Tornado by CameronB. 01/11/21 02:10 PM
| | | | trailer leaf spring corrosion #283090 07/19/16 01:59 PM 07/19/16 01:59 PM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | Since none of y'all have to dunk your trailers in salt water, I figure you don't worry about this, but for those that do, how to you reduce rust on your leaf springs?
Seems I have to replace mine about every 2 years as large flakes of rust start falling off them.
Rinsed after every salt water dip, and I spray PB blaster and/or WD-40 on them every month or so. Tried axle grease, too but to limited effect. Wondering if painting them would help, or someone's suggestion of melting toilet ring wax (melts around 160 F) and painting it on the leafs.
Yes, I must be cheap since a leaf spring set is like $30 USD each (every other year)...
| | | Re: trailer leaf spring corrosion
[Re: waterbug_wpb]
#283096 07/19/16 06:50 PM 07/19/16 06:50 PM |
Posts: 586 Hobart, Tasmania, Oz. | Are you using galvanized springs? Have them on the speed boat that goes in the water every weekend for about 6 months of the year, lasts 10-15 years.
[Re: Dazz]
#283105 07/20/16 08:10 AM 07/20/16 08:10 AM |
Posts: 5,590 Naples, FL | Interesting input. Thanks!
I am almost sure they aren't galvanized leaf springs given how fast they corroded. I thought they were painted, but if so it obviously didn't work very well.
I'll dig around the inner-net for galvanized leaf springs as well as that torsion bar.
My ony question regarding that torsion bar is how to detect it is nearing the end of its service life. I, for one, am not a big fan of catastrophic failures on interstate highways?
[Re: waterbug_wpb]
#283107 07/20/16 08:33 AM 07/20/16 08:33 AM |
Posts: 12,310 South Carolina | Interesting input. Thanks!
My ony question regarding that torsion bar is how to detect it is nearing the end of its service life. I, for one, am not a big fan of catastrophic failures on interstate highways? I don't believe they fail catastrophically. The interior tubing is large enough that it can't rotate inside the exterior tubing. The triangle shaped rubber pieces just provide cushion between the two and last a very long time. I'm nearly certain that the failure mode is that your trailer ride starts bottoming out steel on steel as the rubber deteriorates - but they have a reputation of lasting for a very long time.
Jake Kohl | | | Re: trailer leaf spring corrosion
#283108 07/20/16 09:00 AM 07/20/16 09:00 AM |
Posts: 5,590 Naples, FL | If it were only this easy.... but I'm not sure I believe everything I read. Still, if $22 USD buys me another year or two of salt water use...
[Re: waterbug_wpb]
#283109 07/20/16 09:07 AM 07/20/16 09:07 AM |
Posts: 5,590 Naples, FL | and would that salt-a-way crap they sell at West Marine do anything that fresh water (or soapy fresh water) wouldn't?
I have a manual garden sprayer I hose off the non-galvanized trailer parts (disc, calipers, leaf spring) after driving up the boat ramp...
[Re: waterbug_wpb]
#283110 07/20/16 09:11 AM 07/20/16 09:11 AM | MN3
| MN3
Unregistered | I recently used this on a trailer (not this brand) - It looked good - help sell the trailer - I have no idea if it's worth it but a guy I sail with uses it all over his trailer. He does back his trailer in often to get his gcat - he recommends this stuff If it were only this easy.... but I'm not sure I believe everything I read. Still, if $22 USD buys me another year or two of salt water use... | | | Re: trailer leaf spring corrosion
[Re: catman]
#283129 07/20/16 03:09 PM 07/20/16 03:09 PM |
Posts: 5,590 Naples, FL | Yes, I've tried various coatings (grease, etc) on the springs and aside from the nasty looks and hard questions I get from Marine Patrol when they see that rainbow develop the minute the trailer touches the water, I only get so-so results.
So I guess the torsion axle may be the most prudent way to go...
Next is to get the dang disc calipers to keep from sticking. No corrosion that I see on piston... must be the actuator (hydraulic surge brake) not returning all the way? How do the calipers adjust for pad wear?
[Re: waterbug_wpb]
#283132 07/21/16 07:03 AM 07/21/16 07:03 AM |
Posts: 12,310 South Carolina | Yes, I've tried various coatings (grease, etc) on the springs and aside from the nasty looks and hard questions I get from Marine Patrol when they see that rainbow develop the minute the trailer touches the water, I only get so-so results.
Next is to get the dang disc calipers to keep from sticking. No corrosion that I see on piston... must be the actuator (hydraulic surge brake) not returning all the way? How do the calipers adjust for pad wear? Fluid compensation. Just like a car. As the pad wears, the piston extends further (actually, it just doesn't retract back as far) and it holds more fluid in the caliper with the increased volume of the extended piston. Your fluid level in the reservoir will drop as a result. When you change the pads and press the pistons back into the caliper, you need to watch that the fluid doesn't overflow the reservoir if you have ever added any. You get ANY moisture (including air-born humidity) into the brake fluid system and it will pretty quickly lead to internal corrosion. The hydraulic brake fluid readily absorbs that moisture and, though not practiced by just about anyone, it's a good idea to change the brake fluid occasionally.
#283134 07/21/16 07:49 AM 07/21/16 07:49 AM |
Posts: 5,590 Naples, FL | Thanks Jake. I flush the fluid annually and usually have to change the pads about then, too... I'd bet there might be something going on with the actuator in the tongue that's setting me up for failure and causing those calipers to stick. The seal between caliper body and piston is still intact so as you said it may be the fluid causing the issue.
And Forrest I'll have to try that stuff, too. Being that I drop the boat on a ramp in the everglades, they get really hyper about any petrochemicals in the water. Even bearing buddies cause frowns on the faces of those dudes with guns and badges (although they probably have a chip on their shoulder anyway...)
I show them I use food grade grease which doesn't work as well as Red tacky #2, but I learned that from having to deal with the same issues on farm irrigation pumps dripping grease in the water canals..
[Re: samc99us]
#283148 07/22/16 07:52 AM 07/22/16 07:52 AM |
Posts: 12,310 South Carolina | Sam is talking about Boeshield T-9 which is probably the best product available to protect raw metal surfaces (It's THE product to protect cast iron tool surfaces). It dries to a tacky film and you may give it a whirl - that whole suspension environment, though, is just brutal on any coating or finish you can put on it.
#283157 07/22/16 02:02 PM 07/22/16 02:02 PM |
Posts: 5,590 Naples, FL | like the galvainized trailer frame?
And where does one score this mystical T-9?
37
guests, and 243
Mod | | Forums26 Topics22,384 Posts267,017 Members8,084 | Most Online1,650 Sep 10th, 2019 | | |
