| Re: Preval Sprayer and Flex-Mold
[Re: srm]
#283409 08/30/16 11:46 AM 08/30/16 11:46 AM |
Posts: 382 SE MI / NE IN | With regard to the Preval sprayers, one of my good friends (John Bauldry) uses them almost exclusively and had showed me how to do it. They work amazingly well for small jobs. Have to thin the gel with acetone to get it to spray smoothly. The acetone vaporizes before the gel hits the boat so it doesn't impact application very much.
As to the quality of the result - I did a decent size 4"x6" repair on the side of my boat last summer and I challenge anyone to find it.
[Re: rehmbo]
#283413 08/30/16 04:01 PM 08/30/16 04:01 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Actually I would use medium Lacquer thinner instead of acetone. Thin it just enough to get it to spray.
As far as the nonskid goes, I waxed a area of the good non skid and laid some lightweight glass on it and make my own pattern. Did it on a hobie 18 with fairly good results. Not perfect but good.
[Re: srm]
#283416 08/31/16 08:37 AM 08/31/16 08:37 AM |
Posts: 12,310 South Carolina | Not a bad idea regarding the non-skid. Considering I have 2 TheMightyHobie18's, I could just splash a mold off the good boat and use it to mold the gelcoat on the one I'm fixing.
sm You can also use 100% silicon caulk to make a non-skid pattern mold with...it has the added benefit of being flexible so you can apply that pattern to other areas of the boat that aren't necessarily the same shape as the area you made the mold from. You'll need some sort of mold release to get the silicon to remove cleanly...can't recall what the right stuff is at the moment, though. I'm sure the internet can help. Edit...welp, here you go: http://www.martha.net/2014/05/making-a-100-silicone-caulk-mold/
Jake Kohl | | | Re: Preval Sprayer and Flex-Mold
[Re: srm]
#283511 09/17/16 04:56 PM 09/17/16 04:56 PM |
Posts: 5,590 Naples, FL | not sure since I never used wax in the gelcoat mix, but that could possibly be it..
I've sprayed thinned gelcoat with the Prevail for smaller jobs with good results.
Thinned it to just a little thicker than car-paint consistency and sprayed several layers to build thickness (letting it flash off between coats), and then spraying that green stuff that smelled like chloraseptic to seal the top coat (mold release)
Course, I'm in the tropics (high heat/humidity) so flashing off took about a minute..
[Re: srm]
#283526 09/19/16 09:35 AM 09/19/16 09:35 AM |
Posts: 5,590 Naples, FL | Are you also using the Preval to spray the PVA?
sm use it in a separate prevail sprayer And car paint is usually thinner than house paint. Does that help? Think maybe hot pancake syrup?? Flows relatively quickly, but leaves a residue in the jar.
[Re: srm]
#283527 09/19/16 09:37 AM 09/19/16 09:37 AM |
Posts: 5,590 Naples, FL | Thanks for the reply, but not having ever worked with car paint, that description isn't all that helpful for me. Approximately what percentage are you using gelcoat to styrene? 50/50, 75/25, 90/10?
sm I can't be sure of the exact ratio, since the gelcoat/additives/pigment(s) I was using may be different than yours. I went for the viscosity rather than an exact ratio.
11,061
guests, and 293
