| Re: How are we planning to measure mast lenght?
[Re: carlbohannon]
#32122 04/06/04 09:55 AM 04/06/04 09:55 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Good question, Carl, because we have the same problem. Yesterday Rick's son Dave dumped a very tall mast in our yard and said Rick is going to cut it down for his Wave to race Formula 14. Supposedly, this was a Hobie 14 mast, but I just measured it, and it is about 35 feet long and tapered. Nobody knows what kind of boat this mast was on originally. It looks OLD, but maybe we will be giving it a new purpose and saving it from the aluminum recycling bin. | | | Re: How are we planning to measure mast lenght?
[Re: Mary]
#32123 04/06/04 01:16 PM 04/06/04 01:16 PM |
Posts: 591 Bradenton, FL | So, I guess the question is- do we measure the total length of the mast, or the length of the extrusion?
I am thinking of using a TheMightyHobie18 mast. Does anyone know how long the comp-tip is? The H-18 mast should be 28' long, so if the comp-tip is 4' or less I can cut at the top. If it's 4' or longer I'll have to cut at the bottom, or find another mast.
Hobie 14T
[Re: Berny]
#32125 04/06/04 10:17 PM 04/06/04 10:17 PM |
Posts: 744 | I'm all for the length of the extrusion. What do y'all think?? Bob
[Re: carlbohannon]
#32126 04/06/04 10:40 PM 04/06/04 10:40 PM |
Posts: 12,310 South Carolina | Bob,
Yep - I second that - length of extrusion.
In order to keep from alienating anyone from the class in one year, this kind of decision should be made now.
While getting money at the ATM down the road, I spotted a H14 rotting in someone's back yard...I'll be leaving them a note next week!
Jake Kohl | | | Re: How are we planning to measure mast lenght?
#32127 04/06/04 11:12 PM 04/06/04 11:12 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Well I'm going to be competing on a new 4.3 metre cat within the next 3 months. It's all carbon fibre ie hulls, mast, beams, boom, rudders, C/boards, rudder stocks, and the mast will be 25' long (without the fittings). I will be sailing it as a formula 14, one up on trapeze cat rigged with spinnaker or two up on trapeze cat rigged with spinnaker. I personally would not like to see a restriction on the mast length (no matter how you measure it) any less than 26'or even 27'. Forget about the dimensions of ALL the existing "14' cats" when setting up a completely NEW formula 14. None of the new generation cats that will form this formula have as yet seen the water, so lets not try to restrict them to all the perimeters of "last centuries" designs, Be satisfied with formulating a working formula for all the existing 14' cats to be able to sail together for an "across the line first wins" competition, but don't stiffle what has the potentual for being the best thing to happen to 14' cat sailing since the introduction of fibreglass, by making restrictions based on past manufactureres or association "class" boats. Darryl J Barrett | | | Re: How are we planning to measure mast lenght?
[Re: Darryl_Barrett]
#32134 04/07/04 03:01 AM 04/07/04 03:01 AM |
Posts: 461 Sydney Australia | Let them do what they want Berny, if you were to allow trimarans or tri foilers or triple hulled planners or hydrofoiled craft, it all starts to get a little out of control Sorry Darryl, but as you yourself suggest there needs to be some rules even if they are simple because the class needs the stability of equality or people won't support it including manufacturers. The attractive thing about one design is that there is equality but the major problem with one design is there are too many different classes, each with but a few participants. The attractive thing about the formula class is, it has the potential to bring many of the one design classes together in one fleet but it also needs to adopt the attribute of the equality that one design offers and that can only happen if there are some parameters to begin with otherwise; it all starts to get a little out of control.  Bern | | | Re: How are we planning to measure mast lenght?
#32136 04/07/04 04:12 AM 04/07/04 04:12 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Trimarans? I heard that from the founder and director of the Formula 14 class. And I do not see how they are incompatible with catamarans. They raced against each other in the Formula 40 Class.
Foilers? As far as sailboats, I see those as a completely separate, new classification that encompasses sailboards, monohulls, catamarans, and trimarans.
Foilers are at least as different from multihulls as multihulls are from monohulls. In essence, foilers bring all of the sailing boat types/hull types together because they all start being more equal once you get ABOVE the water. It is a whole new dimension with its own experimentation going on. They do not really belong in any specific "water-locked" sailing class, formula or not. In fact, I think that trying to fit into an existing class would inhibit the development of the foiler technology.
Add: In fact, foilers are kind of like sailboards in being a separate classification.
[Re: Mary]
#32137 04/07/04 06:47 AM 04/07/04 06:47 AM |
Posts: 1,012 South Australia | Mary there are trimarans that although they have foils on the lower ends of their vertical supporting foils, they are not hydrofoils! they achieve their bouancy with very high aspect ratio vertical foils (like three long daggerboards )which collectively have enough bouancy to fully support the "hull" (in this instance refered to more as "fuselarge") well clear of the water and the, neutral lift, horizontal foils under water are used the same as aerolons and elevators on an aeroplane. Although it may sound a little strange when one hasn't seen the plans for one (or one actually sailing)I can assure you that this form of sailing is getting up there with the sort of drag coefficients that we see in an ice yacht (almost but obviously not quite) and although by any ones definition, when you have seen one you would have to say, if asked what "type" of sailing craft was it? you would answer Trimaran (and not hydrofoil because a foiler relies on forward motion to generate lift where as this achieves its lift with its bouancy the same as any catamaran, trimaran or mono hull). If one of these at 14' in length was put up against any catamaran of any size there would be absolutely no competition the "trimaran" would more than double the cats speed on all points of sail and more on some. Would that be fair competition? I think that instead of fostering more diversity and more sailor involvement, it would just stop any and all desire to try to compete against some thing that you knew was "light years" ahead of what you had and it was always going to be that way. Oh by the way just who is it that you say is the founder and director of the Formula 14 class? I have heard this "idea" of a formula style class for 14's 16's "A" class (18's) B2 class (18'sloop), B class (20'), C class being talked about, discussed at length resulting in association constitutions, regulations, and class rules being written and in some instances incorporated, ever since the late 1950's I have a copy of the constitution, the class rules, and the regulations that were written in 1979 specifically for a 14' cat formula where any and all makes of 14' cats could race for first over the line as long as they fell within the "box Rule" It is an idea that, as far as I am aware "belongs to no one person" It has floated around and at times in the past has come closer to fruition then than this one has (as yet). I have always been an advocate of this form of rating specifically sized craft, so that it gets rid of the "one class" idea which has always been slightly diversive for sailing and instead bring in this idea which portents more towards amalgamation of the "Class's" | | | Re: How are we planning to measure mast lenght?
[Re: Berny]
#32138 04/07/04 07:07 AM 04/07/04 07:07 AM |
Posts: 744 | This weekend looks like a great opportunity to discuss with the US sailors at the Spring Fever. I can report back early next week with everyone's thoughts. I'll be leaving early Thursday morning and will be off line until Monday. Thanks for all the great discussion! Bob
#32139 04/07/04 09:25 AM 04/07/04 09:25 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Darryl, aren't you saying the same thing I said -- that foilers should be in a separate classification or separate class? I still don't see what that has to do with whether a boat has two hulls or three hulls in a Formula 14 class. In fact, why wouldn't it allow monohulls, too? The class name and the rules don't mention "multihull."
The rules also don't prohibit foils, but I imagine that will be addressed. Or maybe that would be one of the "sub-classes" alluded to in the rules.
It's kind of funny how this whole thing has mushroomed. It all started with Bob Curry coming up with the idea of forming an informal Formula 14 class so the Hobie Waves and Mystere 4.3's and Hobie 14's could race together. Well, that didn't last long! Within a day or two it had turned into a development class. At this point it is still just an idea. We'll see what happens this weekend at Spring Fever when the Formula 14 class makes its debut.
If Australia already has had a Formula 14 class for a long time, why don't you send the constitution and rules to Bob Curry? The people who gave input to forming a Formula 14 class here were certainly not thinking on an international scale and I don't think anybody was aware that such a class already existed in some other part of the world. | | |
1 registered members (JesperS),
759
guests, and 38
