| Re: spinnaker chute
[Re: Beckit 1824]
#279171 05/27/15 07:37 AM 05/27/15 07:37 AM |
Posts: 182 Grafton, NSW | Another things that wrecks your spinnaker really quickly is any scrags of wire on your fore stay eyelet swage. When they swage it, they intentionally leave it poking out about 1-2mm of the copper swage so you can see if the swage is failing, but when the spinnaker gets wrapped around it it chew 5cm splits into the sail. A bit of PVC or electrical tape does the trick.
I never leave swages with nasty sharp wires sticking out of them. It hurts like hell when you pprick your thumb on them, not to mention ripping sails or chaffing sheets. If a swage is done properly it will never let go; the most common mode of failure is where the strands of the wire break off adjacent to the swage. Protruding wires from a swage serve no useful purpose. When I do swaging at home I either make sure the short end is inside the swage so there are no protruding wires, or if that is not practical and there are protruding wires after swaging, I cut them off with an angle grinder. That requires a good eye and a steady hand, because if you accidentally nick the wire on the other side, you have to start again. The trick is to cut almost, but not quite through the last strands, then they will easily break off. I have done it dozens of times and have only nicked a wire once.
1140 Gadfly 1434 J.I.B.E. 1727 Atreus
| | | Re: spinnaker chute
[Re: Alan Erlandsen]
#279200 05/27/15 10:23 PM 05/27/15 10:23 PM |
Posts: 416 | From a riggers point of view, when doing a Ferral and thimble copper swage before swagging the wire must be the diameter of the wire sticking out at the end and when swagged there should be some unswagged wire sticking out the bottom. Why you may ask..... the unswagged wire is not compressed and will not slip through the copper if it happens to slip. When swagged by a Hand swagger have a habbit to slip under tention. On our "toy boats" we never meet the breaking strain of the wire. Wire breaks due to fatigue.
Its a pain with it sticking out but you can put heat shrink, or self evolving tape around the swage.
Matt
| | | Re: spinnaker chute
#279201 05/27/15 10:34 PM 05/27/15 10:34 PM |
Posts: 182 Grafton, NSW | Thanks to Matt for the expert advice.
I have made dies to suit the various swage sizes, and I put them in a vice to crimp the swages. The dies are not as long as the swages, so the end parts of the swages don't get compressed. That means there is still a short length of wire inside the swages which is not compressed.
| | | Re: spinnaker chute
#279255 05/28/15 07:13 PM 05/28/15 07:13 PM |
Posts: 182 Grafton, NSW | The heat shrink I use on electrical work came from Jaycar and is quite thin. Is there thicker, heavier stuff available?
| | | Re: spinnaker chute
#279265 05/29/15 04:13 AM 05/29/15 04:13 AM |
Posts: 182 Grafton, NSW | Thanks Alan that sounds great, I look forward to trying it out.
I will PM you with my address.
Regards, Greg.
2,080
guests, and 330
