Removing the mast step #2862
09/27/01 07:43 PM
09/27/01 07:43 PM
Anonymous OP
Anonymous OP
Hello,
<br> Does anyone know how to remove the mast step on a Hobie 16 ? I feel the dolphin striker is somehow intergrated with it.... I drilled out the pop rivets and she will not budge.... Can anyone help me? <br><br>
2830- (45 downloads)
Re: Removing the mast step #2863
09/28/01 06:57 AM
09/28/01 06:57 AM
Florida
Hobiedoc Offline
Hobiedoc  Offline
Florida
It is not an easy procedure, but can be done. Must remove the dophin striker. Generally takes some hammering to get it out of one of the corner castings.[Leave the bolt on end of the long rod to protect the threads] Then keep working it out until it is out of the hole in the vertical rod. The vertical stainless steel rod is threaded into the bottom of the mast step. Since the rod is stainless steal and the step is aluminum, it takes a lot of liquid wrench, propane torch to heat and cool, and muscle to unscrew that vertical rod.
<br>
<br>After changing out the mast step be sure to reinstall the dolphin striker through the corner casting before riveting the mast base back on to the crossbeam.
<br>
<br>Good Luck<br><br>Stew Barcalow
<br>Fort Lauderdale
2837- (51 downloads)
Stew Barcalow
Fort Lauderdale
Re: Removing the mast step [Re: Hobiedoc] #2864
09/28/01 08:38 AM
09/28/01 08:38 AM
Anonymous OP
Anonymous OP
Thanks so much......<br><br>
0 registered members (), 275 guests, and 281 spiders.
