Page 11 of 19 1 2 9 10 11 12 13 18 19
Re: F85SR Concept Boat [Re: Rolf_Nilsen] #275445
09/17/14 05:20 AM
09/17/14 05:20 AM
phill Offline OP
phill  Offline OP
Rolf,
I forgot to take before pics. There is around 64 hours work in each one.
I hope to get back to the boat now.
Re: F85SR Concept Boat [Re: phill] #275633
09/29/14 05:14 AM
09/29/14 05:14 AM
phill Offline OP
phill  Offline OP
I'm finally back working on the F85.
After some laminating I managed to cut out the centre of the forward "Central Mounting Module" today.
At last I can work in the front section of the main hull without climbing in through the forward hatch.
Re: F85SR Concept Boat [Re: phill] #276014
11/01/14 01:00 AM
11/01/14 01:00 AM
phill Offline OP
phill  Offline OP
Cutting out the centre of the CMM just leads to more work in that area. But I don't have to climb in the fwd hatch anymore to do it now. The pics will tell the story.
It turns out the section I cut out of the CMM was big enough to make the cover panels.
flange formwork.jpg (1294 downloads)
Re: F85SR Concept Boat [Re: phill] #276015
11/01/14 01:13 AM
11/01/14 01:13 AM
phill Offline OP
phill  Offline OP
Still more work in this area.
Formwork is required to build a glass flange.
The Glass flange is created so Uni can be laminated over it.
In this case I used Uni Carbon over the flange.
This pretty much concludes work in this area for a while.
I have made 4 little cubbie holes, two either side. So with a crew of 4 each person has a place for valuables while sailing
or other items like a torch that one may want to keep at hand while cruising with my better half.
fwd flange formwork.jpg (1239 downloads)
fwd flange.jpg (1274 downloads)
Fwd carbon Flange.jpg (1241 downloads)
Re: F85SR Concept Boat [Re: phill] #276669
12/12/14 09:42 PM
12/12/14 09:42 PM
phill Offline OP
phill  Offline OP
I'm currently working on the outside of the main hull.
Starting at the bow I installed the carbon socket for the spinnaker pole and fore stay.
Main the anchor well hatch rim and glassed it to the top of the deck with some 400gm B/D.
Then I did the fairing needed for the the fwd hatch.
anchor well rim lr.jpg (1052 downloads)
spi pole socket.jpg (1048 downloads)
fwd hatch.jpg (1044 downloads)
Re: F85SR Concept Boat [Re: phill] #276679
12/13/14 08:16 PM
12/13/14 08:16 PM
phill Offline OP
phill  Offline OP
The glass tube to take the forward net has been glued and glassed to the foredeck. I have cut a slot thru the hull under the tube for the fwd 200mm. This allowed me to take 2 layers of 400gm glass over the top of the deck around the tube and to the under side of the deck. Now any load will be transferred to the deck and not trying to delaminate the hull. The slot was filled and glassed over on the inside of the anchor well and then also covered in 2 layers of glass as the tube was glass over it's full length. I have designed a fitting that will insert in the glass tube to take the dyneema line the fwd net will be laced to hence the need to strengthen the end section of the tube.
I have made up a fairing for the fwd flat edge of the fwd cmm.
This will be faired into the hull further when the mainhull is faired for painting later.
fwd net tube lr.jpg (1008 downloads)
fwd cmm fairing lr.jpg (1016 downloads)
Re: F85SR Concept Boat [Re: phill] #276816
12/25/14 05:22 AM
12/25/14 05:22 AM
phill Offline OP
phill  Offline OP
I had some laminating to do between the rear beam mount (CMM) and the **** floor.
Normally this is probably just done by kneeling down in the ****.
A few days earlier I came off my bike again.
At least I didn't break my collar bone this time, but with cracked ribs and no skin on both my knees kneeling
to do it this way would be an adventure in pain that I could do without.
The boat was winched onto its side enabling me to do the work sitting on a chair next to it.
Re: F85SR Concept Boat [Re: phill] #276820
12/25/14 10:37 PM
12/25/14 10:37 PM
phill Offline OP
phill  Offline OP
I had some laminating to do around the main beam bulkhead on the underside of the cabin roof.
Mark came around to help roll the hull over for this. One person winding a winch out and one winding a winch in and hey presto its done.
I supported the hull with a couple of out of date gas bottles under the main beam pads and a plank and ladders at the rear.
Then I could just roll under on an office chair and do the work while seated through the forward hatch. Very easy and comfortable.
I think I'll do this when it comes to painting the underside of the cabin roof too.
Here are some pics of the setup.
main hull flipped.jpg (928 downloads)
flipped 2.jpg (929 downloads)
flipped 3.jpg (936 downloads)
Re: F85SR Concept Boat [Re: phill] #277489
02/08/15 03:54 AM
02/08/15 03:54 AM
phill Offline OP
phill  Offline OP
It has been around 6 weeks since my last update.
In the interim I have managed to get a few things done.
I've made the carbon beam for the traveler.
I've installed it just behind the CMM.
Quite a bit of thought went into its positioning as a part of how the carbon mast and boom are going to work.
I finally decided against roller furling. (BTW:-I hope to take delivery of the carbon mast in a couple of weeks.)
I had already purchased the traveler when a local chandlery was going bust.
The only problem being I couldn't source M6 bolts long enough to attach it to the carbon beam.
Instead I bought the longest M6 countersunk bolts that I could source and some M10 hex head bolts.
I put the M10 in the lathe , cut the treads off and bored a hole right through them and tapped an
M6 thread. I get around 20mm of thread engagement which is more than enough.
I've made the seat side panels and like the carbon traveller beam and most other things all under a vacuum.
I kept the cut outs in the side panels and made doors. I was quite surprised at how heavy
the stainless hinges are for 6 doors. I think I'll replace the stainless hinges for white plastic ones that I have
managed to source locally. If I decide I don't like the doors I will just take them off.
side panels 2.jpg (735 downloads)
side panels 3.jpg (751 downloads)
Traveller Bolts.jpg (746 downloads)
Re: F85SR Concept Boat [Re: phill] #277491
02/08/15 04:06 AM
02/08/15 04:06 AM
phill Offline OP
phill  Offline OP
I have installed the port seat side panels and was taping in the stbd side earlier today.
I looked at sourcing the watertight hatches required to house the emergency gear, EPIRB flares etc but
couldn't source the ones I wanted in the size I wanted so I made my own.
Here is a pic of the hatch to be accessed from inside the ****.
Below is the hatch that would be accessed from the nets if the boat has flipped.
Once the seals have been installed they will both be perfectly flush so I'll paint the cylinder the "T"
handle is in red for contrast so it can be easily found.
Over the next couple of days I hope to flip the main hull upside down and elevate it with the winch system
sufficiently that I can either sit or stand beneath and start the internal taping of the installed seat panels.
side panels 6.jpg (734 downloads)
side panels 4.jpg (712 downloads)
side panels 5.jpg (730 downloads)
Re: F85SR Concept Boat [Re: phill] #277605
02/15/15 02:29 PM
02/15/15 02:29 PM
Wayne Gorrie Offline
Hi Phil
I'm assuming you bought your mast from C Tech in NZ. I've been in touch with them. I'd be interested to know what you think when it arrives. Racing Mail OrderBride to Alaska this June in the R2AK. She rows really well!
Wayne
Re: F85SR Concept Boat [Re: Wayne Gorrie] #277606
02/15/15 03:59 PM
02/15/15 03:59 PM
phill Offline OP
phill  Offline OP
Wayne,
That is correct.
It is scheduled to be shipped tomorrow so I would think that I'd have it within the next couple of weeks.
Re: F85SR Concept Boat [Re: phill] #277652
02/19/15 12:37 AM
02/19/15 12:37 AM
Try Flying Offline
Try Flying  Offline
Wayne just checking out that R2AK ...wow awesome idea. That's another one for my bucket list like the everglades challenge.
Is a F85 eligable? would have thought it would be just small boats...not read the SA's yet.
Re: F85SR Concept Boat [Re: Try Flying] #277665
02/19/15 09:04 PM
02/19/15 09:04 PM
phill Offline OP
phill  Offline OP
I'm currently making the daggerboard case. This should have been done and installed before the main hull halves were joined
but I wanted to experiment with the cabin space before committing to the dagger board.
Having mocked up the inside with both the C/B and D/B I have decided the space actually feels more open with the D/B.
Go figure as I really didn't think this would be the outcome.
So I have made the D/B mould and made both sides. Weighing all that went in and out I got a 43% resin content.
The weight of the stbd side is 3.8kg and the port side came out at 4.2kg.
The port side is a little heavier because of the extra glass that goes into it to reinforce the channel for the pull up/down lines.
Below are pics of the port side just before and just after demoulding.
db before demoulding.jpg (1014 downloads)
db demoulded1.jpg (1026 downloads)
Re: F85SR Concept Boat [Re: phill] #277798
03/05/15 03:06 AM
03/05/15 03:06 AM
phill Offline OP
phill  Offline OP
Another piece of the puzzle arrived today.
Mast , carbon with all carbon fittings and 5 constrictor clutches fitted for all 5 halyards.
Set up so each halyard can go to either cabin top winch once I add 4 more turning blocks on the mast base.
The sheaves are already fitted for the 2:1 halyards.
The mast base is built into the mast with a socket to take the gin pole out front for raising and rotation and raising web out back.
Just need to add the halyards and stays.
It is just over 12.6 metres long and weighs 57.01kg. Once the synthetic stays are added I expect it to be still under 60kg. I think that is very good going for a mast of that length. I asked for hi mod carbon in the side walls which should result in the mast being 35% stiffer than Farrier's minimum specs, at least through the minor axis. Hopefully improving what I see as one of the main weaknesses of a wing mast. Time will tell.
mast 1.jpg (1183 downloads)
mast 2.jpg (991 downloads)
mast 3.jpg (1043 downloads)
Re: F85SR Concept Boat [Re: Try Flying] #277944
03/12/15 01:53 AM
03/12/15 01:53 AM
Yup F85 is eligible and we are in. No limits on boat size or type just no motor at all. I am working on the rowing systems but as it is with one simple station in the **** I can maintain 2.5 kts rowing alone. I am putting a sweep on each float and am convinced that 3.5 /4 will be realistic. We will be sailing with three crew. Wish I had your rig!
Re: F85SR Concept Boat [Re: Wayne Gorrie] #279088
05/20/15 06:41 AM
05/20/15 06:41 AM
phill Offline OP
phill  Offline OP
Just working on some more pieces to the puzzle.
Re: F85SR Concept Boat [Re: phill] #279350
06/03/15 06:10 PM
06/03/15 06:10 PM
phill Offline OP
phill  Offline OP
A pic that shows just how long the Dagger board is. Makes me look short but I'm just 1/2 inch under 6ft.
These look like great boards, many thanks to help from Mark H and his CNC work.
Re: F85SR Concept Boat [Re: phill] #279367
06/04/15 04:36 PM
06/04/15 04:36 PM
australia
self_inflicted Offline
australia
They are nice looking boards, What happened to the 6ft swim suit model, That i hired to hold them for you smile smile ?
Is your email working i haven't heard from you for a while
Richard
Re: F85SR Concept Boat [Re: phill] #279368
06/04/15 05:49 PM
06/04/15 05:49 PM
australia
australia
Hi Phil have just sent email,let me know if you get it.
0 registered members (), 687 guests, and 134 spiders.
Posts267,056
