| Re: Dimensions of trailer cross bars…
[Re: Seeker]
#27742 01/13/04 12:01 AM 01/13/04 12:01 AM |
Posts: 591 Bradenton, FL | Don't use box! Use C-Channel. Box will hold water and rust out pretty quickly! My trailer is at a lot or I'd go measure it for ya, but it's nothing bigger than what you'd see on a small bass-boat. These boats weigh well under 1000lbs and don't require heavy-duty trailers.
Hobie 14T
[Re: Seeker]
#27743 01/13/04 09:00 AM 01/13/04 09:00 AM |
Posts: 12,310 South Carolina | My 6.0NA trailer has 2" sqaure tubing with a 1/8" wall. The unsupported ends extend 24" from the trailer box frame and are almost 8.5" long.
Jake
Jake Kohl | | | Re: Dimensions of trailer cross bars…
[Re: Seeker]
#27745 01/13/04 12:24 PM 01/13/04 12:24 PM |
Posts: 12,310 South Carolina | sure - note that I meant overall length is nearly 8.5' (not 8.5"). It's probably closer to 8'
[Re: Seeker]
#27747 01/13/04 02:52 PM 01/13/04 02:52 PM |
Posts: 833 St. Louis, MO, | Remember that once you cut it the area where you cut it won't be galvinized. You could just spray a little silver rustolium on the ends to keep them from rusting. Anyplace you cut or drill is a place where rust can start.
Mike Hill H20 #907
Mike Hill N20 #1005
[Re: Seeker]
#27749 01/13/04 03:11 PM 01/13/04 03:11 PM |
Posts: 3,114 BANNED | I'm curious, because this is almost twice the amount that the local industrial supply warehouse here wants for an identical piece of non-galvanized. If the price difference is because of the galvanization, then you might want to take the approach I am with my new tilt and just put the whole thing together then give your buddies a case of beer to help you coat the whole damn thing in POR15. Better than galvanizing IMHO. AND you can get a bright yellow trailer at the same time! | | | Re: Dimensions of trailer cross bars…
#27752 01/13/04 04:10 PM 01/13/04 04:10 PM |
Posts: 3,114 BANNED | Not exactly sure what it is chemically, all I know is that its bulletproof. The antique car guys use it to coat car chassis parts. basically, my car buddy says that its the stuff that all the hot rod and street rod guys are using to preserve all their junk. Its not a paint per se, more of a coating. He says that if its going to be exposed to sunlight for long periods of time, then you really should paint on their supplied primer and then put a topcoat of something on it to protect it. He says overall, that he trusts this stuff more than galvanization to protect from rust. He says a simple internet search will provide answers to your questions
2,475
guests, and 285
