Help with hull damage! #32379
04/14/04 10:53 PM
04/14/04 10:53 PM
Minneapolis, Mn
Wrinkledpants Offline OP
Minneapolis, Mn
I don't know the story how this anchor was damaged cause it was like this when i bought it. It appears to be just the top of the deck where the is damage. There are only a few small hair line cracks runnings along the top. I think its only in the gelcoat. I guess my question is should i pay to have this fixed? The rivets aren't damged any nor are they loose. I can move the anchor only because i think it's flexing. Has anyone had any experience with this? Thanks everyone!!
Reid Rechel
32512-Home 008.jpg (207 downloads)
Re: Help with hull damage! [Re: Wrinkledpants] #32380
04/15/04 06:24 AM
04/15/04 06:24 AM
I would repair it - if it were to fail it would be a certain dismasting. Secondly, it will very likely be a small leak into the hulls. What year is that 5.2?
Re: Help with hull damage! [Re: Wrinkledpants] #32381
04/15/04 02:56 PM
04/15/04 02:56 PM
Maryland
Kris Hathaway Offline
Maryland
Ouch! Bad memories.
I had a 5.2 where the shroud pulled right through a chain plate that was visibly in fine condition. Sling shot my 12-year-old son as she demasted.
Ronstan does not make the plate used in the 5.2 any more. Consequently, I ended up manufacturing a replacement from a mast tang that had the same dimensions as the chain plate. Only had to drill the necessary holes to mount.
Good Luck
Kris Hathaway
Nacra 6.0NA
Kris Hathaway
Re: Help with hull damage! [Re: Kris Hathaway] #32382
04/15/04 07:51 PM
04/15/04 07:51 PM
Minneapolis, Mn
Minneapolis, Mn
Its a 1980. I don't think it's damaged anywhere near the rivets, it's just the top. How do you fix something like this? Drill out the rivets, insert a new anchor and rivet that in? Is this something i could do myself (i'm mechanical but have never done glasswork). Thanks all!
Reid Rechel
1 registered members (FredL), 446 guests, and 68 spiders.
