't be all that hard.
CRAW is made up mostly of F16's and F18's. It's a pretty even split with a few other boats here and there. They race on handicap, but the difference between the two main classes is pretty minimal. It's basically boat for boat. No matter what kind of catamaran, CRAW would welcome you. Don't think they'd turn you away if you showed up with a Hobie 14 or something.
I have a 2012 Viper I would like to sell if you are interested.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273989
07/17/14 12:50 PM
07/17/14 12:50 PM
Here you go Chris: http://www.formula16.net/
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273993
07/17/14 05:06 PM
07/17/14 05:06 PM
C
C
Thanks for the replies. I'm planning to visit the green bay regatta in august, so I can see f16s and f18s in action. I have spinnaker experience with the G32, and was hoping to step into a boat with a spinnaker right away.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273994
07/17/14 05:19 PM
07/17/14 05:19 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Buy a very well set up boat with a very good spinnaker and you will master it a lot quicker
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273995
07/17/14 05:50 PM
07/17/14 05:50 PM
Chris, I can try and get you out on the water Friday if you like.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273998
07/17/14 07:53 PM
07/17/14 07:53 PM
C
C
karl,
That would be great! My email is laser28 at mac dot com. I can send you my cell number once I hear from you.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #273999
07/17/14 08:19 PM
07/17/14 08:19 PM
M
MN3
MN3
M
whats your budget?
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #274006
07/18/14 05:50 AM
07/18/14 05:50 AM
C
C
Budget depends on what I would need to spend in order to get a "club competitive" cat that is for the most part squared away. I have a feeling I will be at the back of the pack for a while, and I would like my first cat to be good enough to win races if a good sailor was sailing it. Basically I don't want the boat to be the reason I finish last smile A new NacraF20c or a new flying phantom are out of bounds, but a F16 or F18 that's a couple of years old looks doable.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #274007
07/18/14 07:00 AM
07/18/14 07:00 AM
You have the right attitude, grasshopper. Get the boat out of the equation. If you don't, you'll blame it (instead of the real reason for being slow) every time.
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #274008
07/18/14 07:03 AM
07/18/14 07:03 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Probably more F18's on the market than F16. You'll need a regular crew for the 18 though.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #274009
07/18/14 07:05 AM
07/18/14 07:05 AM
M
MN3
MN3
M
that's a great place to be able to start from. Many if not most are limited with a low starting budget.
That being the case, F16 sounds like the right boat. mostly because it is a 1 or 2 person cat/racer
Re: what is a good 1st beachcat to buy for the beginning racer? [Re: Chris Ross] #274026
07/19/14 01:08 AM
07/19/14 01:08 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
I'm getting rid of my 2013 boat to make space for the new one. PM sent.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
0 registered members (), 2,710 guests, and 482 spiders.
Yesterday at 10:10 AM
