Re: enclosed trailer [Re: JrShrekster] #276110
11/06/14 01:10 AM
11/06/14 01:10 AM
JrShrekster Offline OP
Not getting too much help here. Enclosed trailers are up to 8.5' (102"). Yes, I was planning on disassembling the boats to get in the trailer. Do you all realize that the f18 is 8.5 ft wide! Been looking on CL, finding 24' trailers from $4000 to $7000, used, and in good condition. What I'm looking for is some help with how people are securing the boats in the trailer. I know there are ones out there, seen them, but at the time did not consider, so would like to see/hear what people are doing.
Thanks.
Re: enclosed trailer [Re: JrShrekster] #276115
11/06/14 07:20 AM
11/06/14 07:20 AM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
I will see if I can find some details of the trailer we used for LA/Sarasota. It was fully enclosed, 6 boats inside, masts on top. The trailer was owned by Chris Prentice, and El Presidente Riccardi was involved as well. I think there are some pictures floating around on Facebook.
USF18 Eastern Area Rep
Nacra Infusion USA 753
Re: enclosed trailer [Re: JrShrekster] #276118
11/06/14 09:07 AM
11/06/14 09:07 AM
Thanks.
E-Tracking. Mount three levels of strips horizontally on each side. They make sockets that go into the E-Track that you can put a 4x4 in making a horizontal beam from side to side on the trailer. The ones in the link from McMaster are for a 2x4, but I know I've seen them for 4x4 lumber as well. Just space the brackets out so they line up with the beam sockets, and set the hulls upside down on the lumber and strap/tie them down. You'll have to likely clump same brands together so the beam socket spacing is all the same.
You should be able to get three levels in there. Depends on the size of the sidewall on the trailer, most are about 72" though. It'll be snug.
Beware of trailers. There is a lot of cheap, horrible, shitty trailers out there. Featherlite is a good brand, as is Sundowner. Like any tool, spending less gets you nowhere most of the time. You also need a decent tow rig if you're looking at a 24' trailer. I wouldn't do it with anything less than a 3/4 ton. Even then I'd add the stabilizer/weight distribution bars. 24' is a big butt trailer for a bumper tow. It's not so much the weight that kills you, it's the windage pushing you around in a nasty crosswind.
As for beams, and the rest of the crap, I'd probably pad and strap the beams vertically to the wall, wrap each in a moving blanket and stretch wrap it. A ladder rack would work fine for masts on the roof. Cat-Trax are always the biggest hassle though, dis-assembling them blows. The rest packs pretty easily.
Re: enclosed trailer [Re: JrShrekster] #276127
11/06/14 11:42 AM
11/06/14 11:42 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Karl,
Often thought about making the toy hauler you describe. Maybe a little bit smaller. it wouldn't even really be that expensive in the grand scheme of things. Biggest roadblock to all of that it was a hardly any of all the regatta destinations have a place to park/turn around such a rig.
Re: enclosed trailer [Re: JrShrekster] #276128
11/06/14 11:47 AM
11/06/14 11:47 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
That, and the fact you would have to go inside at the Taco Bell, instead of the drive thru. Seems reasonable. smile
Philip
USA #1006
Re: enclosed trailer [Re: bacho] #276132
11/06/14 02:09 PM
11/06/14 02:09 PM
Originally Posted by bacho
Karl,
Maneuverability is hassle with that much rig. The trailer is damn near semi size.
It makes more sense to me than doing a coach/bus type RV though and hooking the boat on. You get to where you're going and you are a pedestrian. With a big rv toyhauler, you drop the trailer, and the pull truck is your wheels. A two ton doesn't have any bigger foot print than a four door, long box pickup.
Re: enclosed trailer [Re: JrShrekster] #276155
11/08/14 12:01 AM
11/08/14 12:01 AM
Thanks Jeff. I'll touch base with you on the side.
TC
0 registered members (), 22,041 guests, and 407 spiders.
Most Online23,788
57 minutes ago
