| G-Cat owners #283662 10/19/16 07:20 PM 10/19/16 07:20 PM |
Joined: Jun 2001 Posts: 425 Toledo, Ohio (western end of ... Mike Fahle OP
Posts: 425 Toledo, Ohio (western end of ... | Do the various size G-cats use the same mast extrusion? I need to source a replacement mast butt (bottom end extrusion) for a G-cat 5.7 and learn how these are rigged for raising the mast. Any help is appreciated as it is for the boat that we refurbished for a wedding gift and its new(lywed) owners.
| | | Re: G-Cat owners
[Re: jsb4g]
#283732 10/29/16 03:14 PM 10/29/16 03:14 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Lock the rudder down. Drill a hole for a #6 screw through the clip and between the tiller arm and the kick up bar. Use a couple washers and a nylock nut. Now snug up the screw. It will pull the clip together. You can now adjust the tension. Most people do both just to have it done with.
| | | Re: G-Cat owners
[Re: jsb4g]
#283733 10/29/16 03:16 PM 10/29/16 03:16 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I ended up buying the G-Cat 5. Now I am looking to replace a couple of things. What length/size halyard should I be using for jib and main halyards? I found a diagram and assembly manual, but no parts list. Also, I need a rudder retention clip for the port side. The current one does not stay down real well. Any ideas? I posted on Hans' FB page and he replied by giving me his email address, so I emailed him, but he has not responded to the email. I have a email with all the info. I'll look for it.
| | | Re: G-Cat owners
[Re: jsb4g]
#283748 10/31/16 08:59 PM 10/31/16 08:59 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Main halyard 26' of 3/32 7x19 wire. Jib halyard 17' 8.5" of 3/32 7x19 wire.
I don't have the measurement for the stop slug on the main. The best way to do that is to hoist the main and flip the boat over to crimp the Nico or mark the spot. This way you can be sure to get the main all the way up.
The only thing I would change is I would use 1/8" wire for the main.
Those measurements are center of pin to center of pin, P2P.
2,705
guests, and 415
