| Re: wave blade jib
[Re: RickWhite]
#32857 05/25/04 10:38 PM 05/25/04 10:38 PM |
Joined: Jul 2002 Posts: 32 Victoria, Australia Inland_Sailor
Posts: 32 Victoria, Australia | [quote]I am presently working up a rig for the F14 Class that will add a larger jib that is self-tacking.
Rick, what progress have you made with this new jib for the F14 and Wave and when do you think you'll have them available?
Magnum
| | | Re: wave blade jib
[Re: Inland_Sailor]
#32860 06/22/04 10:06 AM 06/22/04 10:06 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | The rig I want to use for the F14 Class would have a long bow sprit (around 10'), and place the forestay much farther forward than it's present position. I would then have a roller furling spinnaker (Hooter), and a roller furling jib (fairly large) that would be self-tacking. With this rig you would have plenty of power upwind (trapeze should be used) in normal winds; in very light winds you could use the Hooter upwind; and in heavy air just furl and sail with the main. Off the wind there would be two nice slots and should create plenty of speed. In theory I believe the Wave Platform will do better than the H14 because it has so much more buoyancy. But who knows?  See ya, Rick | | | Re: wave blade jib
[Re: RickWhite]
#32861 06/23/04 12:22 AM 06/23/04 12:22 AM |
Posts: 32 Victoria, Australia | and place the forestay much farther forward than it's present position Rick, How do you envisage the new forestay being attached further forward. especially on the Wave? Will it be available to be used as a seperate unit to the bowsprit/screacher package for the Wave? How much larger will the new Jib be than the stock Wave unit?
Magnum
| | | Re: wave blade jib
[Re: RickWhite]
#32863 07/19/04 07:55 PM 07/19/04 07:55 PM |
Posts: 32 Victoria, Australia | Rick
When in the Fall do you think you'll be back to work on this project? Can you let us know of your progress and development of the new setup as you move it along? I'm sure we would all like to know [pics as well] how its progressing?
Magnum
| | | Re: wave blade jib
[Re: Inland_Sailor]
#32864 07/20/04 09:38 AM 07/20/04 09:38 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Sure can keep you informed. I will heading south to Pensacola for the Wave NAs on the weekend of the 24th and on to Key Largo from there after the races. Then I will be back close to Calverts where we can work on the project. Basically, I intend to use a 10' bow sprit, use the Hobie bow spreader to keep the hulls from coming together, and then replace the present halyard with a halyard that is attach about half way out the bow sprit. That is where I intend to hank on the roller furling jib. I want to set it up as self-tacking. Then I will use the roller furling Hooter at the end of the bow sprit and sheet from the aft part of the boat (That I am already doing -- you can see the whole story at Wave Class Site on the Super Wave) That will be a pretty powerful rig on a platform that can handle a lot of buoyancy. However, you won't be able to hold the boat down in winds over 12 mph, so I intend to have a trapeze as well. Since the tiller is in front of the mainsheet, a standard tiller extension will not work -- you would constantly be fighting to get it and you through during each tack and jibe. So, I will use a long, one-piece tiller extension that goes out both sides of the boat. It will be bent up so it does not hit the water on the leeward side. Anyway, that is the plan. Thanks for asking, Rick | | | wave blade jib
[Re: RickWhite]
#32865 07/20/04 08:12 PM 07/20/04 08:12 PM |
Posts: 32 Victoria, Australia | Since the tiller is in front of the mainsheet, a standard tiller extension will not work -- you would constantly be fighting to get it and you through during each tack and jibe. So, I will use a long, one-piece tiller extension that goes out both sides of the boat. It will be bent up so it does not hit the water on the leeward side.
[/quote]
Rick, Your thoughts on revising the tiller cross arm setup to a standard type ie, behind the mainsheet. Then wouldn't a regular tiller extension be possible and easier to use!!!? Your comments!!!
Magnum
| | | Re: wave blade jib
[Re: Inland_Sailor]
#32869 10/19/04 03:35 PM 10/19/04 03:35 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | I really have not had time.., spent the summer at Put-in-Bay and had no place to try out things.
Also, it appears that the hoopla about a F14 Class has gone away.., the reason for adding all the sail area. And, I have done really well with the Wave with Hooter only. Of course, if the wind pipes up too much, then I would love to have the self tacking jib.
This summer I was able to stay with the Mystere 4.3 class upwind and downwind most of the time.
I jwould love to continue working on the idea, however. Rick | | | Re: wave blade jib
[Re: Loren]
#32871 03/29/07 08:55 AM 03/29/07 08:55 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | For a jib to work properly, the jib luff must be very tight in most wind conditions -- although perhaps not so much on reaches. Since the jib attaches to an thin aluminum bar between the hulls, you cannot get enough tension. If you get the tension you really need, it will only be for a short time -- the cross bar will break.., or bend so much that you will lose the luff tension. To tension a jib you need more than to pull it and cleat it. You should use at least a 2:1 or 3:1 tensioner. Check it out. Next time you are sailing up wind, look at the luff of the jib. It will be sagging way off to leeward. If the luff looks arced, it is not working. if the luff looks almost as straight as the mast, it is working. To stop the catching, duct tape the cleats, and then put a bungee cord running from the mast to each side of the boat as a preventer. Good luck, Rick | | | Re: wave blade jib
[Re: Loren]
#32873 03/29/07 09:39 AM 03/29/07 09:39 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Note from Mary: Since the Wave doesn't have diamond wires, in order to have that bungee cord to prevent your jib sheets from catching, you will probably have to install a small eye strap on the front of the mast, maybe 18 inches or more up from the bottom, to run the bungee cord through. I would tie it off at the eye strap with a half-hitch or something, and then run each end of the bungee down to each end of the main beam and tie off there, where there is an opening in the trampoline at each end of the beam.
If that still doesn't work, you can come up with various creative variations on the same theme. And let us all know what works best. | | |
1 registered members (vasil),
412
guests, and 25
