Re: New F14's [Re: Mary] #29210
02/09/04 06:15 AM
02/09/04 06:15 AM
I have the documentation on it at home, but from memory.
4.30 mtr. length (Aus is metric) = little more than 1 inch longer than 14 feet
0.5 * 4.30 width = 2.15 mtr. = 7 ft 2 inch
Same length to width ratio than Tornado, F18, F16. Will make the preformance with respect to these designs constant over the full range of windspeed when the rig is carefully chosen. This make single handicap number racing (dominant in Aus, EU and Asia) possible. No shifts when wind speed changes.
about 7 mtr. = Mast length, at least that was considered most likely but this dependents on the rig used
weight as low as 70 kg's = 155 lbs
We were leaning towards a cat rigged setup with indeed a furling headsail. Not because of the cat-rigged craze, but because the boats can be build lighter and cheaper without a jib. In this setup the boat needs a furling kind of headsail like a hooter to keep the performance around a course up, especiall reaching which requires a very flat headsail.
Mainsail + mast = about 12 sq. mtr. is a likely candidate.
With the numbers given above the F14 would arrive at about the speed of a P16 when double handed by two kids.
The F14 was/is put in the fridge because of limits in spare time and because it was considered too small a market to be succesful and economic viable.
However if you guys get it off the ground ....
Re: The 14 foot designs you talk about ... [Re: Wouter] #29211
02/09/04 06:44 AM
02/09/04 06:44 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
Mate,
Not sure what the "Glider" is.. The design I recall is the "Int 14".. Cat rigged one trap..
Re: New F14's [Re: Wouter] #29212
02/09/04 06:53 AM
02/09/04 06:53 AM
Thanks for your help, Wouter.
Re: The 14 foot designs you talk about ... [Re: Stewart] #29213
02/09/04 07:05 AM
02/09/04 07:05 AM
Will post picture tomorrow and than we can see if the Int 14 and Glider are the same or not.
Of course there are so many 14 ft designs in australia.
Re: The 14 foot designs you talk about ... [Re: Wouter] #29214
02/09/04 08:03 AM
02/09/04 08:03 AM
Victoria, Australia
Inland_Sailor Offline
Victoria, Australia
You can see the Glider here
http://takeoff.to/geminicatamarans
Magnum
Re: The 14 foot designs you talk about ... [Re: Wouter] #29215
02/09/04 08:55 AM
02/09/04 08:55 AM
I may be able to clarify the Glider Inter14 for you.
They are completely different boats by different designers.
The Glider is 4.0m and the Inter14 is 4.3metres.
The Glider can be configured with main jib and spinnaker while the Inter14 has a bigger main and to my knowledge no jib or spin.
Thanks, [Re: phill] #29216
02/09/04 09:06 AM
02/09/04 09:06 AM
How many of those 14 footers do you have down there in Aus ?
Arrow
Paper tiger
Alpha Omega
Int 14 catamaran (not the same as int 14 dinghy)
Glider
Taipan 4.3
Which am I forgetting ?
Aussie 14's [Re: Wouter] #29217
02/09/04 09:29 AM
02/09/04 09:29 AM
Victoria, Australia
Victoria, Australia
Woulter
There's also the
Windrush 14,
http://www.windrushqld.asn.au/
Maricat,
http://users.bigpond.net.au/graham_heap/index_maricat.html
TAIPAN 4.3:
To quote AHPC
"The newest and smallest of the Taipan's was launched at the Melbourne Boat Show in July 1999. This yacht is still in its developmental stages, but much interest from around the world is already evident.
The Taipan 4.3, A small, single handed catamaran, is aimed at the junior and intermediate catamaran recreational racing market."
I've posted a picture of the Tiapan, Check the links for the others ->.
Magnum
Re: I just ordered the Quattro 14 plans (Future F14?) [Re: Rolf_Nilsen] #29218
02/09/04 10:37 AM
02/09/04 10:37 AM
S. Florida
BRoberts Offline
BRoberts  Offline
S. Florida
Hi Rolf,
You have to be careful scaling an 18ft boat down to a 14ft boat because the displacement also scales down. For example if the hull length and width and height all scale down by 14/18, then the displacement, meaning weight carrying ability, scales down by (14/18)**3. This means the weight carrying ability of the 14ft boat would be 47% as much as the 18ft boat. You might need to go on a significant weight loss program.
Good luck,
Bill
Re: Aussie 14's [Re: Inland_Sailor] #29219
02/09/04 10:44 AM
02/09/04 10:44 AM
Bradenton, FL
Sycho15 Offline OP
Sycho15  Offline OP
Bradenton, FL
That Glyder looks like a hot little boat! By any chance is it a design that can be built from plans in wood? Where would be the best place to stretch the hulls .3M? Between the beams, at the bows, or the sterns?
I find it interesting that they stick with ~7' width. Are the roads just wider here in the US, allowing for 8'6" wide boats without the need for a tilt trailer?
NEW F14 Rules posted [Re: Sycho15] #29220
02/09/04 10:55 AM
02/09/04 10:55 AM
Bob_Curry Offline
Bob_Curry  Offline
Hey guys!
New rules on the F14 forum up for debate! We did listen to you and have reacted. Have fun!
Bob Curry
Re: Aussie 14's [Re: Sycho15] #29221
02/09/04 10:56 AM
02/09/04 10:56 AM
Unfortunately the Glider has to be built from a mould.
You could always buy the hulls and build up the rest.
It uses 2x2 industrial grade aluminium for its beams so it is easy to acquire. And a wing mast 6 metres long. Any broken carbon a class masts around. Alternatively a retired aluminium A class mast.
You would have to ship the hulls from the Central Coast of NSW (Aus).
As far as the raods go the max allowable towing width is 2.5m. The Glider has a 2 metre beam. It was set up this way so the boat is still exciting to sail. It does not carry a huge sail plan.
Bill, that just works out nicely [Re: BRoberts] #29222
02/09/04 12:10 PM
02/09/04 12:10 PM
18 foot with 150 kg crew and 180 kg boat = F18 = overall weight 330 kg
Using your rule :
F14 weight = 0.47 * 330 kg = 155 kg = 80 kg crew (singlehander) + 75 kg boat
Or 70 kg crew + 85 kg boat
Works out quite nicely
Tiapan 4.3 [Re: Wouter] #29223
02/09/04 05:24 PM
02/09/04 05:24 PM
Victoria, Australia
Victoria, Australia
Woulter
Sorry I forgot to attach the photo!!!!
[ See Company Profile section at AHPC]
http://www.ahpc.com.au/
Magnum
Re: Tiapan 4.3 [Re: Inland_Sailor] #29224
02/10/04 07:00 AM
02/10/04 07:00 AM
Inland_sailor,
I'm well aware of the Taipan 4.3 and AHPC.
As the Formula 16 class chairman (Also Taipan 4.9 spi) I have to.
Thanks for the effort.
0 registered members (), 2,780 guests, and 523 spiders.
Yesterday at 10:10 AM
