| 2015 Nacra 17 Worlds #279654 06/28/15 07:33 AM 06/28/15 07:33 AM |
Posts: 554 Boston, Ma | First day of racing for the 2015 Nacra 17 Worlds is Sunday July 5th. This is a huge event for the US teams for a couple of reasons.
1. The US still needs to gain a country berth for Rio
-Ideally, we would gain one of the three berths available in Aarhus. If not, lets hope Canada, Aruba, and Puerto Rico all qualify!
2. The results of these worlds have major implications on the US selection process for Rio.
- The selection events for the US team are the 2016 Miami World Cup and 2016 Worlds in Clearwater.
- Entries for Miami will likely be limited, and the results of the 2015 Worlds determine who gets spots at Miami. No Miami, no Olympics.
From the selection document:
"2. For the 2016 ISAF Sailing World Cup Miami, if limited entries are enforced, MNAs will be awarded a certain number of spots according to a system described in the Notice of Race. US Sailing will award entries to its athletes using the following criteria:
The first two entries in each class will be awarded to the two highest finishing athletes or teams at the 2015 class world championships.
If a third entry is available in a class, it will be awarded to the highest finishing athletes or teams at the 2016 MLK Weekend Regattas at Coconut Grove Sailing Center (470, 49er, 49er FX, Nacra 17, RS:X) and Lauderdale Yacht Club (Finn, Laser, Laser Radial) January 16-18, 2016.
If a fourth entry is available in a class, it will be awarded to the third highest finishing athletes or teams at the 2015 class world championships...."
US entries: Mark Mendelblatt United States USA027 Carolina Mendelblatt Sarah Newberry United States USA278 Matthew Whitehead Michael Easton United States USA 234 Katie Pettibone Steph Hudson United States USA123 Evan Aras John Casey United States USA204 Kristen Lane
USF18 Eastern Area Rep Nacra Infusion USA 753
| | | Re: 2015 Nacra 17 Worlds
[Re: Jeff.Dusek]
#279760 07/06/15 10:47 AM 07/06/15 10:47 AM |
Posts: 3,906 Clermont, FL, USA | It is interesting to see the number of teams that decided to stay on the beach. It's a gamble to burn your throws early. Mike and Katie are posting very consistent numbers.
[Re: Jeff.Dusek]
#279762 07/06/15 11:35 AM 07/06/15 11:35 AM |
Posts: 554 Boston, Ma | I think the results are a bit misleading currently. There are two fleets- yellow and blue. Yellow fleet have finished two races (Easton is yellow), now blue is on the water (Newberry) but have only finished one race, and have a DNC for race two. It would be nice if they didn't use DNC for that purpose!
[Re: Jeff.Dusek]
#279763 07/06/15 11:37 AM 07/06/15 11:37 AM |
Posts: 3,906 Clermont, FL, USA | Gotcha, thanks for the clarification.
[Re: Jeff.Dusek]
#279766 07/06/15 12:35 PM 07/06/15 12:35 PM |
Posts: 554 Boston, Ma | Results are up for today: two races each fleet (they may do a third, not sure): https://dl.dropboxusercontent.com/u/438966762/Nacra17%20-%20Results.htmAs a reminder, the countries that are qualified: 1 FRA , 2 ARG , 3 AUS ,4 ITA, 5 NZL, 6 SUI, 7 GBR, 8 DEN, 9 AUT, 10 NED Three spots available at 2015 worlds: 1. ARU 2. GER 3. ESP 4. GRE 5. USA (Newberry) 6. PUR (Figueroa) 7. URU 8. RUS 9. CAN (Ramsay) 10. NOR
[Re: brucat]
#279784 07/07/15 06:16 AM 07/07/15 06:16 AM |
Posts: 12,310 South Carolina | That's not fast (or cheap)...
-Captain Obvious Well, technically speaking...it could be fast depending on how anxious the rib driver is. But that does indeed have a very high suck factor.
Jake Kohl | | | Re: 2015 Nacra 17 Worlds
[Re: Karl_Brogger]
#279787 07/07/15 07:59 AM 07/07/15 07:59 AM |
Posts: 3,906 Clermont, FL, USA | That's weird, a broken N17 mast... Oh come on Mark you can do better than that? Oh sh1t Karl said that, damn marriage has made you soft, are you getting fat too?
[Re: Jeff.Dusek]
#279790 07/07/15 09:03 AM 07/07/15 09:03 AM |
Posts: 3,969 | As a reminder, the countries that are qualified: 1 FRA , 2 ARG , 3 AUS ,4 ITA, 5 NZL, 6 SUI, 7 GBR, 8 DEN, 9 AUT, 10 NED
Results for the first 2.5 races from today are up. ARU and GER are going to be extremely difficult to catch, so it's really a race against Iker (and the rest of the teams on the fence) for the final spot. Talk about a daunting task! Mike | | | Re: 2015 Nacra 17 Worlds
[Re: brucat]
#279791 07/07/15 09:58 AM 07/07/15 09:58 AM |
Posts: 5,590 Naples, FL | do you get redress for an equipment failure (like the broken mast)?
[Re: waterbug_wpb]
#279792 07/07/15 10:19 AM 07/07/15 10:19 AM |
Posts: 3,906 Clermont, FL, USA | do you get redress for an equipment failure (like the broken mast)? I've only seen that card successfully played when the equipment was provided. That's not the case here and yikes what a can of worms if you're allowed redress for equipment issues. Imagine the situation where you're having a bad race so you break your stick because you have another and redress gives you a better score.
[Re: Jeff.Dusek]
#279794 07/07/15 10:26 AM 07/07/15 10:26 AM |
Posts: 3,969 | Redress is never given for equipment failure in BYOB events, RRS does not allow for that (think: whose fault is it).
While redress is allowed for damage caused by other boats in BYOB events, I've seen that disallowed at a Worlds. IJ basically decided that the damage wasn't enough to make the boat unraceable.
Redress can be given for equipment failures in a BYOB event, but you have to prove that you didn't cause it (no fault of your own clause). I've seen this disallowed as well.
[Re: waterbug_wpb]
#279795 07/07/15 10:28 AM 07/07/15 10:28 AM |
Posts: 3,116 Annapolis, MD | nope... no redress for breaking your mast.
Now ISAF can notice that mast breakage and they have decided that this should not be part of the competition and request the class under take a fix. That is how the Torando class moved to carbon sticks from alu extrusions. Marstrom designed and built the stick to be close to the alu extrusion. (bullet proof stick)
Is that an option here... oh wait. ISAF already had a hand in designing these masts to fix the nacra ones that broke all of the time..
no worries... they will get it right on the third try!
crac.sailregattas.com
[Re: Jeff.Dusek]
#279796 07/07/15 12:16 PM 07/07/15 12:16 PM |
Posts: 554 Boston, Ma | Update after 5 races:
Three spots available at 2015 worlds: 1. GER (7th) 2. ARU (11th) 3. ESP (20th) 5. PUR (Figueroa, 23rd) 6. GRE (24th) 7. USA (Newberry, 25th) 8. CAN (Ramsay, 29) 9. RUS (30) 10. URU (32)
As far as the masts, I think a lot of it comes down to skill level and time in the boat. You just don't see breakages from the top teams. If you look at the top of the fleet it is the same teams, no matter the wind and sea state.
Note: edited my post because previous comment came across poorly and I certainly mean to disrespect to anyone who broke a mast
[Re: Jeff.Dusek]
#279797 07/07/15 01:18 PM 07/07/15 01:18 PM |
2,501
guests, and 596
