| What's up with the America's Cup #286766 05/08/17 12:48 PM 05/08/17 12:48 PM |
Joined: Jan 2005 Posts: 6,049 Sebring, Florida. Timbo OP
Posts: 6,049 Sebring, Florida. | I just found some You Tube videos from "World on Water" that show the boys practicing in Bermuda. This is from yesterday and it also shows the pedal power training for ETNZ, they are going to use their feet instead of their arms to grind the hydraulic pressure. I'm wondering why they are using big heavy guys over 200lbs with big upper bodies instead of some out of work Tour De France types that only weigh 135lbs and can pedal harder, all day? https://www.youtube.com/watch?v=Yzh5VfDN80E
Blade F16 #777
| | | Re: What's up with the America's Cup
[Re: Timbo]
#286767 05/08/17 01:26 PM 05/08/17 01:26 PM |
Posts: 118 fl | easy - bicyclists are afraid of the water but now my baseless guess would be that they need "power lifters" vs. "endurance guys" I just found some You Tube videos from "World on Water" that show the boys practicing in Bermuda. This is from yesterday and it also shows the pedal power training for ETNZ, they are going to use their feet instead of their arms to grind the hydraulic pressure. I'm wondering why they are using big heavy guys over 200lbs with big upper bodies instead of some out of work Tour De France types that only weigh 135lbs and can pedal harder, all day? https://www.youtube.com/watch?v=Yzh5VfDN80E
Mn3
[Re: Mn3Again]
#286768 05/08/17 05:23 PM 05/08/17 05:23 PM |
Posts: 6,049 Sebring, Florida. | Look at how bow down they all seem to be when they are on the foils. At the beginning of that video you see the Brit team stuff a bow during a tack/gibe. At first I thought it was a Brit boat only thing, but later in the video you see all the boats are sailing like that, almost all the time when they are foiling. I wonder why.
Blade F16 #777
[Re: Timbo]
#286770 05/09/17 08:43 AM 05/09/17 08:43 AM |
Posts: 5,590 Naples, FL | I was curious about that bow-down hull attitude as well.
Perhaps it is the best way to keep the mast as vertical as possible? I presume with a wing you don't have as much mast rake as you would with a sail since the draft profile would be much different.
[Re: waterbug_wpb]
#286771 05/09/17 08:45 AM 05/09/17 08:45 AM |
Posts: 5,590 Naples, FL | in something totally not related (cuz i'm the king of hijack)... Timbo I've got the Naples - Key West race this week (Thursday down, Sunday back), so I could use your help next year if you can keep your calendar clear... & Carlos if he's still alive
[Re: waterbug_wpb]
#286775 05/09/17 01:11 PM 05/09/17 01:11 PM |
Posts: 6,049 Sebring, Florida. | in something totally not related (cuz i'm the king of hijack)... Timbo I've got the Naples - Key West race this week (Thursday down, Sunday back), so I could use your help next year if you can keep your calendar clear... & Carlos if he's still alive Remind me to bid it off next year, tell me around April 5th, when our May bidding opens! I just saw Carlos last Saturday, he's now in Miami going through 737 school, he'll be flying for Miami Air, and he's looking to move to somewhere down there. He might be available next May, heck, he may be retired, again, and again by then!
Blade F16 #777
[Re: mbounds]
#286776 05/09/17 01:14 PM 05/09/17 01:14 PM |
Posts: 6,049 Sebring, Florida. | The bow down attitude is the result of restrictions in the angle of the rudder foils and the different speeds upwind vs. downwind.
Upwind, the boats are relatively level; the boats are moving 25-30 kts. A higher angle of attack is required on the rudder foils to lift and stabilize the back of the boat.
Downwind, the speed increases to 35-40 kts; a lower angle of attack on the rudder foils is required to achieve the same lift, so the boats assume a bow-down attitude. I wonder why they don't change the rudder foil angle of attack by raking the rudders just a little bit, like they do the main foils, unless changing the rudder rake is prohibited by the new rules.
Blade F16 #777
[Re: Timbo]
#286777 05/09/17 08:38 PM 05/09/17 08:38 PM |
Posts: 1,884 Detroit, MI | changing the rudder rake is prohibited by the new rules. There's your answer. Limited to 3 degrees of movement. | | | Re: What's up with the America's Cup
[Re: brucat]
#286779 05/09/17 09:45 PM 05/09/17 09:45 PM |
Posts: 6,049 Sebring, Florida. | Yeah that seems like kind of a dumb rule considering they want a balls out foiling catamaran going as fast as possible, why restrict the rudder rake when so much other stuff is made for going fast?
Blade F16 #777
[Re: Timbo]
#286782 05/10/17 01:54 PM 05/10/17 01:54 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | For a detailed answer to the bow-down attitude watch this short video by Slingsby. Sign up for the Oracle Facebook page and get regular news videos from them. Really well done and some great video of them flying (and of Jimmy falling off ...again!). Facebook link to Slingsby explaining bow-downLatest news (May 10)...Oracle just capsized (again!) but no damage and nobody hurt. | | | Re: What's up with the America's Cup
[Re: mbounds]
#286784 05/10/17 11:03 PM 05/10/17 11:03 PM |
Posts: 6,049 Sebring, Florida. | changing the rudder rake is prohibited by the new rules. There's your answer. Limited to 2 degrees of movement. 3 degrees according to that video, but my question is, why are there any limits?
Blade F16 #777
[Re: Timbo]
#286789 05/11/17 02:38 PM 05/11/17 02:38 PM |
Posts: 5,590 Naples, FL | I'm sure part of the box rule that the defender put together. The question of "why" is probably best left to them.
Maybe to limit the design options (and part of the arms-race)? In doing so, they may limit the wide variety of performance between boats/designs and therefore keep the racing somewhat close?
[Re: waterbug_wpb]
#286790 05/11/17 02:40 PM 05/11/17 02:40 PM |
Posts: 5,590 Naples, FL | I am looking forward to the possibility of watching fleet racing at 40+ kts downwind.
Can you imagine flying toward C-gate with 4-6 other boats and closing speeds on opposite gybes approaching 70 knots? yeehaw! Talk about the tactician having an anyerism
[Re: waterbug_wpb]
#286791 05/12/17 05:50 AM 05/12/17 05:50 AM |
Posts: 6,049 Sebring, Florida. | These cats are what, 45 feet long?
And they are making nearly the same speeds as the 72' cats from 3 years ago!
Wow.
It used to be that a longer waterline made for a faster boat, but once they get up on the foils I guess it comes down to weight and sail area for determining max speed. Foil mechanics and control are becoming more important than waterline length.
Blade F16 #777
1 registered members (Axsip),
383
guests, and 97
