Cleaning hulls #30641
02/28/04 10:06 AM
02/28/04 10:06 AM
Memphis, TN USA
hobie16dude Offline OP
Memphis, TN USA
I recently acquired some really nasty stains on my hulls while lake sailing. I tried "Star Brite" hull cleaner, wax, and even Simple Green cleaner, they didn't even come close to doing the job... Someone told me to try Comet cleaner. Is that safe for the finish? I don't race yet, so I was going to finish off with a good coat of wax... Has anyone tried the Teflon hull finish? Would that cut down on my hull stains?
Have a Hobie Day!
Re: Cleaning hulls [Re: hobie16dude] #30642
02/28/04 03:50 PM
02/28/04 03:50 PM
Daytona Beach FL
TheoA Offline
TheoA  Offline
Daytona Beach FL
West Marine (As much as I hate them) has some kind of acid chemical that literally took the stains off my hulls in seconds. Just don't breathe the stuff.
94 N5.5SL
Re: Cleaning hulls [Re: hobie16dude] #30643
02/28/04 04:58 PM
02/28/04 04:58 PM
Colorado
SteveT Offline
SteveT  Offline
Colorado
I had an older boat with stained hulls and used Soft Scrub with really good success. Comet is pretty abraisive and can leave nasty scratches. Soft Scrub has very mild abraisve backed up with bleach. For particularly tough areas I used a random-orbit sander with soft scrub and went very, VERY easy on the pressure. Once everything was clean and well rinsed I applied a fiberglass sealer then a wax. The result was pretty good considering the boat was 10 years old and had traveled a lot of road and water miles. The one precausion is to go easy on repaired areas or anyplace the gelcoat might be thin. Abraisive cleaners, even mild ones, take off a microscopic layer of material each time you use them and can remove a thin layer of gelcoat over time. Also, wear something you don't mind getting bleach on. Your favorite regatta T-shirt could get wrecked in this cleaning process.
H-20 #896
Re: Cleaning hulls [Re: hobie16dude] #30644
02/28/04 08:47 PM
02/28/04 08:47 PM
Anything with oxalic acid in it (Davis FSR, Zud, Barkeeper's Friend) will work wonders with stains, especially those picked up from tannins in water (brown lake stains).
Re: Cleaning hulls [Re: mbounds] #30645
02/29/04 05:25 PM
02/29/04 05:25 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I agree on the 'soft scrub', oxalic acid, West Marine's, etc.
But there was a thread on this a year ago, and EVERYONE, talked about how this toilet bowl cleaner, I think it was called SNOBOL, was THE ticket!
F-18 Infusion
#626- SOLD it!
Re: Cleaning hulls [Re: Todd_Sails] #30646
02/29/04 09:45 PM
02/29/04 09:45 PM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
Try halving a lemon and rubbing it on the hulls. Cheap and works well for me.
Bern
Re: Cleaning hulls [Re: hobie16dude] #30647
03/01/04 09:09 AM
03/01/04 09:09 AM
I've used FSR (even helped with a rust stain or two), and do use a teflon based polish on the hulls. Makes things look great, and as I am a believer in "clean is fast", I think it helps. Of course, the effort to polish/wax the hulls is somewhat tantric in itself, which probably helps in getting your boat "zen". All those little chips and dings you see/fix while doing this probably helps...
The only drawback with the teflon based waxes/polishes (from what I hear) is that it may be hard to do small scratch repairs due to the teflon coating (probably have to remove it first with light sanding) but I've never had a big problem. Of course, handling a wet hull on the trailer is pretty dang slippery, too!
Even though I may not finish first, I finish looking good!
Re: Cleaning hulls [Re: hobie16dude] #30648
03/01/04 07:16 PM
03/01/04 07:16 PM
Memphis, TN USA
Memphis, TN USA
Thanks for all the help! I tried Soft Scrub, good results,without alot of elbow grease... It is raining here in Memphis all week, so it looks like I get to put off applying Teflon for another week...
Have a Hobie Day!
Re: Cleaning hulls - Sno-Bol [Re: Todd_Sails] #30649
03/01/04 11:02 PM
03/01/04 11:02 PM
Maryland, USA
PRagen Offline
PRagen  Offline
Maryland, USA
Sno-Bol toilet cleaner works wonders for brown water stains. See attached photo and notice the 2 brown areas I left for last.
Just wipe on, wait a minute or two and rince off. It takes off all wax also. You will need to re-wax.
Patrick Ragen
Taipan 4.9 USA 274
0 registered members (), 2,592 guests, and 551 spiders.
