Kevin: Thanks for a good reply, I will have to read trough it several times!
It is nice to hear that amateur building might be feasible even today, with the proper engineering and techniques.
It was probably me asking about wood as a building material earlier. West system has some testing going on with regards to stiffness and repeated cyclic loading. Ref:
http://westsystem.com/ewmag/ (Nr 21)
The idea about presenting yourself as representing a fictous company is not so good in a 'regulated all the way trough' country as Norway. Here all companies are registrated in a central database, where other companies can pick up financial information about it and use them for credit assesment.
On a side note. When I started to look at multihulls some time ago, it looked like homebuilding was something of the past. It looked like today everybody bought what they wanted and went sailing instead of mucking about with projects at home. I tought this was becouse todays fabrication methods was to advanced for the home builder.
Now, some years and several kilos of epoxy and carbon later, I see that there are quite a few homebuilders left around the world doing impressive work. The best part of this, is that you all are willing to share information!
