| Re: Bow Beams
[Re: D_Lemke]
#28063 01/27/04 04:28 PM 01/27/04 04:28 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Sounds like a Sizzler. I worked for the factory in Ohio. That bow "foil" you are talking about was supposed to do exactly what you described -- keep the boat from pitchpoling. I think that others did not adopt it because everyone said, "Yeah, well, it brings the bows back at a certain angle of attack, but if the bows were to go down at a greater angle of attack, the bow foil would actually tend to take it on down instead of bring it back up." (We didn't do enough on-water testing to learn the answer.)
The designer of the boat and the bow foil was Carl Swenson, and I'm sure he has long since departed this world.
He also invented some lifting foils for the hulls (sort of like butterfly wings) that clamped onto the forward part of the bottoms of the hulls. People said the same thing about them -- would give lift until the boat exceeded a certain degree of forward pitch, and then disaster.
But that was long ago and he was doing early experimentation. | | | Re: Bow Beams
[Re: Mary]
#28064 01/28/04 12:13 AM 01/28/04 12:13 AM |
Posts: 591 Bradenton, FL | Hans Geissler was actually a salesman for Sizzler before their demise, and took some of what he learned from their design and incorporated it into the G-Cat. Speaking of G-Cats, it would be easy to widen a 5.7M and turn it into a psuedo 18sq ('cept it's 9" too long). The mast, mast-beam and aft-beam are H16 mast sections and the fore-beam is a H14 mast section. You could cut the G-Cat mast and turn it into the rear two beams, cut a H14 mast and turn it into a front beam, and then slap a taller mast on it and run a big mainsail. I've given a lot of serious consideration to widening my boat to 10-12'... but keeping the same rig + a screacher. This should turn it into a nice all-weather Gulf of Mexico boat
Hobie 14T
| | | Re: Sizzler
[Re: Mary]
#28065 01/28/04 07:06 PM 01/28/04 07:06 PM |
Posts: 11 Minnesota | Sounds like a Sizzler. I worked for the factory in Ohio. That bow "foil" you are talking about was supposed to do exactly what you described -- keep the boat from pitchpoling. Oh thank God !!!! And all this time I thought it was a bad dream 1  Yes - it was a Sizzler 16 that fit (mast height) between a Hobie 14 and a Hobie 16. A little underpowered, but I can attest the foil worked ! Purchased used in 1974 from Brennan Marine up in Bay City Michigan. Interesting tidbit. Brother-in-law and I went to watch DN class in Caseville in "thumb", and they had moved races to Tawas (across the bay) Decided to take in a February boat show at Brennan's and saw the Sizzler. Bought it the next week. Never did make the drive around to the other side of the bay for the DN races. Biggest problem I had, was the internal hull foam shrunk and pulled back from the hulls, leaving about 1/4 inch all the way around. Water would run down the tramp post and into the hull, making it heavier and heavier. The stern (narrow) transoms were too high and had no drains. Had to "pop" off the "bottle cap type plugs" on the top of each hull, turn the whole thing over and leave it that way for winter. By spring it was dried out and lighter again! Good times !  I saw somewhere, that they were going to try to market the Sizzler again. Even saw some info on the Sizzler 21 and "Super Sizzler" - but then nothing! About 2 years ago - unless THAT was the dream! | | | Re: Sizzler
[Re: D_Lemke]
#28066 01/29/04 12:32 AM 01/29/04 12:32 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | It wasn't a dream. I had a story in Catamaran Sailor a couple years ago. I talked to a guy in the Cleveland area who was going to buy all the tooling and left-over hulls and parts from the original owner of the company. I don't know if he ever went through with it. Guess not, or he would have called me to get some publicity for it.
The foam was the biggest problem with the boats. It sounded good in theory -- fill the hulls completely with expanding foam, and then supposedly there was no way for the hulls to take in water, so you didn't even need a drainhole. But in actuality, there were usually voids in the foam here and there, and water did get in, and there was no way to get it out of those isolated pockets. On top of that, even though supposedly the foam itself would not absorb water, many of us were convinced that the foam WAS absorbing water and getting heavier and heavier over time.
The standard Sizzler 16 was a little underpowered, so they quickly came out with the Super Sizzler option, with taller mast and more sail area. That was a really good boat, very well balanced, and fast. And talk about wave-piercing bows!! No other cat has ever had bows that sharp.
The Sizzler was the inspiration for Hans Geissler's G-Cat designs -- at least the deep, sharp, underwater profile that made it possible to have efficient, symmetrical hulls without boards.
P.S. There was also a Sizzler 18, but I have never heard of a 21.
| | | Re: Thanks -
[Re: majsteve]
#28067 02/02/04 05:33 PM 02/02/04 05:33 PM |
Posts: 800 MI | Hi Steve keep us updated on the project ,think an 18 sq with spin would be GREAT , fUNNY how some of the A Class builders a decade or two earlier switched to the more powerfull and open development oriented 18 sqs | | | Re: Thanks -
[Re: Seeker]
#28071 02/04/04 12:27 PM 02/04/04 12:27 PM |
Posts: 12,310 South Carolina | I haven't compared pricing with fiberglasssupply (they certainly have the best motto!) but look at www.aircraftspruce.com as well. Their catalog has many more items in it than are shown on their website - they ship very quickly too.
Jake Kohl | | | Re: Thanks -
#28072 02/04/04 12:36 PM 02/04/04 12:36 PM |
Posts: 3,114 BANNED | although their prices probably aren't the best, I've had really good experiences with http://www.fibreglast.comThey do small quantities. I actually lucked out and found a defense dept. contractor in my hometown back in MD that builds those UAV drones. Quite a bit of CF weave goes into those apparently. I used to be able to pickup some sizeable waste scraps that suited my needs back when I was trying to make that boom. Sorry guys, don't have the hookup anymore | | | Re: Thanks -
[Re: majsteve]
#28074 02/05/04 09:21 PM 02/05/04 09:21 PM |
Posts: 14 Alberta, Canada | I do not know if you guys are interested in reading this or not. Preamble I successfully made a set of what I admit are pretty rough A-Class hulls using a layup of 5.7 oz carbon, 5 oz Kevlar, 3/8 inch Corecell foam, and 5.7 oz carbon going from outside to inside laid up in a female mold using vacuum bagging. On the first version of the hulls, I made the bows too skinny and the boat was scary going out in any breeze. The boat bows would dive when any kind of gust would hit, but it certainly had no trouble piercing waves. As long as the wind was steady, it would go through boat wakes very smoothly, exhibiting no hobby horsing at all. But when it was gusty, the bows would dive very easily. Due to the topside of the bows being almost pointed, the hulls could be driven in a bow down manner without showing any tendency to go under further, and as soon as the gust would let off, the hulls would pop up and we would continue along at full speed. I will certainly use this topside shape again.
I did not like this tendency to dive as I feared for my mast so in the middle of last winter, I dug out my skilsaw and cut off the bottom on one of the hulls. I spread the front by 2 inches near the bow tapering to 1 inch at the main beam . This caused some seperation of the outer skin from the foam due to the high stresses involved in doing the spreading. A carbon skinned hull is pretty stiff, so something had to give. I made new bottoms that are wider than the hull width at the front, and had a completely different shape than the old hull bottom, so had to fit pieces of foam to join everything together. Due to the inability to vacuum bag the layup when applying the final layer on the bottom once the bottom was glued on the top, several areas of the carbon did not attach well to the foam. It took several months of head scratching to figure out how to do the changes, and then once figured out, the second bottom was cut off and the new bottom glued on and finished within 2 weeks. All in all, I like the new hull shape and am considering making a new mold to make a good set of light hulls. My current hulls are over 50 lbs each due to several of the things I did wrong in the building process. I lost about 3 lbs each hull with the new bottoms that I put on. My next hulls will be built utilizing a lot of different design changes, and all the things I have learned, and should weigh about 35 lbs each. On my next hulls, I may use 4 oz unidirectional carbon fabric instead of woven. It is a bit cheaper, and the fibres will all be straight then which will provide greater strength. To get cloth on at 45/-45 degrees, it has to be overlapped 2 inches where there is a join, or you have to purchase fabric that is made on the angles. That proved pretty costly, so I overlapped the cuts with resulting bumps.
So here are some things to consider if you are making a set of hulls:
Try to make sure that you get the layup real dry, especially if you are doing multiple layers. Lots of epoxy means added weight with no structural benefit. When making beams or foils with multiple layers of fabic, the way I get a relatively dry layup is to wet out one layer, get it as dry as I can with a plastic sqeegee, put it in the mold or on the mandrel, and then take a second dry layer and put it over the first layer. If you use your hands or plastic spreader and work it a lot, you can get it to wet out with the excess of the first layer. It took several poorly made laminates with lots of wrinkles in the layup to get this method figured out. If the layup is too wet, the layers will move around easily, and it will be easy to get wrinkles in the layup, plus the excess epoxy gets squeezed out of som areas and into others so you get bumps. If you get wrinkles, you are probably not getting the fabric dry enough, so on the next piece you make, try for less epoxy!
When you are doing a multiple layer layup do not lay the vacuum hose over the layup as it will move the top layers of cloth and form them around the hose. Then when you pull off the vacuum layers needed, you will have a mess, having a nice half round track in the layup where the hose was. Trust me!
When using foam core material, do not put cuts in it to help it mold to the shape of the hull. As you have to fill the cuts in the foam with epoxy, plus the epoxy will fill a minimum of the outer 1/16 of the foam, it will require way more epoxy and make heavy hulls. I used 3/8 inch 4 lb core cell for my core on my hulls and used a heat gun to form the hulls to the shape of the mold. When it proved very resistant to bending by heat gun (too thick), I used knife cuts and then had to fill them with a microballoon epoxy mixture. I tried making a heater box first, with poor results as it took too much energy to mix the air around, and it would have cold spots. It would be possible to do it successfully, but you would need way more air movement than I tried with using 1 8 inch furnace ductto move the air from 1 end to the other. The top of the mold was real hot, and the bottom was cold, so the foam would not mold.
I was the most successful with using a heat gun to mold the foam about 1 sq ft at a time. Once the foam is close to the shape of the hulls final shape, the vacuum will be sufficient to get it the rest of the way. After my first design proved too skinny on the front, I made a new bottom using quarter inch foam and had a way better success molding it with the heat gun. My next hulls will be made with ΒΌ inch 5 or 6 lb foam.
If you are designing your own hulls, if you have hard chines in them, it adds to the complexity of getting a decent layup. Everywhere you have to cut the foam, it adds places that you have to spend lots of time making sure the core is perfectly fitted to the mold. A way of making a hard chined hull easier is to just glue on one skin at a time. Then if the core moves on you in the first vacuum bagging process, it is relatively easy to fill the gaps with microballoons and put the inside skin on. You will need double the amount of mastic and plastic you use for that though.
Make sure your mold has no pinholes in it. If it does, you will have voids in the layup where the air is coming in. These will not only have to be fixed but will likely leave a bump on the hull where the void was after you fill it with epoxy. Trust me on this!
Make sure the mold is fair before starting to build your hulls. If you are making a Cat, fairing the mold once is better than having to fair both hulls you make with a mold that is not fair.
I made my molds by cutting out frames for every foot, boxing them in with 3/8 inch plywood, and then using 1/8 inch mahogany door skins being tortured into shape of the frames. The door skins plywood did not like this, and would go to whatever shape it wanted between the frames. What I had to do is run a stringer down the length of the mold about 6 inches apart, and try to straighten out the skin. Then when the skin was close, I had to fair out the mold with epoxy/microballoons and sand till smooth. This used a huge amount of fairing compound (costly) and took vast amounts of time (read over a month), but I did not have to do the fairing twice and put more weight on my boat hulls. The Mold leak did require pulling off about 4 sq ft of carbon off the front of one Bow and replacing it. It made a mess of the bow and took more time and money. Do a good mold first thing!
What I would do for a mold now: I would cut out plywood stations every ft, make a box that is close to the size of the dimensions of the hull, buy stiff insulating foam in 2 ft by 8 ft by 2 inches thick sheets, line the box with the building foam, and then use a wood rasp or sanding block to shape the foam to the shape of the hulls between the frames. Once shaped, I would then cover with 3 or 4 layers of fiberglass cloth in epoxy and sand smooth, fairing with microballoons as needed. You would then have a fair, solid boat mold that you could tape a vacuum bag to and make your hulls. It would be a lot of work, but less than what I did, and should not have any leaks. I would also put a face of at least 3 inches wide on the top to use as a face to use the mastic on when vacuum bagging. It is pretty normal for me to get some amounts of cloth hanging over the edge when making a hull half. These have to be trimmed later, but can get in the way if you have made the mold face too narrow, and can cause sealing problems with the mastic. I learned to always have a tube of silicone sealant handy to use to fix leaks in the vacuum bag, and holes in the plastic can be fixed by applying a short piece of packing tape to the hole. For the plastic barrier, I just used heavy duty constuction plastic. It worked fine.
Another thing you have to watch for is getting a good vacuum. The pump is important in that it has to be capable of sucking a decent volume. When you use mastic, and it has a few holes in it, sometimes you cannot tell where the holes are if the pump does not suck enough volume to be able to hear a whistle. Make sure you use a good mastic, too. Sometimes I would use packing tape, and if careful, it can work. I found that 3M packing tape is so much better than the cheaper stuff that I will buy nothing else now. I purchased rolls of mastic from fibreglasssupply and I would do that again. It was real good stuff. When I ran out of that, I used some stuff that I bought from a glass shop that they use to install windshields. That was not nearly as good.
You can use any nylon that is breathable for the peel ply. If it is waterproof, it will also be epoxy proof and you will not be able to get the excess epoxy out of the layup.
For breather layers, I used quilt batting. Walmart prices are okay, but I found better prices at a discount fabric store later on. I sure got lots of funny looks going into the fabric stores for this stuff though!
For most of my layups, I used mastic applied around the mold face and gained a seal against the mold. On the last few things I made, I would just stick the piece in a plastic bag. Bags are easy to make using packing tape to seal off the edges. That sure worked easier as long as the bag has just a few holes in it. It seems impossible to get a bag with no holes in it, so you are always hunting for the leaks in the bag, and sealing them with packing tape. Having a roomy workshop would help that a bit.
When applying the plastic vacuum film, it is quite important to make sure that there is lots of extra plastic in pleats. If there is not enough, or the pleat is in the wrong spot, the plastic may not go into every crevice and then you can have a void in the layup.
I made 4 daggerboard halves before I got one suitable to use for making my mold. At first, I tried to make ones that I could use in a daggerboard. Finally, I made one that turned out good by gluing cedar to a plate glass, and then carving it and sanding it until it was the shape I wanted. I then covered it with one layer of fiberglass, and achieved a shape that was thin enough to be accurate. I then made a mold by laminating 7 or so layers of fiberglass on top of the shape I had made, cut out the foil shape in half inch plywood, and bagged it on top of the laminated fiberglass. When I made the cedar shape, I made it long enough that I could make each end the shape of the daggerboard tip, so I can make each daggerboard half by using opposite ends of the mold. That worked good.
When making something as big as a mold for a hull half, it is imperative that you are extremely accurate in the mold shape. Foam with carbon on each side does not like to bend at all, so any mold inaccuracies are not easy to fix. Even being out by as little as a sixteenth of an inch can make for joint problems., and ugly hull joins. I had thought that a sixteenth or even an eighth should be close enough, but my next set of hulls will have a simpler design and I will try to be extremely accurate. I wound up grinding a lot and adding layers of carbon for the joints.
I used bubble pack on one rudder layup. This is not a good idea. I had all these little bubble indentations in the layup that I had to grind out. I now stick with using 2 or 3 layers of quilt batting for breather, and it works fine.
I made my own beams on a 3 inch round aluminum tube. It is imperative when doing a thick layup like this to make sure that you get the layup dry so that it does not squirm under vacuum, and that you do not get any wrinkles in the peel ply. This will make wrinkles in the tube you are making. You will ether have to fill the wrinkles in later or grind them out. When making my front beam, I made it about 12 layers of 9 oz carbon thick with an additional 5 layers on the top and bottom. It was supposed to be about 10 layers thick, but was so wrinkled from using too much epoxy and other reasons that I had to fill in the wrinkles and put another couple layers on to get it close to smooth.
Getting too much epoxy in the layup seriously weakens the layup. With too much resin between the layers of cloth, the resin will crack and weaken the stucture. With the beams, I made them thick enough that they are okay, but it is way wiser to get the layup real close to the ideal of less that 50% resin content. One guy has suggested to me to weigh the resin to be added and make sure it weighs the same as the cloth, and only use that much. To make beams now, I would add 4 layers at a time, using the second and 4th layer to soak up as much epoxy out of the wetted out layers as I could. I might even try doing 3 layers and use 2 layers of cloth to soak up the excess out of the one layer of wetted out cloth. I have started making my rudders and daggerboards by making the skins first, and then adding the foam core later. To add the foam core, I butter it as lightly as I can, let it harden, and sand it, then glue it in. I think this will make it lighter and absorb less epoxy.
My next set of A-Class hulls will be made by lightly buttering the foam core and letting it harden before the skins are glued on. When using foam core, it soaks up a significant amount of epoxy, penetrating about a sixteenth of an inch into the foam. By buttering it real lightly, I hope to lessen the epoxy penetration, let it harden, and then sand it to make sure the skins will adhere to the foam. I had someone suggest using peel ply on the foam as a means of not having to sand after. That might work. Another means of not having to sand would be to not let the buttered stuff harden totally before gluing on the skins. Epoxy will bond chemically to other hardened epoxy up to a certain time limit. If the skins are glued on before that time limit is reached, the laminate should bond to the foam/epoxy perfectly in a much lighter layup. In talking with Ben Hall some time ago, he said that they made 2 hulls that were identical except for the weight. They took far more care in keeping the layup dry in the second set of hulls and the hull weighed over 5 lbs less.
Another thing to be aware of when making your own hulls is there will likely be a significant number of pinholes in the hulls outer skin. This can easily be fixed before painting by sanding the hulls, mixing some epoxy, and spreading it on the entire surface of the hull using a plastic spreader. If you make sure the spreader has no nicks in it and that you leave no ridges of epoxy behind, you will have a minimum of sanding to do after letting it harden, and it will fill all those pesky holes. If you try to paint the boat without doing this fill, the holes will show up in the painted finish and are almost impossible to fill any other way. So do the hull with epoxy. It is worth it. When you build rudders and daggerboards, you need to do the same thing. It will save you lots of time, especially if you get the layup real dry. The dryer the layup, the mor epinholes by the way.
Hope this helps! | | | Re: Thanks -
[Re: Conrad Q]
#28075 02/06/04 07:40 AM 02/06/04 07:40 AM |
Posts: 4,451 West coast of Norway | Whow, this is all really good advice! I just wish you posted this two years ago as it would have saved me a lot of work Thank you for posting such comprehensive information! Two small ideas. Instead of wet layup and vacumbagging, do some research on resin infusion instead. I have done some vacumbagging, but I'll try infusion on my next projects instead. A fiber/matrix ratio of 70/30 has been mentioned by infusion instead of about 60/40 as in wet layup and vacumbagging. It is also a much cleaner and less stressful technique (if you get it to work!). When doing one-off hulls, make the stations as you have done. But instead of torturing plywood to make a mould, use longitudional battens secured to the stations. Bend the foam (with heat) onto the form and infuse/vacum the inside with the proper glass/carbon/kevlar and matrix (epoxy, poly, vinyl) Install bulkheads and then infuse/vacum the outside. Check out http://www.fram.nl for some pictures and do a Google for resin infusion. Just my two cents worth of input on building. | | | Re: help
[Re: majsteve]
#28077 02/10/04 06:25 PM 02/10/04 06:25 PM |
Posts: 3,293 Long Beach, California | Probably have to convert your drawings to a jpeg format and limit the size. Most file formats (e.g., Adobe PDF) are not supported. What format do you have? Do you want some help trying to convert it?
An e-mail to your prodigy eddress bounced...
| | | Re: help 18 lines drawing
[Re: John Williams]
#28078 02/10/04 07:21 PM 02/10/04 07:21 PM |
Posts: 800 MI | http://www.catsailor.com/bb_files/28263-smnacra2.jpg Hi John hi Steve There is the post that Dick L provided earlier on the N 18 SQ basic lines . hope that helps John ,--great post on the Formula 14 new class and helping get it going ,-It should be a fun class and hope the final Formula 14 class rules allow for both a production boat class based largely on the Mystere 14 ,--and also an open category sub class of Formula 14s within as proposed on the F-14 forum . The concept is very much like the 18 sq meter class of earlier decades that can have a {production }boat like the Nacra as a part of it ,-or allow custom boats to be built with more development and interesting ideas added ,they used 2 categories . Hope you forgive my sometimes unusual sence of humor and small town outlooks and hope the concept of design measurement rating ,-improving it ,and it being much more intergral with these types of 14 16 etc Formula classes based in design measurement is beginning to make some sence .  ISAF provides the means of standardized measurement proceedures and required definitions which are the basis of these classes and the basic language used to understand them . http://www.schrs.com/schrsdiagrams.asp?id=boat But ,It is all just sailing ,--fun stuff , and try to go with the flow ,-but it seems N A is slowly backwardly going this general direction . You see it in the enthusiasm for the new F-14 class , and here in the interest in 18 sq ,-though old and in need of updating.  Steve ,-really like your new spin rigged version 18 sq as proposed , the added length to 20 is the right remedy for the added spin forces at work ,-but it is no longer an 18 sq ,-but isn,t with a spin added anyway,  though sounds really expensive with marstom mast and c f hulls . Do you have an estimated cost ? I would really enjoy building a developmental cat design again , though currently have a SC 15 --A H-18 plus another H-18 platform -a Mystral board ,-cayak -and Inter 20 - Would like to modify the SC 15 to Formula 16 class specs for my boys to potentially race ,--same with the H-18 ,needs a spin -snuffer and a modified category F-18 class to race in . Would like the Inter 20 to eventually become the basic of a Formula 20 comperable cat class for all 20 ft cats. Imagine a ht 20 will be out in future years comperable to the Marstom 20 or Ventilo 20 by MM . I did recently draw a basic set of lines for a planning hull spin rigged 18 sq , though would start with a 2 in = one ft --one meter type scale model first. The nice part of a 14 open F-class is the reduced costs in that size range being able to experiment with ideas and concepts inexpensively ,--relatively speaking ,-mainly by retrofitting existing parts and beams boards rudders etc from other existing boats - --which I have  I,d reall like a Formula 60 ALSO  ,-but that has to wait , unless you have a multimillion dollar sponsor set to go or I find one to send the team to race in the Euro circuit . http://www.parlier.org/site02/accueil/1024x768.html I,m ready ,--sign me up .  though most likely will settle for the Atlantic 1000 on 20s -- again
| | | Foam cores
[Re: Conrad Q]
#28079 02/13/04 06:59 PM 02/13/04 06:59 PM |
Posts: 11 Minnesota | One point that I would like to add to the post of "How To Do It" ...
if using foam, I recommend you NOT give the surface a sealing coat of epoxy.
You will wind up with a rough surface once epoxy cures, and must re-sand/fair it back down. If factory smooth finish is still there - don't worry about sealing it. If a cut and sanded surface is there, get an old iron (clothes type - don't use the wife's!!!) Try it on some scrap, but heat it to the point where running the iron over the surface of the foam, will heat, melt and smooth the foam's surface. This seals the foam, and even less epoxy is needed.
Picked up this trick via r/c sailing, where weight containment is even more critical on 1 to 2 meter multihulls than it is on 18 footer real boats.
Another thought, is to lay up foam strips similar to a strip kayak or canoe. Cut on bandsaw, and run edges through a jig on router table adding bead and cove profiles edges. These allow for the strips to fit together, but the rounded edge also allows for the strips to take on a curve without producing the gaps which need to be filled. Strip foam construction requires additional support to prevent the strips from bowing between your cross section templates - especially if you are using 1/4 inch thick strips. What is nice about this method of foam cores, is the ability to cut the strips to thickness needed - so in the hull area, you can use maybe 3/8 to 1/2 inch, while on the flatter sides or on deck areas not subject to loads, you can go down to 1/4 inch for core. A home made hot-wire to cut/shape foam is also very useful. Lots of plans on the internet. I used stainless steel fishing leader wire for the heated wire part and a small electric train transformer for the power supply to heat up the wire. This also leaves a very nice, smooth finish that doesn't take up a lot of epoxy. If you want to get fancy, you can use untempered 1/8 inch hardboard or thin sheet aluminum to make foil shapes. Once you cut the foil shape, the can be added to the front of round cross beams to fair in and give a nice result.
2,423
guests, and 262
