| Re: Trailer Lights
[Re: Kory]
#34189 06/10/04 06:27 AM 06/10/04 06:27 AM |
Posts: 12,310 South Carolina | Your first problem is that the trailer does not carry a catamaran sailboat!
Seriously though, an atypical rear trailer light bulb has two elements in it for two different signals; illumination (i.e. parking lights) and brake/turn signal. If you are getting neither a brake light or turn signal, it could be that the bulb is bad, the bulb is making a poor connection on one of it's contact points, the trailer connector is making a poor connection to the vehicle harness, or you have a bad wire somewhere.
Jake Kohl | | | Re: Trailer Lights
[Re: Kory]
#34191 06/10/04 08:21 AM 06/10/04 08:21 AM |
Posts: 396 Annapolis Md. | Jake is right, put a go fast catamaran on there and the lights will work fine. I chimed in because I'm considering LED lights for my trailer. Any thoughts or experiences?
Still hazey after all these beers. F-16 Falcon #212
| | | Re: Trailer Lights
[Re: LuckyDuck]
#34193 06/10/04 10:09 AM 06/10/04 10:09 AM |
Posts: 74 Maryland, USA | I put on on LED lights the last time my catamaran trailer lights were giving me problems. Well worth the extra cost. LED's are sealed, they should last nearly forever, and the bolts for mounting the kind I got were stainless steel. I don't know the brand off the top of my head.
I just bought a brand new trailer for my power boat. Its supposedly (standard bulb) "sealed" lights were full of water after the first time I launched the boat. I will be converting them to LED's when they stop working.
Patrick Ragen Taipan 4.9 USA 274
| | | Re: Trailer Lights
[Re: carlbohannon]
#34196 06/11/04 09:45 AM 06/11/04 09:45 AM |
Posts: 12,310 South Carolina | you're kidding!? I was considering that same modification because my boat stern ends up so far behind my trailer lights...oh well.
[Re: MauganN20]
#34200 06/14/04 10:05 AM 06/14/04 10:05 AM |
Posts: 12,310 South Carolina | My LED lights are on and the whole trailer is rewired with all soldered connections and shrink tubing. No crimp connectors, nutz, or easy splices here! I then found that my light converter unit had failed on my truck (likely due to all the previous shorts) and replaced it too. Them thar' LED lights is fancy like!
#34201 06/14/04 10:42 AM 06/14/04 10:42 AM |
Posts: 851 US Western Continental Shelf | Glad to hear of these new designs that are worthy of the waterproof claims. Many non-L.E.D. designs' weak points were the need to disipate the heat generated my an incandescent bulb. LED's solve this.
Thanks to you all, I am nearly motivated to add trailer lights and dispense with my funky, strap on light bar.
I'd like to mention that there is an upper-end type of shrink tube that has glue inside it so that it not only shrinks, but creates a seal also. (that is the product's claim, I have not tried the stuff yet)
I'll bet those who own glue guns could do some great things with them to aid in waterproofing.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Trailer Lights
[Re: hobiegary]
#34202 06/14/04 11:36 AM 06/14/04 11:36 AM |
Posts: 47 | Trailer lights if installed correctly and not messed up by mistakes have a good life. I have had 6 or 7 cat trailers over the past 20 years and once I get the lights the way I like them I never have a problem. Though I sail in salt water I never dip my cat trailers in the water. A well designed cat trailer has mounts for lights that protect them from being broken. Spray lubricate in the vehicle connection and if necessary grease the light bulb contact points.
Mark
C28R no. 140
Houston, TX
| | | Re: Trailer Lights
[Re: Mark Meis]
#34203 06/14/04 04:05 PM 06/14/04 04:05 PM |
Posts: 805 Gainesville, FL 32607 USA | Who can describe the number of LEDs to use in trailer lights? Bright white LEDs are like 32 cents each. But commercial 1157-type bulbs now can be found online with like 24 LEDs per "bulb" and are $7 each, with 16 LEDs are $4. But they would have to be soldered into the regular red-lensed cheap trailer light fixture. Also they have just one filament. This ain't too bad. More practical suggestions?
| | | Re: Trailer Lights
[Re: hobiegary]
#34204 06/14/04 04:33 PM 06/14/04 04:33 PM |
Posts: 12,310 South Carolina | I even went the extra 10 miles and smeared 3m 3500 under all the heat shrink tubing before I shrunk it. Did I mention how sick I was of having to work on trailer lights before every $%#( trip!?
Of note: I once had a short on this trailer that took out the fuse for my running lights on my RV. At the same moment, the short destroyed my anti-lock brake CPU and I suspect it initiated the slow death roll (gradually increasing heat sensitivity/failure) of my Engine Management Computer in the same RV. $300 worth of electronics and about 30 hours of my time and I have a new anti-lock brake unit (ebay!), EMC(Autozone $$), and an ISOLATED trailer lighting system on it's own fuse. Now we're ready to roll!
Jake Kohl | | |
692
guests, and 118
