| Re: Aquacat 12.5 righting & sheeting, line questions, etc.
[Re: WildBilly66]
#279597 06/25/15 06:55 AM 06/25/15 06:55 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | For a righting line all you need is comfortable rope probably only about 8 to 10 long. Most attach to the mast base and coil it up on deck. When the boat is on its side, throw the line over the upper hull, grab it and lean back at about 45 degrees. It helps if you can get the bow almost into the wind, allowing the wind to get under the sail and help right the boat.
You might want to check to see if there is water in the mast. Sounds like it. If so, very hard to right | | | Re: Aquacat 12.5 righting & sheeting, line questions, etc.
[Re: WildBilly66]
#279604 06/25/15 11:19 AM 06/25/15 11:19 AM |
Posts: 330 | It later turtled in my attempt to get it upright myself.
I haven't seen an aquacat in years, but my recollection is that they have (or are supposed to have) a float at the top of the mast to prevent turtling. sm | | | Re: Aquacat 12.5 righting & sheeting, line questions, etc.
[Re: WildBilly66]
#279673 06/29/15 03:59 PM 06/29/15 03:59 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Glad you're OK.
LIke Rick White said, any thick line, with knots to help hold it, or if you have it, to put in the hook of your trap harness to lean back on and right the boat.
ALWAYS have a righting line- MUrphys law
practice righting it on the grass/beach before you go out next time. Have fun, be safe
F-18 Infusion #626- SOLD it!
[Re: RickWhite]
#279808 07/07/15 09:23 PM 07/07/15 09:23 PM |
Posts: 3,224 Roanoke Island ,N.C. | You really have to stop with the "pontoon" thingy. They are hulls EASY old man.
[Re: RickWhite]
#279829 07/09/15 07:45 AM 07/09/15 07:45 AM |
Posts: 921 Alachua, FL | You really have to stop with the "pontoon" thingy. They are hulls I think for an Aqua Cat "pontoon" is a better term, Rick. BTW, isn't "thingy" rather gay? Not that there is anything wrong with that.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | |
203
guests, and 19
