grip tape #280281
08/20/15 01:15 PM
08/20/15 01:15 PM
mi
carl2 Offline OP
carl2  Offline OP
mi
Has any one used skateboard tape for their hulls to provide grip when trapping?
My son slipped on his butt hard on our nacra 450(he was barefoot)..I've since purchased "motto" (clear) 10" x 48" for 10.00 from the skateboard store..seems like a good deal but I'm hesitant to put it on the hulls for fear of it yellowing & being hard to get off later..any experience with this tape?
http://www.theskateboardstore.com/grip-tape/motto/clear-10-grip-tape-4-sheet/
Re: grip tape [Re: carl2] #280282
08/20/15 02:38 PM
08/20/15 02:38 PM
Ouch...sounds like that would be rough on the skin. Try this stuff...be sure to NOT use the paddle board stuff..use the PWC stuff as it's tougher.
http://www.hydroturf.com/
Re: grip tape [Re: carl2] #280283
08/20/15 02:59 PM
08/20/15 02:59 PM
Quebec, Canada
A. Bourgault Offline
Quebec, Canada
Jake, is that hydroturf easy to apply when you have composite curved surface like the junction between the radius of the top and side of the hull and the radius close to the beams?
Re: grip tape [Re: A. Bourgault] #280284
08/20/15 04:03 PM
08/20/15 04:03 PM
I haven't had the pleasure of using it myself yet - I was getting ready to order some for the F18. A lot of people are using it - hopefully someone will chime in soon that can comment on how it works on compound surfaces.
Re: grip tape [Re: carl2] #280286
08/20/15 06:17 PM
08/20/15 06:17 PM
3M makes a grip tape for steps that works pretty awesome. It's rubbery and not super abrasive. I stuck some on my boat a few years ago and it's held up very well. The stuff used on skateboard decks is sandpaper and pretty harsh on your gear.
I've thought about sanding all the gelcoat off and painting my hulls, I was planning on just using the 3M grip tape to replace all of the non-skid.
Re: grip tape [Re: carl2] #280287
08/20/15 06:38 PM
08/20/15 06:38 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
I use http://www.seadek.com/p-10-large-sheet-39-x-77.aspx it's pretty easy to apply and is very durable, looks good too.
F18 USA 242
http://www.solarwind.solar
Re: grip tape [Re: Karl_Brogger] #280288
08/20/15 07:54 PM
08/20/15 07:54 PM
dr5e14w Offline
dr5e14w  Offline
It's not fun doing all that sanding. There's way more gel coat than you think!
Re: grip tape [Re: carl2] #280289
08/20/15 08:51 PM
08/20/15 08:51 PM
mi
carl2 Offline OP
carl2  Offline OP
mi
Thanks The hydro-turf looks to be the better price..lot of color & style options cool
Re: grip tape [Re: carl2] #280290
08/20/15 09:06 PM
08/20/15 09:06 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I have some grip tape in particular spots on the beams and behind the rear beam where only feet should be going. Works really well with shoes. It would be pretty rough on any clothing or gear if you cover the entire area in it.
I too have Hydro turf that I have been meaning to install for close to 2 years now.
Re: grip tape [Re: carl2] #280292
08/21/15 06:08 AM
08/21/15 06:08 AM
Lugoff, South Carolina
Mac McCallum Offline
For anyone looking to save a little money on the Hydro Turf, the B grade is an option. I've ordered 4 sheets total over a year and a half period and I haven't been able to find what would downgrade it on any of the sheets. Not all the color and pattern option but it's cheaper. I used the black diamond pattern.
http://hydroturf.com/products/Closeouts_and_Specials/Sheets_of_Turf
'09 Viper F16 USA102
A Cat USA 366
Re: grip tape [Re: dr5e14w] #280297
08/21/15 12:18 PM
08/21/15 12:18 PM
You're the f#ckwit that convinced me it'd be a good idea! grin
Re: grip tape [Re: Karl_Brogger] #280302
08/22/15 08:27 AM
08/22/15 08:27 AM
dr5e14w Offline
dr5e14w  Offline
Glad I could help. It was worth it to me but I wouldn't say the sanding was fun.
Re: grip tape [Re: dr5e14w] #280303
08/22/15 09:19 AM
08/22/15 09:19 AM
JACKFLASH Offline
JACKFLASH  Offline
I have used the hydraturf on my Infusion. It works great and takes the deck to hull side curve just fine. But on compound curves it only does okay unless the compounds curves are not extreme. I suggest making a template out of heavy paper or clear Mylar film that you can than transpose to the flat turf. Keep in mind the turf can be stretched and bunched to some degree.
Collin Casey
Re: grip tape [Re: carl2] #280304
08/22/15 10:54 PM
08/22/15 10:54 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
I have found this stuff to work the best in the past. http://solutions.3m.com/wps/portal/3M/en_US/Facilities-Care-Cleaning-NA/commercial-cleaning/cleaning-supplies/~/3M-Safety-Walk-Slip-Resistant-Medium-Resilient-Tapes-and-Treads-370?N=5927891+8703506+3293414317&rt=rud
Re: grip tape [Re: carl2] #280306
08/23/15 06:34 PM
08/23/15 06:34 PM
That's the exact stuff I'm talking about.
Re: grip tape [Re: carl2] #280310
08/24/15 06:18 AM
08/24/15 06:18 AM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
[Linked Image]Afb077 by northseajunkie, on Flickr [img]http://[/img]
I've used several anti-slip covers. For the flat surfaces on my cat hydroturf sheets (see above for my backfoot) which has a pre-glued sticking side on their back.
So for preparation only light sanding and degreasing is sufficient.
These sheets are very popular in the wavesurf scene and I use them also on my windsurfboard. But with heavy use, you have to replace them after a few years.
For the side-standing with a rather sharp rounding to the deckside (as you can see), I use rubber antislip material (used on yacht decks) which I had to fix with contactglue. A little bit more work but they hold very good despite heavy use.
Last remark. When sailing on a rough sea ,a good antislip standing surface is almost more important than a watertight hull!
ronald
RAIDER-15 (homebuilt)
Re: grip tape [Re: carl2] #280311
08/24/15 07:22 AM
08/24/15 07:22 AM
Thats why I never sail barefoot, you just dont have the same grip when wearing shoes.
As an alternative you could also use sexwax which is used to apply grip to surfboards, it looks a bit odd but works very well.
Re: grip tape [Re: Tony_F18] #280313
08/24/15 02:09 PM
08/24/15 02:09 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Try getting pads for SUPs and cut to size needed. We had custom pads made for our training Open Bics. The kids like them because they're soft and still offer a no slip surface.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: grip tape [Re: carl2] #280314
08/24/15 06:43 PM
08/24/15 06:43 PM
Scarecrow
Scarecrow
skateboard non skid will kill your wetsuits. Another vote here for EVA foam. Another brand option is:
http://www.seadek.com/default.aspx
Re: grip tape [Re: Karl_Brogger] #280401
09/01/15 07:19 PM
09/01/15 07:19 PM
M
MN3
MN3
M
and only $1241 a roll
0 registered members (), 3,731 guests, and 145 spiders.
