How are the builing projects going? #33521
05/20/04 09:50 AM
05/20/04 09:50 AM
Houston
carlbohannon Offline OP
Houston
Has anyone made any progress on building a boat?
I can understand why a builder may not be posting, every spare minute goes into building or trying locate parts or supplies.
My status:
My boat has seen the water. I had to use a Laser rig in a bolted on plywood adapter/mast step. Everything went as expected. Meaning only one rudder would lock, the mainsheet wouldn't feed and later twisted. The hulls performed well. The boat tacks, gybes and the hulls don't leak. With the Laser rig it was way underpowered, J24's were out running me. When I finally got a puff that made the hull feel light, the mast step broke. I had to sail back with an advanced canting rig. The rig was canted the wrong way on one tack. As normal, that was the tack I needed to get home.
Right now I am shortening a broken Marstrom A-Class mast. That mast is amazing. The 30+ ft extrusion is lighter than a Laser mast.
It turns out shortening a carbon mast is pretty easy. Mine is a tapered mast, so it must be shortened between the diamond wires. Mine was broken about a foot below the top diamond wire tang. The only thing that needs to be/can be moved is the spreaders. The only tricky part of that, is maneuvering the internal reinforcement to the right spot on the end of a long stick.
I also learned something last night. If you have a choice, make your mast a little longer than you need/want. That way the top of the sail does not have to be completely flat. Adding a small diagonal or curved section to the top of a square-top improves leach control. My experience agrees with this. It is difficult to control the top section of an extreme square-top.
Good luck to everyone
Re: How are the builing projects going? [Re: carlbohannon] #33522
05/20/04 11:06 AM
05/20/04 11:06 AM
How about some pics for everyone???
Bob
Re: How are the builing projects going? [Re: carlbohannon] #33523
05/20/04 04:40 PM
05/20/04 04:40 PM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
I thought about doing a project 14, but I bought a SC19 and that has moved up to number one. It is going to be a big project as I hardly have any parts for it.
I sold the A-cat and the Prindle 18-2, so I'm hurting for something else.
Thinking about selling one of the H14s with the Hooter rig. I had the one I raced (at least that is what I was calling it) in GA out the other day and had a good time hanging with a Nacra 6.0 and Hobie 16.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: How are the builing projects going? [Re: carlbohannon] #33524
05/25/04 10:14 AM
05/25/04 10:14 AM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Want to build a new boat? I have a F-16 (being built from scratch) that I don’t have time to deal with…It’s tortured ply…all the best marine materials…could be modified to be used as a F-14 at this stage of construction…Located in Fort Pierce, Fl…
Bob
Re: How are the builing projects going? [Re: carlbohannon] #33525
05/29/04 07:05 PM
05/29/04 07:05 PM
Surabyakid Offline
Surabyakid  Offline
I started rigging the Hobie 14 today. Got the shroud reenforcement done as well as the spinnaker pole mounting. Tomorrow the mast....
Pat
0 registered members (), 369 guests, and 101 spiders.
Posts267,056
