Wrist GPS/Start tiumer #280137
08/05/15 11:53 AM
08/05/15 11:53 AM
PTP Offline OP
PTP  Offline OP
The garmin foretrex I had finally died after many resuscitations. Not made anymore, what replacement do you recommend? Absolutely needs the start timer, gps is second to this.
this looks promising, but was hoping for something more in the 100$ price range like the foretrex.
https://buy.garmin.com/en-US/US/on-...n/quatix-/prod120680.html#gallery-dialog
Re: Wrist GPS/Start tiumer [Re: PTP] #280139
08/05/15 01:51 PM
08/05/15 01:51 PM
I went through this myself recently - but they still make the Foretrex. They just hid it really well on their website. I thought they quit making it too but I just bought one last December.
https://buy.garmin.com/en-US/US/prod30025.html
https://buy.garmin.com/en-US/US/prod30026.html
What they don't make anymore is the version that had a sealed internal battery. Everything takes AAAs. I put dielectric grease on the battery contacts and a flexible non-permanant gasket goo on the battery door. It makes for a mess to maintain but it kept water out through a steeplechase and a rather windy Florida 300.
The wireless data transfer on the 401 is nice too...I can send routes from my handheld to the 401 without any cables.
Re: Wrist GPS/Start tiumer [Re: Jake] #280147
08/06/15 09:38 AM
08/06/15 09:38 AM
PTP Offline OP
PTP  Offline OP
Thanks Jake!
Ordered one yesterday
Re: Wrist GPS/Start tiumer [Re: Jake] #280148
08/06/15 11:20 AM
08/06/15 11:20 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
My 401 did really well on the 300 also and the battery case appeared to stay really dry without the goo. Now watch it leak this weekend :-)
F18 USA 242
http://www.solarwind.solar
Re: Wrist GPS/Start tiumer [Re: David Ingram] #280149
08/06/15 11:53 AM
08/06/15 11:53 AM
I still wouldn't trust it without the goo. I've already burned through something like 6 of those suckers. Either through salt water in the battery compartment, just stopped working, or adding it to Poseidon's collection.
Re: Wrist GPS/Start tiumer [Re: PTP] #280150
08/06/15 03:16 PM
08/06/15 03:16 PM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
I dipped mine in epoxy until I got a good 1/2 inch of thickness. it made it hard to press buttons but no water got in...only good for one set of batteries though. in retrospect, not a really good solution...
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: Wrist GPS/Start tiumer [Re: Capt_Cardiac] #280153
08/07/15 08:42 AM
08/07/15 08:42 AM
Dunedin Causeway, FL
David Parker Offline
Garmin would do the world a favor if their line of waterproof GPS would use wireless induction charging of their batteries. That way you could seal the unit and not have to ever open it. I guess they'd sell more as you'd have to replace it when the batteries tired out and died.
Re: Wrist GPS/Start tiumer [Re: Capt_Cardiac] #280181
08/08/15 07:35 PM
08/08/15 07:35 PM
PTP Offline OP
PTP  Offline OP
smart butt. the 1/2 inch of epoxy much have been worn off by the time I got that one from you smile
Re: Wrist GPS/Start tiumer [Re: David Parker] #280183
08/08/15 09:10 PM
08/08/15 09:10 PM
I'll likely never buy a phone that doesn't have induction charging. The phone I've got now has it built in, it's f-ing awesome.
Re: Wrist GPS/Start tiumer [Re: Karl_Brogger] #280184
08/09/15 08:25 AM
08/09/15 08:25 AM
I'm giving that a year for it to be integrated into everything really well...car, home, etc. In fact, I'm about done with being a tester on the bleeding edge of technology.
Re: Wrist GPS/Start tiumer [Re: PTP] #280194
08/10/15 06:39 AM
08/10/15 06:39 AM
Jake,
I think you just made a joke there.. wink
Engineering types like you (and me) will always fall for new and bleeding egde tech.. Fact of my life at least.
Re: Wrist GPS/Start tiumer [Re: Rolf_Nilsen] #280196
08/10/15 07:52 AM
08/10/15 07:52 AM
don't you engineer-types make the bleeding edge stuff?
So yes, it's like denying your very existence...
Re: Wrist GPS/Start tiumer [Re: waterbug_wpb] #280199
08/10/15 08:45 AM
08/10/15 08:45 AM
I want to spend more time making bleeding edge stuff and less time testing other people's bleeding edge stuff from which I only suffer!
Re: Wrist GPS/Start tiumer [Re: Jake] #280200
08/10/15 09:44 AM
08/10/15 09:44 AM
okay, make me an app that give me VMG when I point the camera at a particular point (buoy, landmark, etc)
Or one that I point at the sail trim lines and tells me if I need to adjust it based on NEMA apparent wind.
Re: Wrist GPS/Start tiumer [Re: Jake] #280215
08/12/15 03:10 AM
08/12/15 03:10 AM
Do you have experience with the Arduino system?
I'm thinking about using it for a winter project, maybe build a compass or GPS or something.
Re: Wrist GPS/Start tiumer [Re: Tony_F18] #280217
08/12/15 12:19 PM
08/12/15 12:19 PM
I do. I designed built a series of useless boxes using arduinos for the logic and servo control. I'm no expert with them but they are pretty straight forward. One piece of advice; pick a vendor that puts entire packages together (like adafruit). They test everything so you can be sure that the components are of decent quality and compatible. They also have software libraries that you can incorporate into your projects to use those components with simple commands while the library takes care of the complex programming tasks.
0 registered members (), 659 guests, and 144 spiders.
Topics22,404
Posts267,055
