Bow tang repair causing rust staining down hull? #276211
11/12/14 03:37 PM
11/12/14 03:37 PM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Hi all,
a couple of years ago I repaired a bow tang on the port bow of my Nacra 5.2. It was loose and showing some cracking (probably from inwards directed load and years of neglect). I used epoxy and had the lids off so I could structurally re-seat the tang and rebuild the damaged layup. I know it is 100% sealed in and no water gets through there to the inside.
What puzzles me is that the repair side now has a clearly visible brown rust streak running down the hull while the unaltered side shows no staining at all.
Could there be a compatibility issue with the epoxy I used and the stainless tang? I can't think of anything else. The epoxy feels tough, it has hardened well and even supports a thick layer of (polyester!) gel-coat to this day.
Should I just clean it up periodically with some acid or is there a really good way to seal the rusty tang and keep it from rusting all over my boat?
Thanks in advance for any advice,
Dennis
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276217
11/12/14 07:37 PM
11/12/14 07:37 PM
California
mmiller Offline
mmiller  Offline
California
Did you drill or Tap threads... add any new hardware or fasteners... weld? anything? Tools can leave bits of carbon and that rusts off the stainless. Just cosmetic though.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276223
11/13/14 08:38 AM
11/13/14 08:38 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Hmmm. I did file and sand the tang quite aggressively to clean it up and to give the epoxy something to key into...
That could well be all there is to it!
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276225
11/13/14 09:51 AM
11/13/14 09:51 AM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
I have the same experience. With all the stainless bolts and plates of my hulls. I've sanded everything also in the idea of cleaning and finding good connecting with the epoxy where necessary. Like you used to do between layers laminate and glueing things on and with epoxy.
Well, the rust gives the cat a sturdy used look.
ronald
RAIDER-15 (homebuilt)
Re: Bow tang repair causing rust staining down hull? [Re: northsea junkie] #276226
11/13/14 10:25 AM
11/13/14 10:25 AM
Did you use any carbon fiber in your repair? It can cause stainless steel to rust.
Re: Bow tang repair causing rust staining down hull? [Re: Jake] #276228
11/13/14 11:38 AM
11/13/14 11:38 AM
Petten Netherlands
N
N
Petten Netherlands
Jake, I cannot answer for Dennis, but I used, besides glass and kevlar, at least 2 layers of carbon for my hull skin-laminate.
And on the places where bolts came through even double or triple. (My hulls are not hollow,but have a solid foamcore! So bolts are fixed and glued from inside)
So, your remark is spot on. I wondered already a few years ago where the rust came from. It looked like from inside, because painting it over with 2-C PU paint didn't help at all.
ronald
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276232
11/13/14 01:45 PM
11/13/14 01:45 PM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
No, I didn't use any carbon in the repair, I'd be more worried if I did...
I kind of like the war-torn "Mad Max" look though, it suits my cat well and beats waxing and polishing every year. Oh the joys of an old boat. That and "screw the class-rules"!
Dennis
Re: Bow tang repair causing rust staining down hull? [Re: northsea junkie] #276233
11/13/14 04:29 PM
11/13/14 04:29 PM
Here's a quick reference on the Galvanic Material Series. Carbon Fiber (Graphite) is at the very bottom.
http://www.corrosionpedia.com/2/140...ies-galvanic-compatibility-and-corrosion
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276235
11/14/14 03:28 AM
11/14/14 03:28 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Aha, its probably the platinum D shackles I fitted then... ;-)
I remember using graphite rods for an experiment in a science fair at school a long time ago. The teacher wouldn't give us platinum electrodes...
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276240
11/14/14 10:12 AM
11/14/14 10:12 AM
M
MN3
MN3
M
my next band will be named
"Galvanic Corrosion and the Sacrificial Anode"
or Gcatsa for short
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276243
11/14/14 12:27 PM
11/14/14 12:27 PM
brucat Offline
brucat  Offline
Can't say that I'd have a huge comfort level seeing rust coming from a component responsible for keeping my mast upright. Just sayin...
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276252
11/15/14 03:15 AM
11/15/14 03:15 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Guess I'll just have to just clean it up and see whether there is any more staining or not. There isn't room to add more epoxy in there, maybe some WD40 though...
I'll also check to see if it isn't being caused by any of the shackles or other fittings I have attached there rusting due to them perhaps being made of dissimilar Stainless steel types. The staining might be coming from higher up and leaking down.
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276277
11/17/14 04:18 PM
11/17/14 04:18 PM
California
mmiller Offline
mmiller  Offline
California
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Bow tang repair causing rust staining down hull? [Re: DennisMe] #276286
11/18/14 08:59 AM
11/18/14 08:59 AM
M
MN3
MN3
M
tef-gel is my product of choice
0 registered members (), 2,582 guests, and 492 spiders.
Yesterday at 10:10 AM
