| H-20 mast rake #32685 04/27/04 03:09 PM 04/27/04 03:09 PM |
Posts: 248 Colorado | I'm adjusting the mast rake on a new H-20 and I'm looking for some opinions. My crew and I are 300 pounds and always struggle in heavy wind. I'm assuming more rake is better in this situation, but I know this changes with diamond wire tension. What are other lightweight teams doing and what is the best way to measure the rake?
H-20 #896
| | | Re: H-20 mast rake
[Re: jonr]
#32687 04/27/04 09:57 PM 04/27/04 09:57 PM |
Posts: 833 St. Louis, MO, | Do as Bob's article says and then in the back you should be able to touch the upper rudder pin with the line. That's where I like it.
Mike Hill H20 #907
Mike Hill N20 #1005
| | | Re: H-20 mast rake
[Re: Mike Hill]
#32688 04/28/04 05:14 AM 04/28/04 05:14 AM |
Posts: 744 | Mike is right; the newer sails like lots of mast rake. Use the transom as if it were the rear beam for the tuning articles. One question: where is your spreader sweep/diamond tension? Bob
| | | Re: H-20 mast rake
[Re: Bob_Curry]
#32689 04/28/04 12:49 PM 04/28/04 12:49 PM |
Posts: 248 Colorado | This is really helpfull. My spreaders are raked at 1.5 inches. I've been told that because we are at the low end of light for crew weight that I should go for more rake in all but the lightest conditions. As I said, we have a very tough time keeping the boat down in wind over 20 knots. I think this gives me a great start for some trial and error (hopefully less error).
H-20 #896
| | | Re: H-20 mast rake
[Re: SteveT]
#32690 04/28/04 02:18 PM 04/28/04 02:18 PM |
Posts: 833 St. Louis, MO, | I would go with 2" of rake at your weight. That is with the wires with almost no tension. Put a straight edge against the wires not the spreader ends. This measurement should be 2". This measurement will change as you increase or decrease diamond wire tension.
Mike Hill H20 #907
Mike Hill N20 #1005
| | | Re: H-20 mast rake
[Re: bsquared]
#32692 04/29/04 12:19 PM 04/29/04 12:19 PM |
Posts: 248 Colorado | My question is can you point with the mast raked back past the sterns in light air, even with the new sails? That's the other issue for us. On my previous H-20 I had a new main with an older jib and we raked the mast back to keep the boat managable in heavy air, but in most conditions we were consistently out-pointed, particularly in light air. Some of that had to do with the droopy jib and improper jib-car placement, the latter I discovered after quizing some other light crews on thier techniques. The more dramatic mast rake certainly creates more weather helm, and in light air has caused the boat to round up when a puff fills in. I think that more spreader rake would add more pre-bend and flatten the sail, which is good for our weight, and would allow us to stand the mast up a little bit more so we could point with the bid dogs. Does this make sense to anyone/everyone?
H-20 #896
4,318
guests, and 1,107
