| Polishing gelcoat hulls #279698 07/01/15 05:26 AM 07/01/15 05:26 AM |
Joined: Aug 2011 Posts: 182 Grafton, NSW Greg/Debra OP
Posts: 182 Grafton, NSW | Hi Mossies,
I am interested to hear what people think is the best type of product to polish up dull gelcoat hulls.
Thanks, Greg.
1140 Gadfly 1434 J.I.B.E. 1727 Atreus
| | | Re: Polishing gelcoat hulls
[Re: Greg/Debra]
#279716 07/02/15 01:30 AM 07/02/15 01:30 AM |
Posts: 25 South Australia | Im a boat builder At the boat yard i work at we only use 3m. This for a $3M riv or a 6ft tender Best results is to use machine polish with a foam head not wool head. keep a spay bottle with water handy light coat of water just stops the polish from drying up. Dry polish is what makes the swirl marks you see on cars, once you have finished a area go back over it with a clean dry rag the job will come up spiffy NOTE do not use an aggressive polish unless you are trying to remove scratches (you will see the polish marks) If your just trying to make you boat shine fine polish is the way to go. Most polishes are the same but 3m is made for marine and has a better finish than car polish on fiberglass Cheers
IF I CALL STARBOARD ON YOU BE PRETTY SURE I MEANT TO
[Re: Greg/Debra]
#279744 07/03/15 04:47 AM 07/03/15 04:47 AM |
Posts: 182 Grafton, NSW | Thanks to Stephen and Matt for the advice. I had a look at the recommended products.
Seems like 3M have two; one in a yellow container and the other in purple. While Farecla have about ten different products.
So guys could you make it simple and tell me which particular product you recommend?
Thanks, Greg
[Re: Greg/Debra]
#279754 07/04/15 05:11 AM 07/04/15 05:11 AM |
Posts: 182 Grafton, NSW | Hey Tash,
Thanks for the info, much appreciated. I hadn't even seen those two products as on the Farecla website they are on the"industrial" page whereas the ones I was looking at are on the "automotive" page.
If I can't find it locally I'll get back to you.
Thanks again, Greg.
5,791
guests, and 700
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Sep 13th, 2025 | | | |
