Question on trailers #34102
06/06/04 04:45 PM
06/06/04 04:45 PM
G
Geoff56 Offline OP
Geoff56  Offline OP
G
I am attempting to buy a seaspray 15 but I can't for the life of me find a trailer. Could someone out there help me figure out where to buy one or how to build one.
Cheers, Geoff harris
Re: Question on trailers [Re: Geoff56] #34103
06/06/04 06:47 PM
06/06/04 06:47 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
Geoff, You'll findit helps if folks know where you are located. Good luck! Brian
Re: Question on trailers [Re: Geoff56] #34104
06/06/04 07:52 PM
06/06/04 07:52 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Contact Bob Richards via the email address or phone number listed on the Sea Spray Central website.
http://home.earthlink.net/~soapysails/
He carries his on a truck rack but should be able to offer you lots of trailer ideas on making a simple custom one as he is a real Sea Spray enthusiast.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Question on trailers [Re: Geoff56] #34105
06/06/04 11:19 PM
06/06/04 11:19 PM
Québec, Canada
CharlesLeblanc Offline
Québec, Canada
Hi Geoff
I use to have a Venture Cat 15, probably the same size as the sea-spray but with less fun factor and more ugly factor.
It is much smaller than a regular cat and also narrower.
Many cat trailer have ajustable rollers and can be easily and safely modified to fit a boat like the sea-Spray. Once you have moved the rollers that that the boat is fine, you can cut the excess tubing from the trailler's crossbars
You can also have a stock trailler modifier at a trailler shop (or do it yourself) The main things to add are:
Crossbeam with rollers and vertical guides to hold the hulls.
Front mast holder
Things to check: The tongue must be long enough the hulls need to clear the read of the car when turning sharp (especially when backing up)
The frame of the trailler should be 4'x8' instead of 4'x4' Some boat trailler base a 4'x4' base with bars that connect to the tongue fo form an A frame. There bars could hold the front crossbar but the framing needs to be heavier to keep if from flexing too much.
Wheels should be of standard size ands easy to find and replace. Also you need one spare!
Once you have all of that, you can even do some additionnal work on the trailler:
Add a sail tube
Add a trailer box
Add a rear mast holder
The best solution should be to take an existing cat trailler and simply move the rollers to the proper position
Charles Leblanc
Nacra 5.2 #28
Charles Leblanc Nacra 5.2 #26
Re: Question on trailers [Re: Geoff56] #34106
06/07/04 09:58 PM
06/07/04 09:58 PM
Edmonton, Alberta, Canada
Al Schuster Offline
Al Schuster  Offline
Hi,if you're in the Northwest, Glenmore Sailboats in Calgary, Alberta used to make them (Seasprays, that is) and might be able to help. (go Flames!)
0 registered members (), 321 guests, and 55 spiders.
