| Hobie Cat rental In Ruskin, Fl. #281592 01/14/16 08:08 AM 01/14/16 08:08 AM |
Posts: 4 | Hi all. I'll be in Ruskin next weekend and I'm really looking forward to getting out on a beach cat. I can't seem to find a website with info on rentals. Does anyone have any info they can share? My cat hasn't seen water for some years and I'm long overdue for some white knuckled hull flying Regards, Mark | | | Re: Hobie Cat rental In Ruskin, Fl.
[Re: Meistro]
#281594 01/14/16 02:04 PM 01/14/16 02:04 PM |
Joined: Jan 2007 Posts: 139 Hernando, Florida Mlcreek
Posts: 139 Hernando, Florida | Not Ruskin, but Bradenton Beach....
Coastal Watersports 1301 Gulf Dr N Bradenton Beach, FL (941) 778-4969
Forrest I-20 USA 645
" There ain't enough rum in the drum!"
[Re: Meistro]
#281599 01/15/16 09:47 AM 01/15/16 09:47 AM |
Posts: 5,590 Naples, FL | If you really want to sail hard, check in with the local sail clubs (Dunedin, Gulfport, Davis Island, TBCS, etc) and see if anyone there is sailing while you're down there.
If I recall, the H-18 has daggarboards and the H-16 doesn't? It may have wings, too.
I can't speak for this specific rental operation, but generally speaking the equipment isn't "race ready" and they'd probably frown upon you pushing the H-18 to its limit. The settings (mast rake, jib blocks, rudder rake) will be all wrong, too. And they likely won't want you fussing with it.
If the operator/owner is a sailor, you'll see the equipment is in better shape (like the Islander).
I rented an H-16 once in Key West and there were no trapeze lines (on purpose), and the hiking strap (if you can call it that) was far from adequate.
In many cases, a flying hull would indicate the renter has no clue what's going on and it's probably going to necessitate the rental operator to go out there and get you.
The Wave, on the other hand, can be quite fun in and of itself, even if you can't really get the hull up high. If the wind is up it will scoot quite nicely (again, sails and rigging probably won't be top notch) and you can practice your beach landings at full speed.
I got chased down by the operator (again in Key West) on a Jet Ski when I got their Wave flying a hull (4 people on board, three had to sit on the low side and it was blowing 18) who thought I was going to break something
Heck, I've seen them tow the Waves to the surf line by tying a rope to a 4-wheeler and dragging the thing (makes anyone who sails a high-performance cat freak out)
Longboat isn't known for huge surf, but the chop can be steep and nasty on a NW blow.
And 69 F water temp is pretty cold but tolerable if the sun is out and the air temp is around 80 F or so. If the weather is crappy, the operator may not even be around that day.
Not sure if any of that helps, but I hope you have a great trip down to FL.
[Re: waterbug_wpb]
#281600 01/15/16 09:50 AM 01/15/16 09:50 AM |
Posts: 5,590 Naples, FL | and if you really want "white knuckle" hull flying action, ask Forrest to take you out on his N20. That is one mean production machine.
[Re: Meistro]
#281603 01/15/16 12:25 PM 01/15/16 12:25 PM |
Posts: 3,969 | You're on vacation, not racing, and haven't sailed in a long time.
First choice: Hook up with a local fleet, as mentioned above.
Second choice: I'd go with a Wave, and pick a windy enough day to make it fun (10+ knots). Don't go out alone, because if you flip or fall off, they are very difficult to climb back aboard.
[Re: Meistro]
#281605 01/16/16 09:04 AM 01/16/16 09:04 AM |
Posts: 12,310 South Carolina | "You almost flipped it the whole time you were out there, your probably doing it wrong".
LOL
Jake Kohl | | | Re: Hobie Cat rental In Ruskin, Fl.
[Re: Meistro]
#281609 01/17/16 09:57 AM 01/17/16 09:57 AM |
Posts: 6,049 Sebring, Florida. | On the 'cold water' thing, bear in mind that in August, the Gulf of Mexico water temp is usually around 92, so for a Tampa local, 69 seems absolutely frigid. If you are used to sailing in water that's 50-55, then the 69 will feel like warm bath water.
Blade F16 #777
[Re: brucat]
#281616 01/18/16 09:57 AM 01/18/16 09:57 AM |
Posts: 5,590 Naples, FL | Shocking to us northerners, but people in FL actually close their pools in the winter...
Mike Or spend crap-loads in fuel to heat them to a chilly 78
[Re: brucat]
#281618 01/18/16 11:42 AM 01/18/16 11:42 AM | MN3
| MN3
Unregistered | in the 40's tonight here in clearwater.. not to many people using their pool this time of year (except the lunatic we sail with who swims every day of the year in his unheated pool) Shocking to us northerners, but people in FL actually close their pools in the winter...
Mike | | | Re: Hobie Cat rental In Ruskin, Fl.
[Re: Meistro]
#281619 01/18/16 11:45 AM 01/18/16 11:45 AM | MN3
| MN3
Unregistered | This is wet or dry suit weather. if you fall in, your gonna be very, very cold on the sail back to the beach unless you have the correct gear (and a dry set of it after you go swim) PS you can also rent trimarans in Dunedin (just north of clearwater) they are dryer, bullet proof and fun in good wind | | | Re: Hobie Cat rental In Ruskin, Fl.
[Re: ]
#281620 01/18/16 12:25 PM 01/18/16 12:25 PM |
Posts: 5,590 Naples, FL | I believe a cold front is rolling in this weekend, which can bring some "fun" winds... Renting a Weta or a Wave could be quite fun...
[Re: waterbug_wpb]
#281623 01/18/16 05:40 PM 01/18/16 05:40 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Shocking to us northerners, but people in FL actually close their pools in the winter...
Mike Or spend crap-loads in fuel to heat them to a chilly 78 Actually you just heat the hot tub not the pool.
[Re: waterbug_wpb]
#281625 01/19/16 10:15 AM 01/19/16 10:15 AM | MN3
| MN3
Unregistered | 70%chance of rain friday highs in the upper 50's for the weekend. water is currently below 60* wind in the upper 20's on sat Good weekend for a movie I believe a cold front is rolling in this weekend, which can bring some "fun" winds... Renting a Weta or a Wave could be quite fun...
[Re: brucat]
#281627 01/19/16 01:39 PM 01/19/16 01:39 PM |
Posts: 5,590 Naples, FL | 40 in Clearwater certainly would be nuts! For sure... I recall one Tradewinds weekend when a nasty front rolled through and it was 38 F in Key Largo Sunday morning (and blowing like stink)
16,837
guests, and 1,047
