| Re: Singlehanded with spinnaker
[Re: ceitzi]
#30692 03/02/04 02:05 PM 03/02/04 02:05 PM |
Posts: 1,200 Vancouver, BC | I've recently sailed Tornado single handed with spinny. It is a real challenge. I've only launched the spinny in light conditions while single. Seems to me, the main can be left cleated and near the centerline position, as heeling force will come from the spinny. Just keep the main and/or traveller line close/easy to reach as a last resort if you want to release it in a hurry. Plus, the spinny needs constant adjustment as puffs hit and apparent wind angle changes. Remember to head down in the gusts to control it. Easing the sheet as you head down only helps keep the power up, which is the opposite of what you want.
Enjoy! Mike.
[Re: ceitzi]
#30693 03/02/04 03:06 PM 03/02/04 03:06 PM |
Posts: 371 Michigan, USA | Ceitzi, I cleat the mainsheet (also near centerline) but keep some slack and a finger through it with the hand holding my tiller (keeps it easy to find). I hand hold my spinnaker sheet. If I feel the need to let things go, I release the spinnaker first, then the mainsheet. This goes for heading up to avoid obstacles or when the hull comes up too quickly and bearing off isn't correcting the problem adequately.  I heard of a particularly good skipper sailing the Inter 17R who cleated the spinnaker sheet and "pumped" the main (not sure if he pumped the sheet or traveller) to keep the boat going fast. I haven't found this easy to do.
Les Gallagher
[Re: Berthos]
#30695 03/03/04 07:22 AM 03/03/04 07:22 AM |
Posts: 3,528 Looking for a Job, I got credi... | I heard of a particularly good skipper sailing the Inter 17R who cleated the spinnaker sheet and "pumped" the main (not sure if he pumped the sheet or traveller) to keep the boat going fast. I haven't found this easy to do. I am about to adopt the cleating Spi Sheets on my Inter 17 Euro. to allow me to play with the mainsheet tension and Traveller as required. I think I will probably adopt the following: Always (except for very short periods) have the Tiller in my Aft hand. Cleat Spi sheets to allow changes to mainsail sheet or traveller only. I currently believe that you will have more gain by playing the Kite Sheets to achieve VMG on a dead run. I also believe that when trying to make a mark on a tight(er) reach the only way to gain hight is to dump the traveller. My 2 penny worth anyway....
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Singlehanded with spinnaker
[Re: scooby_simon]
#30696 03/03/04 10:24 AM 03/03/04 10:24 AM |
Joined: Jan 2004 Posts: 430 Virginia Beach, VA Thomm225
Posts: 430 Virginia Beach, VA | Ceitzi,
A tornado is a pretty powerful boat to be singlehanding with a spin. That being said, on the I17R, I and most of the guys I have sailed against, cleat the main ( to save the Mast!) and work the spinnaker sheet. To point higher, like Simon says, let the traveler down. On distance races on long spinnaker runs, we cleat the main, cleat the spin sheet, go to the back of the boat, trap out with foot in strap. Boat is controlled with traveler only! You may want to say a short prayer also before during this!
Tom Turlington I17R #124
You could work the main also to point a little more I guess ....... | | | Re: Singlehanded with spinnaker
[Re: Thomm225]
#30697 03/03/04 02:08 PM 03/03/04 02:08 PM |
Posts: 5,590 Naples, FL | I would tend to agree with you, Thom, cleating the mainsheet would tend to keep the "backstay" on for the mast. Not that I have seen any masts crumble from this, but I know there are many expert sailors that do not advise releasing the mainsheet while the spin is up or under load. I think this has something to do with the height of the spinnaker bail above the forestay/shrouds (unsupported). Mr. Roberts (ARC/SC) had a rule of thumb posted somewhere on this topic.
I don't singlehand often (much less race that way), but in a jam the traveler is usually the first to go (it's easier to recover afterward). Big jam and the spin sheet goes. Bigger jam, and the boat goes over anyway!
2,448
guests, and 420
