| Re: Solo Righting system for H16
[Re: TypeR289]
#32594 04/25/04 09:53 PM 04/25/04 09:53 PM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | Hello, I had the anti-pitchpole attachments on my H16 and I thought they were worth the expense. There were a few times when I felt they saved me from a tumble. If nothing else, it'll give you a little confidence to push the boat harder. I know that the SoloRight is a well proven righting device. It has worked for boats up to 21'. Gary's website is at http://www.geocities.com/hobiegary/soloright.html The righting pole that is sold at catsailor.com is another option, but I'm think it's use solo depends on your weight. Jack
Jack Hoying
Fort Loramie, Ohio
[Re: TypeR289]
#32595 04/26/04 08:48 AM 04/26/04 08:48 AM |
Posts: 324 South Florida | Jay,
I sail a Hobie 18, which is much heavier than a 16. My main problem when sailing (which I do mostly solo) is knowing that If I go over I will not be able to right the boat. Yesterday I went down to the club and rigged a contraption which was posted on this website. It's a righting mechanism based on Ricks righting pole (a low tech and cumbersome version). I flipped the boat 7 times to see if I could right it and I did every single time without any problems! i weigh 180 lbs. This will definitely give me more confidence when sailing out in the ocean. Buy Rick's righting pole!! The system absolutely works!!
Fred F
(ex Hobie 18)
[Re: jmhoying]
#32596 04/27/04 12:34 PM 04/27/04 12:34 PM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen
Posts: 270 Nepean (Ottawa) Ontario Canada | I had the anti-pitchpole attachments on my H16 and I ......
Jack, Are you referring to the small moulded plate that wraps around the top of the nose that provides lift to stop the initial dive? I always wondered about them.
Cheers Alan F
Tiger
[Re: Frozen]
#32597 04/27/04 01:37 PM 04/27/04 01:37 PM |
Posts: 349 Fort Loramie, Ohio | Yes, that is the type we used. Here's a couple photos of them installed on our boat. It comes with longer bolts for mounting in your existing tang position. Keep the old bolts, as you can always remove the fins if you want to race in a class event, or if you sell your boat. Jack Fort Loramie, Ohio
Jack Hoying
Fort Loramie, Ohio
3,115
guests, and 352
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
