| Re: kite sailing, anybody tried it?
[Re: CapmWoody]
#30559 01/04/05 03:01 PM 01/04/05 03:01 PM |
Posts: 1,200 Vancouver, BC | If you are thinking of the KiteShip type setup, then they can be attached anywhere you think is strong enough. On a beach cat, a good place would be on the main beam at the inner gunwales. Perhaps with a turning block at the bridle tangs. You don't want to attach to the mast, as the point is to eliminate the heel moment. When we set this up on Afterburner (a 52ft beachcat) we used a halyard line on the mast to control kite height when launching/recovering. Everything else was at deck level. See www.KiteShip.com for details on their systems. Mike.
[Re: flumpmaster]
#30563 01/04/05 06:54 PM 01/04/05 06:54 PM |
Posts: 805 Gainesville, FL 32607 USA | The Texas City story is old now. WHat happened with Einstein and his kite-cat? Dave Culp and Kiteship are not really interested in beach cats. Does anybody know about Robby Naish's gear, and appropriate kites for beach cats?
[Re: dacarls]
#30564 01/04/05 08:23 PM 01/04/05 08:23 PM |
Posts: 1,200 Vancouver, BC | Dave Culp and Kiteship are not really interested in beach cats. I wouldn't say that...he was hounding me at one point to try one out on my Tboat. I think he will respond to anyone who want to experiment. Trick will be how to work out a control system so one man can launch/steer/retrieve the kite while the other steers the boat.
[Re: Frozen]
#30573 01/21/05 09:17 AM 01/21/05 09:17 AM |
Joined: Jan 2005 Posts: 31 Perth Western Australia harryproa
Posts: 31 Perth Western Australia | G'day, Outleaders ( www.kiteship.com) are different to board kites. They are launched from the boat not the beach and they do not have anywhere near the power zone. They are 20-50% more effective than a spinnaker due to flying higher in clearer, stronger air and not being affected by other sails or the boats motion. Mostly though, they are safe. All the lines lead to the deck, so there is no heeling or nosediving. Biggest worry is getting airborne, more a problem on a beach cat than a large cat. They have been used on big, slippery tris, a dismasted Newick was bought back from the Carribbean under a kitewhich was smaller than their assymetric. Went just as fast as the assy and main. They don't need winches. We launched, flew, gybed and retrieved a 420 sqm/4,515 sq' Outleader on AAPT, a 20m/66' skiff in Sydney without once winding a winch. You do need snubbers, I have a bank of sawn off hardwood fenceposts mounted on a piece of 12x2 timber for my small kite. This can be strapped to a cross beam, a seat or a hull. Conventional assy's have an aspect ratio of about 2:1. They are twice as high as they are wide, triangular and area is limited by the height of the mast/luff. 9m mast, max area is about 20 sq m. Outleaders are 1:4. Max hoist is 9m, but the max area is 162 sqm! And don't forget, they do not cause heeling or nose diving! Outleaders are just getting going. As more and more hotshots use them, so will the techniques for flying them improve. Afterburner's first experience was not a good one. The Kiteship team will be sailing with them this summer to reverse this. None have been used on beach cats yet, although I will be trying my 40 sqm/430 sq footer on my 7.5m/25' proa http://www.harryproa.com/Elementarry/SailingPhotos_4.htm in a couple of weeks. Will let you know how it goes. Peter Lynn's little cat was an awesome beast. Peter told me where to sit, how to steer with the pedals and how to trim and steer a kite. I climbed on, sailed off the beach (4 fixed stainless steel rudders, turned on a dime), through the surf and back and forth, upwind and down, for an hour or so. No problems, enormous fun. This was the first time I had used a kite, or steered with my feet. He was developing a 6m/20 footer while I was there, and I think he is now selling these. regards, Rob | | | Huh, fact check !
[Re: harryproa]
#30574 01/21/05 11:26 AM 01/21/05 11:26 AM |
Posts: 9,582 North-West Europe | You should do some fact checking on your info Rob, Mostly though, they are safe. All the lines lead to the deck, so there is no heeling or nosediving. Biggest worry is getting airborne, more a problem on a beach cat than a large cat.
More people have gotten killed by going airborn under a kite than by flying an assymetric spinnaker. As a result power kiting and buggy kiting are banned on the Dutch beaches and waters now. They may only sail at certain reserved spots and after acquiring a license. For buggy's you'll now need an official (landyacht) pilot license and you must do an exame for that. 420 sqm kite on a 20m/66' skiff
20-25 sq.mtr is enough to fly 75-90 kg human beings (paragliders) so 420 sq. mtr. is enough to fly 1500 kg. How much did that 20 mtr skiff weight ? So what do you mean exactly by "more a problem on a beach cat than a large cat." Conventional assy's have an aspect ratio of about 2:1
Maybe on mono's but not on beach cats F18 => (8.25)^2/21 = 3.24 aspect ratio Tornado => (8.75)^2/24 = 3.19 aspect ratio F18HT => 9^2/20 = 4.05 aspect ratio None have been used on beach cats yet,
- 70's and 80's experiments http://www.cobrakite.com/jaclad.html- 80's world record set by Tornado platform with a kite "Kite boats are already allowed in speed sailing. A world record was set and held for 7 years by a kite powered Tornado, back in the early 1980's" Source : http://www.sailinganarchy.com/innerview/2003/daveculp.htm They are 20-50% more effective than a spinnaker due to flying higher in clearer, stronger air and not being affected by other sails or the boats motion
Issues with kites : - Try sailing under bridges or power lines - Try bouy racing with them - Try to stay in the water with them (not get fully airborn) - Try sailing upwind with them - The sagging of the lines transmitting the force is a serious problem in upwind sailing or high speed sailing. With respect to efficiency of kites. Yes they are theoretically and practically more powerful than assies, however they (used to) have rather bad lift to drag ratios and are (were ?) far less attractive upwind dan normal sails. This ratio and the sagging of lines also impeded very high speeds. Landspeed records and water records (boats and surfboards) are once again set using conventional masted sails. Kites are quite interesting but they are far less new or promising than some make them out to be. Wouter (Yes I did a stint at kite flying and building as well, several years back I must admit)
22,041
guests, and 407
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,788 57 minutes ago | | |
