| Re: Loos gauge
[Re: Arjan13]
#276605 12/08/14 09:45 AM 12/08/14 09:45 AM |
Posts: 554 Boston, Ma | I would absolutely get a loos gauge. We use ours in a couple ways.
1. To set our tuning marks for diamond tension. We use marks on the mast and diamond wires to keep track of things on the water, but the gauge is important to make sure everything is calibrated.
2. To check tension on sidestays. We don't have sta-masters so this is a rather gross setting, but we like to make sure we are in the correct range.
USF18 Eastern Area Rep Nacra Infusion USA 753
| | | Re: Loos gauge
[Re: Arjan13]
#276606 12/08/14 09:52 AM 12/08/14 09:52 AM |
Posts: 774 Greenville SC | I use one, and I think its a benefit. On my boat i set the diamonds to a guess of what the conditions might be. I think that it makes a big difference on my boat.
I also question the accuracy of the loose gauge, however i think what is most important is that it reads the same every time. I think that you should look at the tuning guide for a guideline but come up with your own numbers overtime. With that in mind I think it's important to use one gauge on your boat and not use multiple ones. Find out what works for you and take notes, The gauge will help you repeat the same settings when you want to.
I use the Harken rigtune. several friends have put their loos gauges on my boat to compare and seen similar tension numbers. However one guy put his device on my boat and it read several hundred pounds differently, if I had used his gauge one time for my settings, it would have been far different from what I was expecting.
| | | Re: Loos gauge
[Re: Arjan13]
#276607 12/08/14 10:18 AM 12/08/14 10:18 AM |
Posts: 1,121 Eastern NC, USA | If nothing else, it will allow you to set the boat up the same way each time. Over time, you will get a series of settings for your boat/weight/sails that match the weather conditions. This tool will ensure that you tune the boat to the same setting each time out (even if they are different from the generic "tuning specs").
Tom | | | Re: Loos gauge
[Re: Arjan13]
#276609 12/08/14 02:00 PM 12/08/14 02:00 PM |
Posts: 1,403 | I have been using one for years... Regarding the setting of the diamond wires.... I got recommended benchmarks from the person that made my mainsail... They gave me a few settings depending on the conditions. I just took the middle setting and went from there... As for them being accurate, all I can say is that I saw a Loos gauge in a aircraft mechanics tool box that he used for light aircraft rigging. I would say they are pretty much "close enough for government work." Note, this is all they do; that is build tools for cable/wire rope industry. I think they have it figured out. You don't have to buy one... I always lend mine out to fellow sailors and collaborate on settings etc... Also, if I could recommend, you may want to upgrade your diamond wires... The Inter 18 and Nacra F-18 used 1/8" here in the US and the recommended tensions/setting from my sail maker was pushing the limits of the cable... Loos recommended tension at no more than 25% of rated breaking strength. I upgraded mine to a 5/32 and was able to "honk it down" with plenty of room before it maxed out.. Here is some info from their website... http://loosnaples.com/how-to-use-pt-series-tension-gauges
| | | Re: Loos gauge
[Re: Ventucky Red]
#276626 12/09/14 02:01 PM 12/09/14 02:01 PM |
Joined: Jun 2012 Posts: 97 The Netherlands Arjan13 OP
Posts: 97 The Netherlands | Thank you all for your input, as always it is helpfull again. Hi ventucky red, thanks for your input on wire size. I have no clue which size it is on our boat?? But looking at the available sizes on the gauges, does anybody think the wire could be thicker than 4 mm? (5/32) Your link doesn't seem to work? If we go for it, we would go for this tool: I think this one is ok? And a little afraid to ask, but: would anyone have any settings for the Inter 18?
| | | Re: Loos gauge
[Re: Arjan13]
#276665 12/12/14 05:05 PM 12/12/14 05:05 PM |
Posts: 1,403 | And a little afraid to ask, but: would anyone have any settings for the Inter 18?
I would say a good starting point would to add tension until you get about an inch of pre-bend in the mast... This should help you out http://www.working-the-sails.com/masts_and_booms.html | | | Re: Loos gauge
[Re: Arjan13]
#276682 12/13/14 09:04 PM 12/13/14 09:04 PM |
Posts: 2,844 42.904444 N; 88.008586 W | These links above are for general, mono masts, Scows are pictured in the background.
Does your cat have an actual 'backstay'? Not the shrouds, or mainsheet- an actual backstay?
F-18 Infusion #626- SOLD it!
| | | Re: Loos gauge
[Re: Todd_Sails]
#276687 12/14/14 09:02 AM 12/14/14 09:02 AM |
Posts: 1,403 | These links above are for general, mono masts, Scows are pictured in the background.
Does your cat have an actual 'backstay'? Not the shrouds, or mainsheet- an actual backstay? The intent was to show him how to measure the pre-bend for his mast. Is that any different?
| | | Re: Loos gauge
[Re: Arjan13]
#276843 12/30/14 09:49 AM 12/30/14 09:49 AM |
Posts: 12,310 South Carolina | Various Loos gauges have different scales for their numbers. It is useful to use the scale on the gauge to convert those into Kg or Lbs for the sake of discussion.
Jake Kohl | | | Re: Loos gauge
[Re: stampede]
#276954 01/12/15 10:39 AM 01/12/15 10:39 AM |
Posts: 5,590 Naples, FL | Good point.
With today's sail materials (with little or no stretch), how much would changes to rig settings benefit the sail shape?
I was talking to Lin (North Sails) about the 3-Dl/3-Di moulded sailshape and what, if any, changes to pre-bend or even downhaul might have (other than to attain proper sail shape initially). I mean, if you crank a 16:1 downhaul, how does it flatten the sail if there's no flex/stretch in the material? Does it just bend the mast?
| | | Re: Loos gauge
[Re: Arjan13]
#277011 01/14/15 03:52 PM 01/14/15 03:52 PM | Scarecrow
| Scarecrow
Unregistered | Bending the mast is exactly what a modern cat downhaul does, look at some of the A-class sails and you'll see a heap of fibre running up the luff. | | | Re: Loos gauge
[Re: ]
#277013 01/14/15 03:59 PM 01/14/15 03:59 PM |
Posts: 5,590 Naples, FL | So if you don't have a mast with a whole lot of flex (think the old N20 mast), and you're using modern non-stretch material on the main, you're pretty much not going to change the shape much with your sail controls (downhaul, outhaul)?
| | | Re: Loos gauge
[Re: waterbug_wpb]
#277021 01/14/15 06:46 PM 01/14/15 06:46 PM |
Posts: 12,310 South Carolina | The I20 mast was capable of some pretty incredible bending...particularly at the top. I remember stepping back on one for the first time in a while after sailing F18 regularly...I couldn't stand to look up at the top of the I20 rig because the amount of bend bothered me so much.
Jake Kohl | | |
4,857
guests, and 1,054
