| Re: H17 Battens - how much and where to thin
[Re: Joe]
#27849 01/14/04 05:54 PM 01/14/04 05:54 PM |
Posts: 1,459 Annapolis,MD | Before you touch the battens with a sander - rig your sail with the battens just tight enought to take the wrinkles out. Rig the boat, raise the sail, set basic settings (downhaul to take out wrinkles, rotator pointed around shroud, not oversheeted), put the boat on its side (support the mast a short ladder near the hounds), and measure the draft and its position on the sail. Then you will know where and how much to sand, if you need to at all.
Sanding before measuring might get you the need to buy new battens.
On my 18, the older sail I had required all kinds of different tensions on different battens to get a consistent shape. My new sail only required batten tension to take out wrinkles, and had a wonderful shape without having to do any shaping of battens.
Measure first! Sand later! | | | Re: H17 Battens - how much and where to thin
[Re: MauganN20]
#27853 01/15/04 02:23 PM 01/15/04 02:23 PM |
Posts: 8 St. Louis MO | I am new to Hobies (1.5 years) but that is how they are sold - w/o battens. Is it true the H17 can not use the foam/carbon fiber battens for legal racing? Since we are venting a bit. What upsets me about Hobie is you have to work through a dealer to order from Hobie. Murrays has it set up right so I think you get better service and price (overall). Last year I ordered CatTrax and some other small items and a dealer wanted to charge me $75 shipping (for 3 week service no less). At the time of the order the clerk said the items would would be combined with the boat order so shipping would be minimal. In the end I paid $25 for shipping. Sorry to vent, Joe | | | Re: H17 Battens
[Re: samevans]
#27855 01/15/04 04:42 PM 01/15/04 04:42 PM |
Posts: 284 S. Florida | Hi Sam, I will be one of the first to tell you that when Boston Whaler moved SC to California, the QUALITY went to poor. The California builder changed the B/M to the same construction materials as the other California beach cat builders. The fiberglass, resin, foam, polyester glue, gel coat etc took a big step backwards in physical properties to cheap, cheap, cheap materials. As a result some poor quality boats were built during that time period by untrained foreign labor. Hull weights went up 20 to 40 pounds per hull. Today Aquarius Sails is the only beach builder that builds with West Epoxy resin and the highest quality fiberglass cloth, carbon cloth, PVC foam core, titanium chainplates, all 316 SS fasteners, NO pop rivets. They build 22ft hulls that weigh 95 pounds and 30ft hulls that weigh 175 pounds rigged and painted. Some of these boats are 20 years old... no problems. I have sent several boats to Europe. The owners ordered spare boards and rudders. None of the spare parts have been used. The point I am trying to make, Sam, is that I read about all these changes people are making to their boats to make them right, better, faster. The parts they are changing would cost the same made incorrectly or correctly. For example: Symmetrical rudders and boards vs lopsided ones. Standing rigging that puts the CE in the sweet spot vs having to buy a longer forestay to obtain proper mast rake etc. Battens that put the max camber where it should be in the sail vs untapered ones that have max bend at 50% length and the list goes on and on. Hulls that leak; fittings that leak; masts that leak; boats that pitchpole easily and turtle. Boats that come with no righting system. Bill | | | Re: H17 Battens
[Re: BRoberts]
#27858 01/26/04 05:59 PM 01/26/04 05:59 PM |
Posts: 12,310 South Carolina | Bill,
What other boardless 17' cats are there?
Jake Kohl | | |
3,008
guests, and 279
