Epoxy The Frame #32110
04/05/04 11:13 PM
04/05/04 11:13 PM
DanWiz Offline OP
DanWiz  Offline OP
I have an '85 H16 that has a lot of flex. I have read the articles and given my application of not breaking down the frame except to replace parts, I can't think of a reason not to epoxy it. Have tried shims, tightning the tramp, etc..
Has anyone had success in removing epoxied parts with heat?
Any stong advise to do or not to do the epoxy?
Any advice on where to purchase the rivits cheap without buying four times what I need?
Please give me your input, pro or con.
Dan
Re: Epoxy The Frame [Re: DanWiz] #32111
04/06/04 11:54 AM
04/06/04 11:54 AM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
Epoxy that thing
Re: Epoxy The Frame [Re: rhodysail] #32112
04/06/04 02:25 PM
04/06/04 02:25 PM
Ditto. Especially if it has a red glue seam on the hull/deck joint. (That means it is one of the light '84/'85 boats.)
If it doesn't have the red glue seam, have it weighed. If it weighs over 340 - sell it and get a '95 or newer boat.
Re: Epoxy The Frame [Re: DanWiz] #32113
04/06/04 08:10 PM
04/06/04 08:10 PM
Hong Kong
schobiedoo Offline
schobiedoo  Offline
Hong Kong
Just finished epoxying mine and tightening up the tramp and am very pleased with how much slack is now gone out of the boat. It gets my vote.
Re: Epoxy The Frame [Re: mbounds] #32114
04/06/04 09:41 PM
04/06/04 09:41 PM
St. Louis, MO
nova Offline
nova  Offline
St. Louis, MO
What do you include with this weight? Mast,sails,rudders?
Re: Epoxy The Frame [Re: nova] #32115
04/07/04 02:45 PM
04/07/04 02:45 PM
It includes everything other than stuff you wear - trap harnesses, etc.
Here's the quote from the rule book:
19. MINIMUM BOAT WEIGHTS
19.1 The minimum boat weights shown in the individual Class Rules are for each class of boat, ready to sail, with all permanently attached and non movable racing equipment EXCLUDING the following:
a) Cushions
b) Life jackets
c) Trapeze harnesses
d) Tool bags
e) Personal gear
f) Crew weight
19.2 All weights required to bring a boat to minimum weight shall be permanently attached during a regatta and shall not be usable for any other purpose.
Re: Epoxy The Frame [Re: DanWiz] #32116
05/13/04 08:53 PM
05/13/04 08:53 PM
DanWiz Offline OP
DanWiz  Offline OP
I followed the instructions from www.thebeachcats.com and was very impressed with the results. I would make two recommendations:
1. Measure the before frame flex off the trailer. Flex in the trailer was making it worse than it actually was.
2. If you buy the West Systems epoxy mixing pots, don't throw them away. Wait until the epoxy hardens, flex the container, and the dried epoxy will fall out. Very reusable.
I easily had 1.5 - 2 ft flex prior. After I was done it was between 1 - 2 inches.
I ended up buying a box of SS pop rivets. If anyone is interested I'll mail a set of 14 for $10. Just email me at [email][email protected].[/email]
Dan
