| Re: Hydroptere with foils
[Re: John_Ilett]
#30928 04/29/04 08:58 PM 04/29/04 08:58 PM |
Posts: 1,307 Asuncion, Paraguay | If I understood correctly, you are saying that the progressive reduction of foil chord reduces the amplitude of up and down movement. Makes sense to me.
I saw the photo in the foiled Moth of your construction (I guess) and would like to ask something:
Could you elaborate on the reasons why many Moths use eliptical tips? In the US there is a tendency to make them square.
Thanks, Luiz
Luiz
| | | Re: Foilcats
[Re: Darrin]
#30930 05/13/04 04:03 PM 05/13/04 04:03 PM |
Joined: May 2004 Posts: 1 Sussex UK WeymouthSpeedWeek
Posts: 1 Sussex UK | Just wishing to wave the flag for Joddy and George Chapman who have developed Ceres, one of the most well sorted foiling cats I have ever seen. Regularly sails at close on twice the wind speed (see the results for sail number 141 at Weymouth Speed Week 2002 SpeedSailing.com) A few details about Ceres and links to further information. Ceres . Regards Nick Povey | | | Re: Foilcats (a different foiled item)
[Re: Darrin]
#30931 06/07/04 02:54 PM 06/07/04 02:54 PM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | I was playing on a foiled "Sky Ski" board yesterday. The foil on this contraption is about 3' long. It is amazing how the slightest movement will make it jump one way or another. Just taking your hand off the rope to scratch your nose would mean an instant wipeout. My friend is better at this sport and can control it easily, but it does take a long time to master. I like to refer to the control as "touchy-feely". Not sure how different the foils on a cat would be, but I think that I would want a computer doing the thinking for me to maintain control. Jack Hoying Fort Loramie, Ohio
Jack Hoying
Fort Loramie, Ohio
[Re: Frozen]
#30933 06/09/04 05:23 PM 06/09/04 05:23 PM |
Posts: 349 Fort Loramie, Ohio | Yes, you do have a seat belt on. Wipe outs are usually easier on the body than regular water skiing. The nice thing about it is that it doesn't take a whole lot of physical effort to get up and to ride it. This makes the learning process a whole lot better, since you can try a bunch of starts without being to whipped to hold on to the rope. After you master the starts, you pop up with ease. Here's a couple photos I took of my friend trying to do 360s, both of which were unsuccesful. For more information, do a Google search for Sky Ski, or Air Chair (two brand names) Jack
Jack Hoying
Fort Loramie, Ohio
| | | Re: Foilcats
[Re: dacarls]
#30934 07/02/04 12:25 AM 07/02/04 12:25 AM |
Posts: 1 | ...Eppler 817 and Speer's foil shape H105 are PROBABLY best for hydrofoil sailing: These are low rise, low bucket shapes that should not ventilate readily at our speeds. Caveats: Supercavitating foils and/or air injection are for high-powered motor-driven vessels only. Sharp entry symmetrical foils like the NACA0012 series ventilate readily. I know this for a fact!... FYI, here are the cavitation diagrams for the E817 and H105 plus a NACA 6-series section. These data are not found on the NASG site. Ventilation, of course, is a different animal. You need to have separated flow to cause ventilation, so that may be a good place to look. I don't know why the NACA 0012 would be particularly ventilation-prone - I'd expect it to be more resistant. But maybe there were some details of the actual foil configuration that caused the flow to separate. | | | Re: Foilcats
[Re: Tom_Speer]
#30935 07/02/04 01:47 PM 07/02/04 01:47 PM |
Posts: 805 Gainesville, FL 32607 USA | Thanks Tom,
Could you please add a Clark-Y shape to that interesting figure? My original NACA 0012 aluminum struts would ventilate badly when presented at high speed at any angle more than a few degrees to the water: These Aluminum struts were probably not really NACA 0012 because they had been extruded too thin, and had very sharp leading edges.
| | | Covered Orma 60 foils
[Re: Darrin]
#30936 07/05/04 06:50 PM 07/05/04 06:50 PM |
Posts: 1,307 Asuncion, Paraguay | I read that the Orma 60 tris covered their foils in the dock after the Transat. Does anyone know of a new idea or concept that could be so important to justify the covers and extra work to hide the foils? I don't believe it was just for protection.
Thanks!
Luiz
| | | Re: Covered Orma 60 foils
[Re: Luiz]
#30937 07/06/04 04:03 PM 07/06/04 04:03 PM |
Posts: 805 Gainesville, FL 32607 USA | I also noticed that the new planing/foiling cat from France with curved lifting foils placed poorly: He hit something and damaged one foil early on. Did this make a big difference? Does this concept really work?
[Re: dacarls]
#30938 07/06/04 09:44 PM 07/06/04 09:44 PM |
Posts: 1,307 Asuncion, Paraguay | Yves Parlier hidroplane cat arrived last in the ORMA 60 multihull class, hardly a success. Lets see how it does in Quebec-St.Malo.
He said the following about the race (bad translation-sorry)
"This was the worst crossing in my life. From Beaufort 3-4 the spray flew permanently. Very soon I was completely wet, despite the sophisticated equipment. I knew it would be tough, but I didn't expect this. I thought I'd be able to sail at ease with the boat under control. But after a favorable beam wind tore one of the mainsails my morale was destructed. The other hull jumps on top of the waves transmiting chocks and vibrations to the craft in the limit of bearable. Apart from that, the lewward sail is hard to see and the craft is difficult to trim. I give myself two years to tame the boat and extract all of its potential, doubtless more for record breaking then for Grand Prix. I was doing 27 knots in Cape Cod and the highest speed reached was 35.5 knots."
Luiz
Luiz
2,943
guests, and 126
