forestay length nacra 5.8 #286360
03/05/17 07:28 AM
03/05/17 07:28 AM
Pam62 Offline OP
Pam62  Offline OP
Does anyone know what the forestay length of the nacra 5.8 should be? I have a spinaker pole, no bridle and a roller. There is a almost new headsail but it is to long. Sometimes it doesn't furl properly because the headsail top touches the mast. Longer forestay?? Changing luff length??
Re: forestay length nacra 5.8 [Re: Pam62] #286361
03/05/17 09:22 AM
03/05/17 09:22 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Sounds like you have a Nacra 5.8 NA jib It will be larger than a regular nacra 5.8 jib. There will be 2 different forestays lengths the NA will be longer
A nacra 5.8 NA will have a bow foil
Re: forestay length nacra 5.8 [Re: Pam62] #286372
03/06/17 01:35 AM
03/06/17 01:35 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Hullflyer's spot on, you have a choice of buying a smaller jib or buying a bowfoil for the boat, the bow foil goes across between the bridal tangs and stops your bows pulling in. I would go the bowfoil path as the bigger jib is a big difference in performance but a small jib would be very cheap second hand if you could find one
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: forestay length nacra 5.8 [Re: Pam62] #286374
03/06/17 03:56 AM
03/06/17 03:56 AM
Pam62 Offline OP
Pam62  Offline OP
But with a bridle I'd to give my spinaker?
Re: forestay length nacra 5.8 [Re: Pam62] #286394
03/07/17 05:19 AM
03/07/17 05:19 AM
JeffS Offline
JeffS  Offline
There is a different spinnaker setup, where the pole attaches just under the bow foil, you have to be careful that the retrieval sock is back next to the bow foil or it becomes a crab catcher in waves, my previous 5.8 number 1626 had a chute retrieval on top of the pole where the sock went through the wire of the bow foil. The bow foil stops your bows from being pulled together and really prolongs the life of the boat
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
0 registered members (), 19,983 guests, and 654 spiders.
Most Online22,490
56 minutes ago
