Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278761
05/03/15 02:25 PM
05/03/15 02:25 PM
42.904444 N; 88.008586 W
Todd_Sails Offline OP
Thanks Tony for the first picture, that's how I"m going to run it in this years GT300.
I think so Azcat, and I reallyt like your avatar! She still around?
F-18 Infusion
#626- SOLD it!
Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278763
05/03/15 03:53 PM
05/03/15 03:53 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
21 years, I think.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: Spinaker sheet, knot placement options.... [Re: Tony_F18] #278765
05/03/15 04:49 PM
05/03/15 04:49 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
[quote=Tony_F18]Picture of our spinsheet setup: http://1drv.ms/1OJTzNh
Off topic: I took some very cool pics of some cats overhere in Carnac, France:
http://1drv.ms/1OJU6z0 [/quot
Tony, what is the single block on the bungee at the skipper position, stb hull , white line exiting?
Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278766
05/03/15 05:01 PM
05/03/15 05:01 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
Also, if you're not using a take up strop on your clue to get rid of your spinnaker sheets, you're ending up with a lot of sheet on the tramp when the kite is snuffed, correct?
Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278788
05/04/15 09:18 AM
05/04/15 09:18 AM
Also, lets say you're doing a distance race and basically on one tack/jibe for many hours and you wanted to run the sheet from the clew, theu a block on the clew and have the end attached to the shroud (cleat, ball and loop, etc.) to make it much easier to work the sheet:
In the case of the spin sheet being run with:
A pagtail burried in the middle of the line tied to the spin clew and the ends tied off or tied together at the back:
That method kinda make it impossible to so that.
Any other options? I may go with a block on the clew on the port sheet side/so when sheeting on a starboard my crew has a 2:1 on the spin sheet.
F-18 Infusion
#626- SOLD it!
Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278789
05/04/15 09:20 AM
05/04/15 09:20 AM
If you taper the ends of the spin sheet, the knot(s) at the clew won't interfere with anything... and still leave you the option of the 2:1 setup mentioned earlier.
Can you get an auto-ratchet block with becket arrangement? That would give you an anchor point for the 2:1 when needed.
Re: Spinaker sheet, knot placement options.... [Re: AzCat] #278883
05/07/15 09:11 AM
05/07/15 09:11 AM
That's the spinnaker's tackline.
It goes from under the front beam to a block at the shrouds, through the block you referenced and back to the shroud where its spliced to the block's center.
Normally tack lines are 1:1 but this one's 1:2 so I only have to pull halve the length, the line is thinner than standard to not add any extra friction while pulling.
Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278902
05/07/15 02:59 PM
05/07/15 02:59 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
Got it
Re: Spinaker sheet, knot placement options.... [Re: Todd_Sails] #278903
05/07/15 03:09 PM
05/07/15 03:09 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
Okay Tony, so your Spinnaker sheets dead and on top of the tramp but a small attached line goes through a turning block, under the tramp and is connected to the other side. On the way across the bottom of the trap you have a block on a bungee pulling the slack out of that line is that correct? Or is that just a bungee attached to the end of your Spinniker sheet? I have attempted this in the past and didn't have good results so I took it off . But I did not taper the spinnaker sheet either, that would actually be a very good idea . Has anyone used this set up in conjunction with the strap on the clue of the kite that gets rid of the spin sheets pulling them into the sock?
0 registered members (), 2,640 guests, and 390 spiders.
Yesterday at 10:10 AM
