| Samson Rope Flavored Ice #282569 05/02/16 08:44 AM 05/02/16 08:44 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | I can't find it in the online store, or the local chandelries. Anyone know how to get some? I need to cover a 3/8" cored line so it grabs in my spinlock.
I guess I could buy some 10mm rope and just use that cover, but the flavored ice looks much nicer...
| | | Re: Samson Rope Flavored Ice
[Re: wildtsail7]
#282592 05/09/16 06:30 AM 05/09/16 06:30 AM |
Posts: 5,590 Naples, FL | Maybe I'm looking at the wrong thing... the website says it is a cover only (no core) that i can use to beef up my 3/8" line so it doesn't slip in the rope clutch. My rope clutch can handle 3/8" as the smallest size, so it does slip occasionally when tensioned up (it's old and probably needs a new cam).
The line on there currently is 3/8" (possibly warpspeed II) with the extra cover where it grips the spinlock. Obviously serves dual purpose: won't slip in rope clutch and tells me when I'm at full hoist.
I have 3/8" Sta-Set X but need to beef up the clutch area with additional cover material...
I picked up a couple of feet of 7/16" cored and 1/2" cored line and will strip the cover off this to see if I can fit it over the 3/8" line and lock stitch/whip.
How do you determine what model a Spinlock is? I can't see where the model # or type is printed/listed on it, but it looks like an earlier generation than the ones in the store now.. They're probably 10 years old...
[Re: mikekrantz]
#282614 05/11/16 10:05 AM 05/11/16 10:05 AM |
Posts: 5,590 Naples, FL | Jay,
You really don't want to bulk the over over the outside. It will jam up entering the clutch. You need to insert line into the middle of the halyard to "bulk" it up. Try pulling 3/16" amsteel/dyneema into the core.
Also for the clutch to work best, bulk up to the max line diameter for the clutch rating. At the bottom end of the range, the rope will almost always slip. Interesting you said that Mike. I was just thinking the same thing (bulking up the core vs. the cover). My current 3/8" has the extra cover tapered over 40 cm or so which makes it gradual increase in thickness. But I do have some Amsteel (maybe even 3/16") I could jam in the core and taper a bit. I will say that core on the Sta-Set X is rather sticky when trying to extract through the cover. I can't remember what blend of fibers they are using (gold and white) but it took a while to get my shackle eye spliced up. Course, I may try that rope shackle doo-dad, but would that be recommended for a mainsail halyard shackle?
[Re: wildtsail7]
#282615 05/11/16 10:09 AM 05/11/16 10:09 AM |
Posts: 5,590 Naples, FL | I'd second Mike... but honestly I'd upsize to 7/16" for the entire halyard rather than bulking up. That's a good bit more expensive and what would be the benefit? Sounds like more weight aloft (I've got a 30 ft. run up the mast), I'm not sure what the working load is (this is cleated at the bottom, not hooked at the top like a beachcat)
4,506
guests, and 514
