| Pics and/or explanation of spin sheet retrieval loop on clew #278594 04/28/15 07:19 AM 04/28/15 07:19 AM |
Joined: Jul 2001 Posts: 2,844 42.904444 N; 88.008586 W Todd_Sails OP
Posts: 2,844 42.904444 N; 88.008586 W | Hello all, I've seen these before, no one around me now seems to use the retrieval line the goes on the clew somehow that helps tuck more of the spin sheet in the snuffer when snuffed, keeping less slack on the tramp. Any links to pictures/explanation would be great- Thanks.
F-18 Infusion #626- SOLD it!
| | | Re: Pics and/or explanation of spin sheet retrieval loop on clew
[Re: Todd_Sails]
#278607 04/28/15 09:53 AM 04/28/15 09:53 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Jake, Chris Green, countless others know this system/ line for the sheets when snuffed off the spin clew?
[Re: mikekrantz]
#278611 04/28/15 10:34 AM 04/28/15 10:34 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Tie a 400mm length small line to the clew with a ring on the end. Pass the halyard from the snuffer through the ring and then up to the snuffer patches.
You will have use a longer spin halyard to make this work properly. thanks Mike, I realize now it's for the spin halyard/retrieval line slack, and not for the spin sheet excess when doused? I'm now running the seperate tack where the bungee goes from around the halyard to the spin tack hoist line, so I may not need this? I was thinking it was also for the spin sheet slack when doused?
[Re: Todd_Sails]
#278613 04/28/15 10:57 AM 04/28/15 10:57 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Tie a 400mm length small line to the clew with a ring on the end. Pass the halyard from the snuffer through the ring and then up to the snuffer patches.
You will have use a longer spin halyard to make this work properly. thanks Mike, I realize now it's for the spin halyard/retrieval line slack, and not for the spin sheet excess when doused? I'm now running the separate tack where the bungee goes from around the halyard to the spin tack hoist line, so I may not need this? I was thinking it was also for the spin sheet slack when doused? No it's for the spin sheet. Think about it. Tie a small line to the clew, I use 2mm spyder line. The other end a plastic ring 1"- 1 1/2"dia. Run the retrieval end of the spin halyard from the snuffer through the ring first then to the take down patches. When you snuff the spin the ring will be the first thing in the bag and will pull the clew and sheets in earlier than without it leaving less line out of the bag.. My small line is a bit longer and you might want to mess with to see what works for you. Shorter small line will take more sheet, longer less. The retrieval end will need to be longer because the ring holds the retrieval line closer to the clew instead of going straight up from the bag to the first take down patch and you need the extra length on port tack so the retrieval line doesn't interfere with the shape of the spin.
[Re: Todd_Sails]
#278630 04/28/15 02:45 PM 04/28/15 02:45 PM | MN3
| MN3
Unregistered | i had this system
but I had problems snuffing and shrimped my spin in pretty heavy air and cut it off the system, at the time i thought it caused me to foul the spin snuffing
now that i have used a spin a lot more and have skrewed up the snuffing many additional times, I am not sure it had anything to do with the snuffing problems of that day or not - but i never replaced it | | | Re: Pics and/or explanation of spin sheet retrieval loop on clew
[Re: Todd_Sails]
#278631 04/28/15 02:59 PM 04/28/15 02:59 PM |
Posts: 3,906 Clermont, FL, USA | I'm not a fan of this system. It makes the snuff more difficult and if everything isn't prefect can hose the spin shape in light are. I use stick on velcro on the crossbar to keep the sheet out of the water. I also use bungee tied to the ends of the spinsheet to keep the deck tidy.
[Re: David Ingram]
#278632 04/28/15 04:48 PM 04/28/15 04:48 PM |
Posts: 4,119 Northfield Mn | I'm not a fan of this system. It makes the snuff more difficult and if everything isn't prefect can hose the spin shape in light are. I use stick on velcro on the crossbar to keep the sheet out of the water. I also use bungee tied to the ends of the spinsheet to keep the deck tidy. What he said.
[Re: David Ingram]
#278638 04/28/15 08:13 PM 04/28/15 08:13 PM |
Posts: 12,310 South Carolina | I'm not a fan of this system. It makes the snuff more difficult and if everything isn't prefect can hose the spin shape in light are. I use stick on velcro on the crossbar to keep the sheet out of the water. I also use bungee tied to the ends of the spinsheet to keep the deck tidy. Same thing here too...my compass sits right behind my forestay and I had this system wrap something around the compass once that made a serious mess out of things. it could also sometimes make the snuff really difficult (actually, I think it was relaunching it that sometimes would get really tough)..but we may have been doing something wrong with it. I eventually quit using it and we just make sure the spin sheet isn't any longer overall than it needs to be.
Jake Kohl | | | Re: Pics and/or explanation of spin sheet retrieval loop on clew
[Re: Todd_Sails]
#278644 04/29/15 07:58 AM 04/29/15 07:58 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Thanks again all, I'll experiment with both systems a bit.
Now I started a new thread about tying off or what people are doing with the spin sheet- as mine has the two ends on the tramp, with a pigtail tying off to the spin. Please see that thread and comment.
[Re: Todd_Sails]
#278764 05/03/15 04:30 PM 05/03/15 04:30 PM |
Posts: 337 Arizona | I use then strop at the clew and love it. However, i regularly sail with inexperienced crew and they don't understand that they need to use their manballs to launch and or snuff. There is a point that the kite bunches up and needs a little extra effort. I know it's going to happen and expect it. I am in touch with my manballs. Once my crew has launched and retrieved a couple times, they are in touch with their own manballs.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | |
3,910
guests, and 692
