Re: Loos gauge [Re: Arjan13] #277044
01/15/15 10:38 AM
01/15/15 10:38 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Has anyone actually folded a mast on an F16 or F18? I know lots of people worry, but wondering whether its just paranoia or sometimes it actually happens.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Loos gauge [Re: rehmbo] #277047
01/15/15 11:28 AM
01/15/15 11:28 AM
I've seen some of the first Infusions make really elongated tacos out of their masts. I'm not sure what the cause for that was. I sure have put mine through it's paces at times.
Crew on the wire, spin up, "Is the mast supposed to look like that?"
Me, driving, trying to do the math on how we can keep the kite up all the way up to the finish line, traveler nearly bottomed out, main twisted off as much as I possibly dare (a ton), head swiveling up and down to use the brim of my hat to fend the spray from the bows off my face, "We're flying and destroying the fleet...I'm not looking up, just so you know".
Re: Loos gauge [Re: rehmbo] #277050
01/15/15 01:06 PM
01/15/15 01:06 PM
I haven't broken one, I've bent an F16 mast from a diamond wire failure though. It happened right at the bottom mark. We both hopped on the wire, sheeted hard, then POP. Immediately off the trapeze and back on the boat. So I'm almost certain it would've folded if we had been going down wind, or had not immediately gotten of the wire.
The Goodall wing mast that is on the Viper, and Falcon F16 is really soft. Which is perfectly fine and awesome if you use it correctly. But when someone turns the corner, the mast is rotated back, and the downhaul is on, with crew on the wire, its f-ing freaky looking.
I've seen a C2 mast do some really scary stuff when the other Karl and I were reaching hard to the finish at Steeplechase the second day with the kite up, double trapped and I failed to release the mast rotation. It was ugly. To be fair, it was kite up, kite down, kite up, kite down, kite up, kite down, trying to hold an angle. I'm scrawny, easily winded, and forgetful.
Re: Loos gauge [Re: rehmbo] #277051
01/15/15 01:33 PM
01/15/15 01:33 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
It's been done many times on both.
F18 USA 242
http://www.solarwind.solar
Re: Loos gauge [Re: rehmbo] #277052
01/15/15 02:45 PM
01/15/15 02:45 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Oh yeah
Philip
USA #1006
Re: Loos gauge [Re: Arjan13] #277054
01/15/15 05:10 PM
01/15/15 05:10 PM
I think there was a number of Viper masts at that Alter Cup that broke. It was nuking if I remember correctly.
Taylor and Mathew broke a F18 mast at Hyannis, I don't remember how or why.
Re: Loos gauge [Re: Arjan13] #277055
01/15/15 06:16 PM
01/15/15 06:16 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Clearly I had a naive question. I've been petty careful , but did forget to release rotation on a breezy 15+ downhill leg. The picture I saw the next day scared the heck out of me.
That being said, the 4 short years I've been sailing these boats I've never seen it happen.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Loos gauge [Re: Karl_Brogger] #277056
01/15/15 06:36 PM
01/15/15 06:36 PM
There wasn't many broken masts in that 2009 Alter Cup. I competed in that event and it was pretty mild weather for most of it.
Re: Loos gauge [Re: Jake] #277057
01/15/15 08:33 PM
01/15/15 08:33 PM
Clermont, FL, USA
Clermont, FL, USA
Just one I think. It was Mike and Tripp, the diamond came off the spreader and they didn't see it, at least that was the theory.
F18 USA 242
Re: Loos gauge [Re: Arjan13] #277058
01/15/15 08:48 PM
01/15/15 08:48 PM
I'm thinking of the global challenge which was about the same time then. I remember there being lots of carnage.
Re: Loos gauge [Re: stampede] #277064
01/16/15 03:06 AM
01/16/15 03:06 AM
Arjan13 Offline OP
Arjan13  Offline OP
Originally Posted by stampede
Arjan,
in case you bought the loos gauge pictured/posted above, 38 is the medium setting for nacra F18. Max is 42. The prebend of your mast must be inline with the cut of your mainsail (luffcurve matches prebend). If you crank the stays hard, the mast gets stiffer in the lower section and the top is more flexble and vice versa. Andrew Landenberger has some tuning tips for A-cat on his homepage. I found it very helpful to better understand the physics behind. Most People overestimate influence of stay's tension compared to correct use of mast-rotation and cunningham.
Thanks, that is at least giving me an idea about if we're heading in the right direction...
Re: Loos gauge [Re: David Ingram] #277069
01/16/15 08:34 AM
01/16/15 08:34 AM
Aaaa - yes...I remember that being the case.
0 registered members (), 15,781 guests, and 807 spiders.
Most Online22,490
8 hours ago
