| Speed #30281 02/20/04 02:46 AM 02/20/04 02:46 AM |
Joined: Nov 2002 Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... Mary OP
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I hate to revisit this topic after the last thread where I got a little upset about people saying that small catamarans (20-foot max) cannot go faster than 22 knots. Now I have to say that this claim about 33 knots also seems totally unrealistic at the high end. The following is quoted from a story on the US Sailing website:
"The Tornado sailboat has the ability to reach speeds of 15-18 knots upwind and downwind, and 33+ knots reaching!"
It's ridiculous! I think the max possible speed (without hydrofoils) is somewhere in between, probably in the 25-26-27-knot range at absolute max, in high winds on flat water.
P.S. Why can't we get some good, on-water data on this so we don't have to operate on a myth basis?
| | | Re: Speed
[Re: grob]
#30284 02/20/04 03:58 PM 02/20/04 03:58 PM |
Posts: 805 Gainesville, FL 32607 USA | Speedometer? Yes- they come with the Rave foiler. Hollis Caffee somehow kicked his off by accident just before I took the Rave out. At least that is what I claim. I never saw it in action.
| | | Re: Speed
[Re: pitchpoledave]
#30285 02/21/04 05:49 PM 02/21/04 05:49 PM |
Posts: 800 MI | hI Mar , Gareth ,-Dave C , and pp Dave Would like to make it over sometime Dave ,-raced on Earie and Lk Ontario a number of times in past years on the Ohio side and in CAN ,--Rondeau Park CAN ,-raced the CAN h-Natls one year , was at the Hobie 18 Worlds in Toronto --80s ,- been to Kingston ,-etc --always fun . The Marstom 20 and web site claims a 30 knot GPS verified run . which seems credible http://www.sailcenter.se/administration/Boats/M20/index.asp
| | | That is not correct
[Re: grob]
#30289 02/22/04 07:16 PM 02/22/04 07:16 PM |
Posts: 9,582 North-West Europe | If the boat is in a tidal flow than the wind when sailing on one side appears to be stronger than when sailing on the other sides etc.
It all comes down to relativity guys.
Only thing that will trully work is having to measurement ; One absolute and one relative and deduct the one from the other to calculate the flow and then compensate all calc for the flow.
| | | Re: Speed
[Re: grob]
#30290 02/22/04 09:08 PM 02/22/04 09:08 PM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen
Posts: 270 Nepean (Ottawa) Ontario Canada | Grob
I just did something a bit uncharacteristic of myself. I read the whole advertisement.
It has an impellor. They say there are 2 ways to mount it. The cheaper model (believe it or not) transmits the data (wireless) however the two parts must be max of 20 to 50 cm or 2.54 cm = 1 inch so 8 to 20 inches apart.
I have visions of the impellor getting smucked by something in the water or during beaching. Also anything like that will be affected by the flow around the boat as the water is probably accelerated as it is pushed aside by the hull.
Also you would need two as when you are flying a hull the other is 'blowin in the wind".
Maybe the answer is to get the CIA to track you on satellite. According to all the movies I have seen lately they can probably do that better than finding Osama.
I am a real serious guage weenie and would love to have some kind of guage for wind speed, water speed and depth of water. Unless you are blessed with a sailing buddy or a regular group of racing friends it is hard to guage the results of little tweaks etc on the speed of the boat.
I suspect GPS is the best bet.
The depth of water guage would of course have to be forward looking, as nothing is more useless than the depth of the rock you have just hit. I suspect some kind of fish finder might be the trick.
Now of course all of this gear would have to be cheap and ultra reliable.
Cheers Alan F
Tiger
| | | Re: Speed
[Re: Frozen]
#30292 02/23/04 06:17 AM 02/23/04 06:17 AM |
Posts: 12,310 South Carolina | I've heard of guys that dangle the impeller by a wire between the center of the two hulls - that way when you are flying a hull you will still get a reading.
Jake Kohl | | | Re: Speed
[Re: davidtilley]
#30293 02/23/04 09:50 AM 02/23/04 09:50 AM |
Posts: 270 Nepean (Ottawa) Ontario Canada | I wondered about that.
Aircraft when they are a wingspan (tip to tip) or less from the ground enjoy the benefits of ground effect. Some people call it a cushion of air. I could go on and on about it but essentially when you get closer to the ground the wing becomes more and more (geometrical progression) efficient. The air is compressed. So you can take off at a lower speed than you can fly at.
Cheers Alan F
Tiger
| | | Re: Speed
[Re: Frozen]
#30295 02/24/04 01:00 AM 02/24/04 01:00 AM |
Joined: Oct 2002 Posts: 82 Minneapolis, Mn Wrinkledpants
Posts: 82 Minneapolis, Mn | Hi all, I've used to have the one they advertise in Murray's called speedmate. Yes the is a line that dangles in the water and though it's not weighted, is somehow always stayed about 4 inches underwater. It was relatively accurate i guess but it has many short falls. 1. If you mount the unit towards the front, sometimes the cord would get tangled in the rudder and then it's not always easily visible from the back of the tramp. 2. If you mount it somewhere towards the back, you end up snagging it onthe mainsheet, tiller, and occasionaly yourself. 3. The bay i sail through is merky and has lots of crap floating around, so sometimes something would hit the propeller and jam it. No damage to it, you just have to reach down and pull the cable out of the water to clear it. If you really want something to accuratly measure speed, distance, etc. I would get a GPS. If you get one that is WAAS enabled, then you get an incredibly accurate reading. Even now, most GPS's come with some sort of mapping data. Garmin has a select few units with what they call blue chart capability (basically marine maps on your gps) So though you won't get a direct reading of your depth, you can look to see the contour lines you are between. I never leave home without mine (Garmin 76s). I velcro it to my fore arm and at a quick glance can see where i am on the lake, my speed, and my direction. Extreemly helpful if you need to call for emergency help because you can rattle off the lat and long for quicker rescue. To me, i didn't like the fact of having something dangling behind me and then having to be in a certain spot to read what it said. GPS is far more useful. Just my few cents  ~Reid Lake Superior N5.2 | | | Re: Speed
[Re: Mary]
#30296 02/24/04 01:04 AM 02/24/04 01:04 AM |
Joined: Jan 2004 Posts: 2 Bremerton, Washington mcollier
Posts: 2 Bremerton, Washington | I have been using a small portable GPS unit while sailing my F18 boat. I have tested the GPS against odometeters and measured courses. I once competed in open class rallies and learned to verify odometers and even this fairly inexpesive model is accurate to about a 1.5% or less error, in measuring speed.
I had a friend attempt [color:"blue"] [/color] to measure the speed of my boat with a RADAR gun, but had difficulty getting accurate measurements from a fiberglass, kevlar, mylar, and aluminium target.
Another advantage in the portable GPS units, is choice of speed measurement displays. Most units allow KPH, Knots, or MPH display.
I usually have mine set on MPH, and have clocked a high speed of 31 MPH in 25 MPH winds.
Mike | | | Re: Speed
[Re: Mary]
#30300 02/24/04 01:14 PM 02/24/04 01:14 PM |
Posts: 48 Toronto | Now now ... No need to get upset :-) I had also posted some comments off that thread thinking(I was sure at the time) I had seen a Nacra 5.5 doing 26+knots(via GPS). I have since found out it was not 26knots but more like 22  . Ever drive a car at 25 knots and open your door to have a look at the ground, or telephone polls flying by. Makes me wonder if that guy wasn't closer to the truth. I'll just have to get together with 'pitchpoledave' this summer and do some fun speed trialin' on beautiful West Lake. Marc | | |
4,387
guests, and 470
