life vests #31796
03/28/04 07:41 AM
03/28/04 07:41 AM
Long Island, NY
gregP19 Offline OP
gregP19  Offline OP
Long Island, NY
Can anyone recommend a good cat sailing life vest? I'm tired of my old vest blocking my harness hook, riding up in my face and catching on trapeeze wires. Price isn't an issue. Thanks
Re: life vests [Re: gregP19] #31797
03/28/04 12:07 PM
03/28/04 12:07 PM
Socal
nesdog Offline
nesdog  Offline
Socal
I can't give you a particular model to choose from but I do have a suggestion. I had the same problem and solved that by wearing my pfd under my harness. I have clear access to the trapeze connect plate and still feel enough freedom of movement to be comfortable.
Sheldon
P-18
Re: life vests [Re: nesdog] #31798
03/28/04 06:36 PM
03/28/04 06:36 PM
Memphis, TN USA
hobie16dude Offline
hobie16dude  Offline
Memphis, TN USA
Another comfortable option is to try one of the inflatable "horse collars" They are used by professional fishermen and some deckhands... You can find them at Bass Pro Shop or other good sporting goods store. They inflate with the pull of a ripcord that activates a co2 cartrige. Another option is a Body Glove water ski vest, they are solid neoprene, cut large in the arm openings for freedom of movement,they fit snug so they don't ride up, very comfortable, and reasonably priced at Sam's Wholesale Club...
Have a Hobie Day!
Re: life vests [Re: gregP19] #31799
03/28/04 08:14 PM
03/28/04 08:14 PM
Hong Kong
schobiedoo Offline
schobiedoo  Offline
Hong Kong
I use the crewsaver Max lifejacket that is obviously designed for trapezing as it sits fairly high and it never gets in the way of my hook. Check out the link
http://www.crewsaver.co.uk/crewsaver/webpages/50n_buoyancyaids.htm#
Re: life vests [Re: schobiedoo] #31800
03/28/04 09:04 PM
03/28/04 09:04 PM
any kayaking lifejacket is designed to keep the boyancy high to allow paddlers to be able to put on their skirts.
That being said, I have an extrasport with a neoprene shoulder straps and my gf has a Lotus. We both love ours.
Re: life vests [Re: gregP19] #31801
03/29/04 02:48 AM
03/29/04 02:48 AM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Any sailboat/ kyaking dealer with have lifejackets that are cut high. Murrays.com, teamonenewport.com, www.coliesail.com, etc etc all have many options. Almost all dinghy racers use lifejackets that are cut high and work well with trap harnesses.
I would not reccomend the inflatable kind, many big boat sailors use them (it's better than no jacket at all), but if you get knocked unconscious you are s.o.l. they make ones that inflate when they are in water but they are $$.
Re: life vests [Re: gregP19] #31802
03/29/04 08:58 AM
03/29/04 08:58 AM
Neb
flounder Offline
flounder  Offline
Neb
Hit a local dive / paddling store and try some on. I have an MTI vest that sits about 2" above my belly button when seated. The downside is the wierd zipper placement.
A few things to look for:
1. UV resistance
2. Adjustable shoulders
3. Large arm holes
3. Utility pockets
4. Center entry zipper (much easier to use).
Extrasport, MTI and Lotus all make nice designs.
Re: life vests [Re: flounder] #31803
03/29/04 12:32 PM
03/29/04 12:32 PM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
I've been using the Lotus for several years, and I wear it under my trap harness. Works great!
Les Gallagher
Re: life vests [Re: sparky] #31804
03/29/04 02:56 PM
03/29/04 02:56 PM
California
mmiller Offline
mmiller  Offline
California
This is the new offering from Hobie Cat USA for 2004. This is a Kayak paddle vest. As mentioned above, they are perfect for cat sailing. High waisted. Will run $85.00
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: life vests [Re: gregP19] #31805
03/29/04 05:14 PM
03/29/04 05:14 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
I have a Lotus I really like, also an Extrasport, and an MTI of different sizes for guests or crew. The Hobie looks good. I bet Rick White could hook you up with a good one too!
0 registered members (), 285 guests, and 47 spiders.
